  1. Sep 22, 2020 at 7:08 AM
    #8071
    speedtre
    speedtre New Member
    Inland Northwest
    Ok, we are all well aware of the GX460 caliper upgrade, but has anyone tried the T100 brake booster/Master Cylinder upgrade? It seems to me, that these two in conjunction might just be the Holy Grail of FGT brake upgrades (I'm not sure how much increased brake performance the rear disc kits are...but I'd like those for convenience too, just too expensive). It seems like all in, this option (Calipers/Booster/MC) would be well under a $1000 if you do it yourself...
    One of the things I'm struggling with in my head is trying to figure out why Toyota would have downgraded the performance of the BB/MC on the at the time new Tundra relative to the older T100...? I know the T100 appeared before @empty_lord was born, but being a Toyota Tech, maybe he has some insight?
  2. Sep 22, 2020 at 7:24 AM
    #8072
    As I read your post I was literally thinking the exact same thing. Maybe the answer simply boils down to cost? Otherwise I don't know why they would do it. I've only seen the T100 swap mentioned one time but haven't seen anyone actually do it.
    speedtre[QUOTED] likes this.
  3. Sep 22, 2020 at 7:32 AM
    #8073
    speedtre
    speedtre New Member
    Inland Northwest
    I know that the guy who came up with the caliper upgrade has also mentioned this upgrade as well on FB, but I can't find anymore info on it from him directly.
  4. Sep 22, 2020 at 7:40 AM
    #8074
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Just do the sequoia master with the sos adapter, easier
    ktundra and speedtre[QUOTED] like this.
  5. Sep 22, 2020 at 11:46 AM
    #8075
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Have you tested the purge solenoids?
  6. Sep 22, 2020 at 12:07 PM
    #8076
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Maybe they gave us a weaker booster and M/C because we got ABS and I don't think the T100 did?
  7. Sep 22, 2020 at 12:23 PM
    #8077
    speedtre
    speedtre New Member
    Inland Northwest
    Darkness[QUOTED] likes this.
  8. Sep 22, 2020 at 12:33 PM
    #8078
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Voss and speedtre[QUOTED] like this.
  9. Sep 22, 2020 at 6:19 PM
    #8079
    empty_lord
    05 rollover special
    T100 had 1 Ton options with bigger rear drums.
    speedtre and Darkness[QUOTED] like this.
  10. Sep 22, 2020 at 6:27 PM
    #8080
    Cummins3500
    Logan
  11. Sep 22, 2020 at 10:18 PM
    #8081
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  12. Sep 22, 2020 at 10:25 PM
    #8082
    empty_lord
    05 rollover special
  13. Sep 22, 2020 at 10:45 PM
    #8083
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have a set of longer lines that replace the rubber section and the hardline section. They go from the hardliners at the frame to the caliper as one piece. I like the idea of eliminating the extra joint, but it wasn't for having a longer line.
  14. Sep 23, 2020 at 8:41 AM
    #8084
    Cummins3500
    Logan
    Gotcha thanks for the replies,
    if I was to order an set, should I go +1 or +2?
  15. Sep 23, 2020 at 9:39 AM
    #8085
    Does anyone remember which direction moves the headlight bulb up?
    Darkness likes this.
  16. Sep 23, 2020 at 8:59 PM
    #8086
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I'm running an OBDii to my phone but still learning to read it.
  17. Sep 23, 2020 at 9:03 PM
    #8087
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I replaced the one under the hood as well as gas cap and PCV valve so I'm down to the vent solenoid under the truck attached to the charcoal canister, the canister itself, or incorrectly connected lines to the newly installed used fuel tank, or leaking fuel tank
  18. Sep 23, 2020 at 9:31 PM
    #8088
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm gonna guess counterclockwise
    Works faster if you paint your screwdriver black
  19. Sep 23, 2020 at 10:06 PM
    #8089
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I had evap troubles on my Tahoe. I don't remember if it was code P0441 or P0445. Mine kept pointing to the fuel tank pressure sensor. May be an idea on yours also.
    JessiJane06Tundra likes this.
  20. Sep 23, 2020 at 11:33 PM
    #8090
    artsr2002
    'Yonder
    Put stickers on it for more horsepower.
  21. Sep 24, 2020 at 5:25 AM
    #8091
    Professional Hand Model
    Fred
    Hand Protectors
    Run it across some Sacred Earth Crystals for Special Mojo.
  22. Sep 24, 2020 at 12:31 PM
    #8092
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    New Zealand wagyu patties grilled with a dusting of garlic and a generous amount of black pepper, bacon covered in black pepper, fresh lettuce, tomato doused in black pepper, herb mozzarella, grilled sweet onion, lightly grilled brioche buns with a bit of alioli mayo.
    I like black pepper.
  23. Sep 24, 2020 at 1:40 PM
    #8093
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    My stomach is yelling at me.
    bmf4069 and Darkness like this.
  24. Sep 24, 2020 at 4:43 PM
    #8094
    Can you send one of those my way?
  25. Sep 24, 2020 at 4:57 PM
    #8095
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That looks better than my dinner :monocle:
    bmf4069 and Darkness[QUOTED] like this.
  26. Sep 24, 2020 at 4:59 PM
    #8096
    Fred
    Hand Protectors
    Excellent Thumb Pose. Cuticles are looking sharp!
  27. Sep 24, 2020 at 5:44 PM
    #8097
    Haha my buddy wasn’t lying when he said there is all kinds of fancy schmancy meat shops in Cali! That sounds super good, I’m a black pepper fan as well, I won’t measure my love here..... I’ll send you some jerky if you want, I’m kinda scared based on how much my cuticle burned today from making the marinade........
  28. Sep 24, 2020 at 5:46 PM
    #8098
    16408EDF-03DE-4C7A-B941-20A8365C4FD0.jpg Baller status, I’m kinda stoked!
  29. Sep 25, 2020 at 11:20 AM
    #8099
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Taking the truck in for a smoke test it's too expensive and difficult to keep making semi educated guesses and I have a stuck spinning bolt holding the vapor canister in place. Let's hope for it's not one of the 300 dollar parts or even worse the fuel tank I just had put in.
    NUDRAT[OP] and shifty` like this.
  30. Sep 25, 2020 at 12:17 PM
    #8100
    I suspect it'll be the rear purge (if exists) or the tank pressure sensor, possibly the tank if this started after replacement. Only two of those are gonna show smoke. :)
    It should be very clear whether the tank pressure sensor is working correctly, I would think. But haven't had to dick with one on a Toyota before.
