Truck cranks, runs for a few, the shuts off...2007 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by oldschoolhdmike, Jul 11, 2016.
  1. Jul 11, 2016 at 3:12 PM
    oldschoolhdmike
    oldschoolhdmike [OP] New Member
    mike
    2007 tundra crew max 5.7
    not much
    just got home from work and i go to hook up my camper and my truck cranks fine.....runs for about 5-6 seconds and shuts off. does it over and over and now wont even crank. fuel pump? thinking it may have been cranking and running on fuel in the lines? now there is now fuel it wont crank?
  2. Jul 11, 2016 at 3:29 PM
    oldschoolhdmike
    mike
    not much
    ok. i go out about 15 minutes later and it cranks and stays running. so?????? security cpu.....geez i hope not
  3. Jul 11, 2016 at 3:31 PM
    TheBeast
    TheBeast The Beach
    do you hear the fuel pump kickin in when you turn on the key ?
  4. Jul 11, 2016 at 3:36 PM
    oldschoolhdmike
    mike
    not much
    no but i has been running now for 10 minutes. turned it off again to try and hear the pump and i cannot hear anything....but it has been running now.....now i am afraid of getting stranded. a shop cant tell what it is doing if it wont do it. no check engine light is on
  5. Jul 11, 2016 at 3:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Could be electrical??
  6. Jul 11, 2016 at 4:08 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Fuel pump,relay to the fuel pump bad, crankshaft sensor not picking up.. or battery connections dirty not making solid connection..
  7. Jul 11, 2016 at 4:19 PM
    oldschoolhdmike
    mike
    not much
    fuel pump relay would be nice. but it wont be my luck
  8. Jul 11, 2016 at 4:26 PM
    LML 3500HD
    Total bummer.
    I would look at what @Mike suggested as well. Relays are cheap and easy to test.
  9. Jul 11, 2016 at 4:32 PM
    Mike Tread lightly.
    south carolina
    Rare relays go bad for no reason.. the Toyota fuel pump is a tough pump.. I have 280,000 on mine it's in my Tacoma tho..
    If you know how to use ohms meter. Check for continuity between ground and where the lead going to the fuel pump is on the relay side.. if it reads infinity pump is shot... if it reads continuity pump is good...
    ColoradoTJ likes this.
  10. Jul 11, 2016 at 4:36 PM
    oldschoolhdmike
    mike
    not much
    taking it to my buddy who is going to test that stuff tomorrow...he can also test fuel pressure.....guess i will know more tomorrow
  11. Jul 11, 2016 at 7:44 PM
    Hope its minor!
  12. Jul 12, 2016 at 12:25 AM
    4wd
    4wd New Member
    Doug
    currently truckless
    I don't know if Tundras use igniters but if so dbl check harness connections, they can seem tight but as I found out is not always true...
  13. Feb 18, 2017 at 4:59 PM
    Wes07
    Wes07 New Member
    Wes
    Colorado Springs
    07 tundra
    Reviving an old thread, my 07 5.7 does this almost weekly now but cranks on the 5th try every time. It has went into limp mode once after cranking it after driving it hard in an emergency. Would this be the aip or crank position sensor?
  14. Feb 18, 2017 at 9:09 PM
    Wes07
    Wes07 New Member
    Wes
    Colorado Springs
    07 tundra
    160k. I unhooked the positive battery cable and that cured the limp mode.
  15. Feb 25, 2017 at 3:14 PM
    Woodjb88
    Woodjb88 New Member
    2010 Tundra Crewmax
    Mine does this as well. (2010 platinum with 225kms)
    Mostly seems to be when there would be moisture around. Freeze/thaw/wash etc.
    But if I wiggle things around in engine compartment fuze block, it seems to start next try. I have been applying dielectric grease to connections but haven't narrowed it down to one place yet
    Interested to see if anyone else finds out anything
  16. Apr 11, 2017 at 11:57 PM
    M1khale
    M1khale New Member
    2008 Desert Sand Mica Crewmax TRD 4x4
    Custom Black Headlights / Taillights Amp Research Automatic Steps Transfer Flow 50 Gallon Tank Pro Comp Leveling Kit Slotted/Drilled Disk Brakes
    I have this same issue and I just unplug the positive battery for 15 seconds and she fires up every time took it to Toyota several times for this but they say they can't replicate it so I just carry a 10mm wrench on me to pull my positive and don't bother preset radio stations
  17. Apr 16, 2017 at 3:14 PM
    Woodjb88
    Woodjb88 New Member
    2010 Tundra Crewmax
    I've come to wonder with mine, that it may have something to do with the key...
    maybe not reading chip right...?
    Could ignition switch become worn and cause this somehow? My truck has almost 230000kms so likely has seen its fair share of use
