Rigid SAE 30" light bar and Spod help
Discussion in '2.5 Gen Tundras (2014-2021)' started by CorsoTundra, Jan 9, 2020.
  1. Jan 9, 2020 at 5:23 AM
    CorsoTundra
    CorsoTundra [OP] This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    So I just got my Rigid SAE 30" light bar to put in my C4 hybrid front bumper, as soon as it's done getting powder coated, and I want to hook it up to my Spod. The harness that is provided by Rigid has 2 relays and a 40 amp fuse. I know that Spod says you dont have to use the harness because the fuse and relays are built in to the switch panel however, the harness doesn't look so easy to just cut fuse and relays off and splice to the shorter section of where the battery terminals connect. This is what it looks like.
    Has anyone done this? It doesn't look like rigid makes a direct plug and play harness for this type of light connection like they make for their D series lights. Like this.
  2. Jan 9, 2020 at 6:37 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve got 2 SR30 in my Tacoma and an SR40 in my tundra and I just chopped off the harness right after the relay and connected it to my switch pro. Not sure why that harness has 2 relays instead of one.
    you can give rigid a quick call and ask, I called them once about something and I was able to talk to someone right away and get my question answered.
  3. Jan 9, 2020 at 6:38 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    Call , sPOD they will help you out. They have great customer service. I'm not familiar with Rigid but it looks like your light is multifunction or is 2 separate lights made into one.
  4. Jan 9, 2020 at 7:00 AM
    CorsoTundra
    North GA
    okay.
    Thanks
  5. Jan 9, 2020 at 7:01 AM
    CorsoTundra
    North GA
    Thanks.
    I think you're correct. I believe that the Rigid symbol in the middle of the light, lights up as well.
  6. Jan 9, 2020 at 7:03 AM
    CorsoTundra
    North GA
    This is the one I have......
  7. Jan 9, 2020 at 8:22 AM
    shellshock
    Iowa
    2019 TRD PRO
    Looking closer at the first picture you posted, there are 4 wires going to the light - I only saw 2 when I first looked so I was confused.
    It’ll be 2 positive and ground wires. Depending on how it is switched, you could hook each one to a switch on the Spod, or connect them both to the same switch if you don’t care to control them individually.
  8. Sep 22, 2020 at 5:32 PM
    Matthewkort
    Matthewkort New Member
    I’m just trying to see pics of that bar! Haha how u like it?
