Victory Roof Rack Safety Warning (please read if you have an over-cab rack)
Discussion in 'General Tundra Discussion' started by TwoWheels, Aug 14, 2020.
  1. Aug 21, 2020 at 9:59 AM
    #121
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Looks like they are sending him a new bumper. At least that’s what I gathered. Still a pain in the ass to even have this happen with such an expensive item.
    rmvcard0303 likes this.
  2. Aug 21, 2020 at 10:09 AM
    #122
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    I meant the vehicle manufacturer, not the maker of the parts. Sorry for the confusion.
    As to the rest of your statement, we have already had this argument in previous posts.
    And yes, Victory should probably idiot proof the process going forward.
    Sunnier likes this.
  3. Aug 21, 2020 at 10:26 AM
    #123
    Hurricane
    NC
    2017 White 1794
    None
    So now you are the gatekeeper for me being able to give my opinion on a public forum?
    Take your own advice and kick rocks.
  4. Aug 21, 2020 at 10:27 AM
    #124
    TwoWheels
    TwoWheels [OP] New Member
    AZ
    2016 Tundra Crewmax
    BDS4.5 CO, BD ONX6 40, Transfer Flow Tank, Firestone Airbags, Softtopper, BedRug, TRD Grill, Datinfab Bedrack, Victory Roofrack, Hushmat, SDHQ Rocksliders, SDHQ hidden lightbar, BajaDesigns Squadron fogs, Method 18s, Falken Wildpeaks
    If you choose not to follow manufacturer’s instructions, or use their supplied tools, I could envision a stronger argument for the manufacturer to claim no-fault in the event of damage.
    I don’t actually believe its possible to drill these holes with the supplied tool and only penetrate 1/2”.
    I used drill oil and was VERY patient allowing the bit to cool every 5 seconds or so. The layers of sheet metal force you to keep the bit speed up, otherwise the bit ceases.
    The hardness of the welded metal layers require decent pressure to make progress vs just heating the bit. I would guess each hole took 10 minutes. I completed them over two work periods and several battery changes on the drill.
    The instant you penetrate, the supplied bit threads the hole and you react as quickly as possible to prevent that. As shown in the video - what might “seem” like 1/2” is much more after further inspection.
    I realize there is some “idiot” subtext here, but sometimes things may not be as easy as they appear...and you have no firsthand experience with this.
    With a different tool and/or procedure, stopping the drill @ 1/2” is certainly possible.
  5. Aug 21, 2020 at 10:49 AM
    #125
    timsp8
    NY
    I see the update now. Missed it earlier.
  6. Aug 21, 2020 at 11:09 AM
    #126
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    This statement here says everything. You're wrong. The issue is, you don't know how to properly use the tool or even clearly understand how a drill bit works. Its easy to blame someone else.
    300BLK likes this.
  7. Aug 21, 2020 at 11:13 AM
    #127
    Hurricane
    NC
    2017 White 1794
    None
    Not calling you an idiot, btw.
    Although, a drill stop is pretty easy to use.....:D
    personally I would have grabbing different drill bits, a stop, and probably a good cutting oil. Apparently since I haven’t modded my truck though I shouldn’t have an opinion here.
    Hopefully Victory and you can come to a conclusion that works out for everyone.
  8. Aug 21, 2020 at 11:18 AM
    #128
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    sorry to hear of the troubles. maybe the installer in that pic was using a shortened bit? that's possible. a drill stop definitely would be good.
  9. Aug 21, 2020 at 11:24 AM
    #129
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    Let’s get serious here. If anyone in this thread is saying they have never over drilled, over penetrated a hole while drilling with a hand drill they are lying or haven’t drilled enough holes to have made a mistake. Everyone is human. Should a drill stop be suggested or even included in this kit since the design allows the installer to possibly over penetrate and strike an airbag, yes. As for Victory's involvement in this thread, they are aware because they posted earlier. I would think they should be a little more concerned about what there customers are saying. I will remember this thread when purchasing parts made by a fabrication company that I put on my truck. Just my .02 cents, carry on
  10. Aug 21, 2020 at 11:25 AM
    #130
    TwoWheels
    AZ
    2016 Tundra Crewmax
    TaquitoBandito and Tundyfundy like this.
  11. Aug 21, 2020 at 11:30 AM
    #131
    rockmup
    rockmup New Member
    Todd
    I'm not sure what the picture is supposed to represent. I also want to be clear, I'm not bagging on you at all.
    AggiePhil likes this.
  12. Aug 21, 2020 at 11:39 AM
    #132
    TwoWheels
    AZ
    2016 Tundra Crewmax
    Did you watch the install video?
    Tundyfundy likes this.
  13. Aug 21, 2020 at 11:49 AM
    #133
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    That’s A picture of the install video putting the whole drill bit in!
  14. Aug 21, 2020 at 11:54 AM
    #134
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Ah no, you're wrong. With the supplied bit you have to put a lot of pressure to get it to work - as shown in their install video. Without a drill stop - which was not provided or even recommended - it is damn near impossible to stop the bit after only 1/2". This process requires a drill stop, not just a piece of tape marked out at 1/2". Many I bet are like myself who don't own a proper drill stop, I'd just have to wrap the thing up with a crap load of tape to make it thick enough to not go past, something I thought would not have been necessary based upon their video.
  15. Aug 21, 2020 at 12:00 PM
    #135
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    And to think this probably could have all been prevented with a $4 set of drill stops.......Victory should recommend this be used in their instructions is the only argument I see....or recommend you drop the headliner and through bolt it....or include the stops. Either way, I have no interest in adding a roof rack to my truck so this doesn’t really apply to me.
