Griot’s 3-in-1 Ceramic Wax Review
Discussion in 'Detailing' started by War Machine, Jun 15, 2020.
  1. Sep 22, 2020 at 10:57 AM
    #151
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Yup, love me some beadmaker. Once that runs out though, I'm trying the griot's 3 in 1. Longevity is the grail.
  2. Sep 22, 2020 at 3:51 PM
    #152
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    That's what I bought a nanoskin fine grade also my eyesight is shot as well so should be good.:thumbsup:
  3. Sep 23, 2020 at 11:56 AM
    #153
    infamousavi
    infamousavi New Member
    Great review and Feedback from other members is a plus. ill be trying this out!
    War Machine[OP] and jpod like this.
  4. Sep 24, 2020 at 5:29 AM
    #154
    FirstGenVol Brake Czar
    2002 AC
    We just got our first rain since I applied the 3-in-1. I'm really impressed with the hydrophobic abilities.
    War Machine[OP] and ToyoMafia like this.
  5. Sep 25, 2020 at 11:13 AM
    #155
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Picked it up yesterday. If it's cool and dry enough next weekend, I'm going to apply it.
  6. Sep 27, 2020 at 5:10 AM
    #156
    War Machine
    War Machine [OP] SSEM # 5 3MW
    Ok, daughter came home for the weekend. First time her Tundra has been here since mid August. I washed it yesterday, and the Griots 3-in-1 has pretty much worn off. Last time I washed it was in early August, and it was still holding up at that point.
    Since the truck hasn’t been here for about six weeks, I’m not sure exactly when it failed. I originally applied it in mid March, and it was still protecting at the beginning of August. I can safely say I got 5 months of protection from the product.
    Five months through the hottest part of the year here in Texas is pretty damned impressive. Also, I only did one coat instead of the recommended two, and didn’t do anything to maintain it in that time. That’s one coat, no maintenance other than washing with Reset. Had I used 2 coats, then used it as a drying aid on occasion, I assume it would have lasted a good bit longer.
    I went ahead and reapplied 3-in-1 to the truck yesterday. Not sure if I’ll go ahead and add a second coat or not.
    Note: Yesterday the weather was in the mid 70’s, no humidity to speak of. I had zero issues with streaking.
    FirstGenVol, GODZILLA, jpod and 3 others like this.
  7. Sep 27, 2020 at 5:27 AM
    #157
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    I really like hearing about the length of time it still gives you protection. Put on 2 coats last week and hope to add 1 more coat before it get too cold. Not sure if I will be able to put on a coat once we get into winter. Today is Fluid Film day.
    ToyoMafia and War Machine[OP] like this.
  8. Oct 4, 2020 at 4:01 PM
    #158
    Piney
    Piney New Member
    2020 MGM TRD Pro
    Easy, peasy.......
    Here's my result in one coat. New paint and it popped.
    I'm sold. This stuff is the real deal.
  9. Oct 5, 2020 at 10:21 AM
    #159
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    curious if anyone has tried Griots 3-in-1 on their tonneau cover? I have the Bakflip Revolver X4 (matte finish) and right now have 303 on it but wonder if the longevity of 3-1 will work with the vinyl overlay
  10. Oct 6, 2020 at 3:42 AM
    #160
    War Machine
    I haven’t tried it on my Bakflip, but no other product of this type has held up on mine. (I have an MX4 though, not a Revolver.)
    I did one little spot on mine with Cerakote to see how it will hold up. It’s been a couple of weeks and it seems like it’s going to work. Only problem is it will probably take a whole pack of them at least to do the whole thing.
    itsmerh85[QUOTED] and ToyoMafia like this.
  11. Oct 7, 2020 at 8:50 AM
    #161
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Ok! I'm in!
    AutoGeek 25% off this morning. Ordered a gallon of 3-1 and a gallon of Bead Maker.
    rv740, War Machine[OP] and ToyoMafia like this.
  12. Oct 10, 2020 at 11:25 AM
    #162
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Maybe I've missed something here (and I'm a newbie) but how do you use the 3n1 as a drying aid? I used the product the 1st week of September after reading all of these post and have been impressed.
  13. Oct 10, 2020 at 12:51 PM
    #163
    War Machine
    When you wash the truck, just lightly mist the product on the paint while it’s still wet. Then just dry as normal.
    GODZILLA likes this.
