Victory 4x4 Strike parking sensor fitment issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yoder18, Jun 3, 2020.
  1. Jun 3, 2020 at 6:06 AM
    Yoder18
    Yoder18 [OP] Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Has anyone bought the victory 4x4 strike bumper and had fitment issues with the sensor holes? The stock bumper is 13/16” x 15/16” and the strike bumper is just a round 13/16” hole. I’d hate to cut into it and jeopardize the powder coat flaking sooner than later. I even tried sanding them down but can’t go much further without breaking the outer casing of the sensors. Tia
  2. Jun 3, 2020 at 8:40 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Do not have one and have never pulled out a sensor. Question i have is does the 90 deg angled piece disconnect from the outer round sensor?
    If so then the diameter of the round sensor might be correct.
  3. Jun 3, 2020 at 9:05 AM
    TXTundra2722
    2015 Black Tundra
    True...I don't have that either but this looks like it should disconnect.
  4. Jun 3, 2020 at 9:23 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
  5. Jun 3, 2020 at 9:26 AM
    timsp8
    NY
    I just switched my sensors to a Fab Fours bumper and they were tight. The angled part does not disconnect from the round part. It has to go through the hole as one piece, then it connect back to the wire.
    I think you are going to have to drill the hole. Is the issue on both sides? One of mine fit perfect, but the other side pulled the sensor in when i put the white plastic holder back on. Not sure why it didn't fit right, but its in the hole and works.
  6. Jun 3, 2020 at 9:40 AM
    Yoder18
    Mitch
    Ya it doesn’t I tried last night and ended up taking a belt sander to it to see if I could get it in that way w no luck.
    Yep going to have to drill the hole is what it’s looking like. Ya both sides are 13/16” perfectly round while the sensor holes on the bumper are not. Iv got the white clips ready for when I can get them back in. Thanks for the reply gents!
  7. Jun 3, 2020 at 11:38 AM
    csuviper
    Broomfield, CO
    Use one of these
    ZappBrannigan and CavalryCrew602 like this.
  8. Jun 3, 2020 at 12:59 PM
    timsp8
    NY
    Don’t go too big. The ovalish hole helps hold the sensors. Did you contact victory 4x4? You can’t be the only one with this issue. Now you have to drill on your new bumper.
    mountainpete and Stroke250 like this.
  9. Jun 3, 2020 at 2:02 PM
    Yoder18
    Mitch
    Yep I contacted them and they are looking into it. To be honest I’m pretty upset about it. The last thing I want to do is drill holes in my new bumper and risk the finish. They advertise it fits the front sensors and his video shows it does perfectly but mine definitely do not match what they are advertising. Wouldn’t have gotten this bumper if I would have known the sensors wouldn’t work w it.
  10. Jun 3, 2020 at 2:14 PM
    timsp8
    NY
    Take some pictures of it not fitting before you do anything. That way if it gets messed up you can prove it was still from a manufacturing defect. Or if there was any warranty or anything.
  11. Jun 3, 2020 at 2:16 PM
    Yoder18
    Mitch
    Yep definitely will get some after work. Will take what the stock looks like compared to the one they sent. Holes don’t match up whatsoever. Thanks for the input timsp8 I appreciate it
  12. Jun 3, 2020 at 3:53 PM
    Yoder18
    Mitch
    2 totally different holes
  13. Jun 3, 2020 at 6:09 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Did it come coated ? Take a file to it and open the hole up some, its not a big deal.
    At the very least measure your stock hole and the new one and see whee you're at.
    EDIT: yeh, thats not gonna work. You'll need to open the hole up to the same dims.
  14. Jun 3, 2020 at 6:32 PM
    Yoder18
    Mitch
    Yep came coated. If it wasn’t coated I’d be more open to it but I don’t want to have to re powder coat it if I don’t have to and I already paid for them to do it so ya that’s on them. Yep I’m going to test it out on a piece of wood to the dimensions it should be. 15/16 all the way around and see if it still fits. The stock bumper is not 15/16 all the way around so we will see.
    rockmup likes this.
  15. Jun 3, 2020 at 6:58 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I wonder if different bumper caps are different....someone posted some for sale and they look roundScreenshot_20200603-215639_Chrome.jpg
  16. Jun 3, 2020 at 7:39 PM
    Yoder18
    Mitch
    Wow that would absolutely suck if that’s the case. Maybe I should try and see if different sensors would work better. My caps are definitely different than those thanks for letting me know you saw these
  17. Jun 3, 2020 at 8:02 PM
    RollTide82
    Michael
    2019 Tundra 4x4
    Screenshot_20200603-230234_Chrome.jpg I assume the sensors cannot come apart any other way? I have never had mine out....they look as if the round part might can clip off...which would make it fit possibly
    PeakIT likes this.
  18. Jun 3, 2020 at 8:43 PM
    Yoder18
    Mitch
    Iv tried where the tabs are but they wouldn’t budge at all. Replacements are cheap so I still might try and tear one apart to see if I can get it to work that way
    better yet this pic shows that the tabs just hold the outer part and not the sensor itself. Will give it a shot in the morning
    PeakIT likes this.
  19. Jun 3, 2020 at 8:56 PM
    Yoder18
    Mitch
    Alright got the sensor ring off but it won’t fit in the hole without being drilled out. So the hole just straight up is too small even if I take the sensor apart
  20. Jun 3, 2020 at 9:02 PM
    RollTide82
    Michael
    2019 Tundra 4x4
    I would use the step bit as mentioned above and just paint around the edges with a small hobby brush...wouldn't think it would hurt the finish...anyhow I still would contact the company
    Yoder18[OP] likes this.
  21. Jun 3, 2020 at 9:08 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Before drilling anything I'd wait and see what Victory4x4 has to say..
    GODZILLA, Yoder18[OP] and Ely010606 like this.
  22. Jun 3, 2020 at 9:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2, definitely wait imho.
  23. Jun 3, 2020 at 9:24 PM
    Yoder18
    Mitch
    Definitely! Corey from victory got on it quickly now I’m just waiting for a response. I hope they can fix the issue so not all the bumpers going out are like mine.
  24. Jun 4, 2020 at 4:37 AM
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    I've noticed several threads lately with people having fitment issues on Victory4x4 parts... engine skid plate, rear diff skid and now the front bumper.
    I don't have any of their products, but they seem to be very involved, which is great. They really need to start working on testing and qc though...
  25. Jun 4, 2020 at 11:32 AM
    Yoder18
    Mitch
    Ya that’s unfortunate cause the company seems legit and yes super involved. QC would have been nice on this bumper!
  26. Jun 4, 2020 at 12:46 PM
    TheBeast The Beach
    they have a quick turnaround between R&D and production, it's got its pros and cons. They do have great CS in case of issues though.
    Luckydog likes this.
  27. Jun 5, 2020 at 4:37 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Don’t drill it...then it becomes your problem.
  28. Jun 5, 2020 at 4:52 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    Tell them to send you out a new one and I'll take your old one...lol
  29. Jun 5, 2020 at 9:37 AM
    Yoder18
    Mitch
    Couldn’t agree w that more. Definitely going to wait until they respond
  30. Jun 5, 2020 at 5:10 PM
    Yoder18
    Mitch
    Got the fogs installed and they are mean! Had to go through the fire wall which was a new one of me but was surprisingly easy and fun