  16. Aug 21, 2020 at 12:12 PM
    #136
    rockmup
    rockmup New Member
    Todd
    Again, from this statement you do not know how to use a drill bit correctly or even drill a hole.
    This project is for DIY people and if you buy the product you are taking responsibility that you have a basic understand of how to accomplish it.
    If the instructions tell you to only go 1/2" deep but you watch the install video and see them sinking it all the way to the chuck, you should have had concerns which should have made you ask questions. Pretty simple
    It doesn't require a drill stop. Plenty people with experience could do this job with out one, would it make it simpler for you ? Maybe, what if the stop moved ? They do that a lot and need to be checked after every hole, would you know to do that ?
    I'm not trying to bag on anyone but get tired of hearing people blame everyone but themselves when things go sideways.
  17. Aug 21, 2020 at 12:31 PM
    #137
    TwoWheels
    AZ
    2016 Tundra Crewmax
    In the install video, the installer states that the holes are drilled in safe zones away from airbags (as stated throughout this thread).
    Are you of the opinion that the customer should not trust that information when doing the install? And if they do trust that information, its their fault that they damaged airbags?
    The screenshot shows that even the manufacturer can’t keep the bit from penetrating beyond their recommended depth. It appears they do, until you go frame by frame in the video (which you may want to watch and listen to). So you expect the customer to be more proficient than the manufacturer?
    This thread was not here to blame anyone. If you read it in its entirety, I think you’ll see that.
    Personal abilities and the arguments of drilling excellence aside...some folks are going to have damaged airbags and they outta know.
    Warreng, Bob_Wiley, GODZILLA and 7 others like this.
  18. Aug 21, 2020 at 1:23 PM
    #138
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    I’m only here to acknowledge your awesome username and avatar, and to point out that if you reply to this comment, you’ll have 666 messages.
    so wait, cutting corners IS the answer? My boss is gonna hear from me about his assessment of my work. I’ve been cutting corners forever.
  19. Aug 21, 2020 at 1:26 PM
    #139
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    :rofl::rofl::rofl:
  20. Aug 21, 2020 at 3:41 PM
    #140
    Cthulhu
    I had a really bad day and your post just made me laugh, both on the signature count and cutting corners comments. Thank you SO MUCH for that much needed comic relief!!
    Username is my gaming handle from at least 20 years ago. Avatar is Cthulhu, as I’m a huge fan of Lovecraft’s work.
    And here is my baby photo if you’re interested:
    :headbang:
  21. Aug 21, 2020 at 3:49 PM
    #141
    KevinK
    Tundras to Sedona
    here’s yer sign
    GODZILLA, Sunnier and joonbug like this.
  22. Aug 23, 2020 at 7:07 PM
    #142
    mkeCraftsman
    mkeCraftsman New Member
    Milwaukee
    08 SR5
    I’ve been looking at these for a few weeks, and noticed / laughed when watching the install video and the drill was punched all the way in. I considered buying these because the DIY process didn’t look crazy, and the installer claimed he was drilling into a safe zone.
    Thanks @TwoWheels for the information.
    It would be nice if everyone could just note the information and move on.
    For those who’ve installed already it’s great information.
    For those yet to install it’s a solid warning.
    For those just trolling, Hope it was enjoyable.
    It’s also worth noting @Victory4x4’s response. I value a company’s customer service more than their products usually. Noting the problem and updating information seems like a small thing to do to keep customers safe and happy.
    All the best
  23. Aug 23, 2020 at 7:28 PM
    #143
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    That's a quality first post.
  24. Aug 25, 2020 at 8:33 PM
    #144
    TwoWheels
    AZ
    2016 Tundra Crewmax
    Any word on repairs/cost?
    Cthulhu and Tundyfundy like this.
  25. Aug 26, 2020 at 12:58 PM
    #145
    Poormantrdpro
    Poormantrdpro New Member
    2020 Tundra tss off road
    Dang .... I was just about to order there roof rack . Thanks for sharing , Probably just get a prinsu now
  26. Aug 26, 2020 at 1:16 PM
    #146
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got no bad things to say about victory 4x4. Have the blitz bumper and their rock sliders. On the sliders, they notified me of a hole that needed to be widened, offered a discount or a swap for newer ones. I took the discount because easy enough to widen a hole. I think they’ve been great.
    As far as install goes, it’s your truck, you mess something up it’s on you. If they install and mess something up, it’s on them. It’s not the fabricators fault for mishaps, it’s the installers. If they say don’t go past 1/2” and you do...... it’s on you.
    Hurricane likes this.
  27. Aug 26, 2020 at 1:20 PM
    #147
    fisherman951
    Tony
    2017 crewmax 4x4
    did U happen to watch the install video?
  28. Aug 26, 2020 at 1:24 PM
    #148
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    ...or read where OP said 50 times that instructions said it was a "safe zone" ?
    Poormantrdpro likes this.
  29. Aug 26, 2020 at 1:28 PM
    #149
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    No, I haven’t , and I haven’t purchased that product. But I also know how to fab stuff, drill stuff, measure 2x before cutting. I’ve messed up plenty of times on my own to know better than blaming someone else for something. I take instructions more as a guide than a bible. I use my own knowledge, learned the hard way, to do do installs and fabrication.
    ultimately, it’s your vehicle. You want to cut or drill on it, cool. It’s yours.
  30. Aug 26, 2020 at 1:29 PM
    #150
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