  14. Oct 10, 2020 at 1:17 PM
    #164
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I have done this. Just make sure it’s not to hot out.
  15. Oct 12, 2020 at 8:44 AM
    #165
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    Another dumb question: I just clayed my wifes new to her Pilot. Should I wax and then treat with the Griots 3n1 or just do the 3n1 only? The car will be sitting in the garage for at least 4 more days.
    The 2018 was bought used and it does not look/feel/bead water like it has had either in some time.
    ToyoMafia likes this.
  16. Oct 12, 2020 at 8:58 AM
    #166
    ToyoMafia
    Magic carpet.
    No wax. Did you wash after clay? You want the surface as clean as possible. Wipe it down with some alcohol and water mix first (presuming you don’t have CarPro eraser)
  17. Oct 12, 2020 at 9:16 AM
    #167
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    I washed and rinsed. Clayed with (Mothers speed clay 2.0) using fresh car soap/water mix for lubricant and then rinsed and dried. Did that for each panel. So I still need to wash again?
  18. Oct 12, 2020 at 9:18 AM
    #168
    ToyoMafia
    Magic carpet.
    You should be good. Just give a wipe down and she’s ready.
  19. Oct 12, 2020 at 9:20 AM
    #169
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    Will do the alcohol water mix wipe down 1st. Thanks for the speedy replies. Have a excellent day.
  20. Oct 12, 2020 at 11:47 AM
    #170
    briarpatch
    briarpatch New Member
    So....update on my 3 in 1 experience. My daughter was home from school this past weekend, and she was quick to tell me how dirty her car is. Saturday morning it found itself in the wash bay. Griots was applied in August. Basically, two months later, the protection is still holding up, but not as strong as I would have thought for a car that spends its life in a parking garage, and really isn't driven that much. This was the first application where I've really had time to assess it's longevity. In fairness, it has not been washed since she returned to school in late August, but I was expecting a little better than what I saw.
    Perhaps it was my application process, I don't know. I've used it on some customer's cars......let's see how it does on theirs.
    War Machine[OP] likes this.
  21. Oct 13, 2020 at 5:23 PM
    #171
    Taco-Blender
    AZ
    2010 DC 4x4
    Had a little visit from the AutoGeek fairy this evening.
    If we ever get below a 100 friggen degrees I'll give it a go :mad:
  22. Oct 13, 2020 at 5:29 PM
    #172
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Come on up to Wyoming. I'll let you test it on my truck! :p
  23. Oct 14, 2020 at 5:46 AM
    #173
    War Machine
    Pretty much the same situation for my daughter but I got better performance. I wonder what factors could make such a difference? I doubt it was your application process, you definitely know what you’re doing.
  24. Oct 14, 2020 at 8:47 AM
    #174
    briarpatch
    It got no boosters after this wash....I want it to stand by itself and see what it looks like the next time I see it. I'm thinking that my application may have been a little light....due to the heat and humidity when I applied it. Time will tell. I still think it's an outstanding product.
  25. Oct 14, 2020 at 8:51 AM
    #175
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Picked up some 3 in 1 the other day at Autozone. Can this be applied over a wax? McGuire's Tech wax? Or do I have to strip it off?
  26. Oct 14, 2020 at 9:39 AM
    #176
    ToyoMafia
    Magic carpet.
    No sir. Get that wax off the truck or wait till it’s about gone then prep and seal.
  27. Oct 14, 2020 at 10:21 AM
    #177
    War Machine
    You can, but it probably won’t last very long. It’s best to do a paint decon anyway if you haven’t. That will take the wax off.
  28. Oct 14, 2020 at 10:22 AM
    #178
    War Machine
    I didn’t boost hers either. It’s probably the truest long term test I’ve done. I applied it in March, so heat wasn’t bad. Actually suspected I used too much at the time also, so that may be a factor.
  29. Oct 15, 2020 at 5:07 AM
    #179
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    2 coats of 3-1 separated by 24 hrs. My first time using. Easy to apply and easy off, I did the wheels as well. What helped for me was using several mf towels, as once one got too saturated it became harder to wipe off. I'm hoping this will provide good winter protection. I intend to use turtle wax ceramic wet wax as a drying aid when I wash.
  30. Oct 15, 2020 at 8:42 AM
    #180
    briarpatch
    Looks good. I've seen other people actually use the 3 in 1 as a drying aid...not tried that myself yet
    YotaFan05[QUOTED] and jpod like this.
