2020 Bed Extenders?
Discussion in 'General Tundra Discussion' started by Kung, Jun 2, 2020.
  1. Jun 2, 2020 at 8:05 AM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    So I guess I'd like a bed extender more than I realized...but everything I've read says 2019 or earlier. I'm pretty much DEAD sure there's been no differences between 2019 and 2020 but figured I'd hit the good people @ Tundras.com up before potentially making a mistake. Any thoughts?
    Also, any reason to go with an AMP Research over an OEM one?
  2. Jun 2, 2020 at 8:17 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    I went with the AMP more rectangular shaped one for my 20. I did go with the no drill bracket rather than drill holes. I believe the AMP bed extender is the same as OEM OEM is V shaped and uses the no drill brackets.
  3. Jun 2, 2020 at 8:33 AM
    Kung
    KG, VA
    Ok, good deal. And yeah, definitely would rather go with no-drill brackets. Do you still have to request them or is it an option when ordering?
  4. Jun 2, 2020 at 9:02 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I got the OEM one for my 2020, and I love it. The curved edges haven't bothered me much, but I guess I would prefer more boxed out corners. I didn't know there was a no-drill option for the AMP when I got mine.
  5. Jun 2, 2020 at 10:37 AM
    rebmo
    Rural SE Wisconsin
    Getting the no drill brackets takes a bit of extra effort but well worth it IMO. Talk to Ray at ElectricStep.com and me can help you with the No drill bracket parts and AMP extender. The AMP kit only is offered with the drill brackets so you need to get the brackets separately.
  6. Jun 22, 2020 at 7:14 AM
    SM 2018 1794
    SM 2018 1794 New Member
    I have a 2018 with the factory installed OEM one. The thing is great have used it more then i thought I would of. One good thing is that when I couldn’t use it for a load and had no place in the bed to put it after loading the bed up, I was able to lift up the rear seats and it fit just fine in the cab of the truck. Not sure if it was designed that way but it worked out great. Plus they are really easy to take in and out. Just make sure your tailgate is always locked to it doesn’t disappear.
    BlueSpartan1597 likes this.
  7. Jun 25, 2020 at 1:21 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    i like readyramp. bed extender and motorcycle ramp in one. utilizes tailgate latches so no drilling.
  8. Jul 5, 2020 at 4:24 PM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Does anyone know how these work with bed stiffeners? Any good combos?
  9. Jul 5, 2020 at 4:37 PM
    Can't be used with bed stiffeners.
    Joss1799 likes this.
  10. Jul 8, 2020 at 12:15 PM
    Redcon41318
    Redcon41318 New Member
    Any idea if the oem bed extender will clear a standard camper shell i have on my 19’ tundra.when i rotate the extender will it hit my camper shell?
  11. Jul 8, 2020 at 12:26 PM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    i like readyramp as well. bed extender and motorcycle ramp in one. Make the most sense to me.
    Have one of these and recommend. it folds down so its smaller easily fit in the back seat if needed. Doesn't permantly attach so its only when you need it and it works great on a motorcycle too. (just be careful on motorcycle street tires as i found on on a rainy day (pulled front brake and bike keep sliding). Not a deal breaker.
    https://www.amazon.com/ReadyRamp-I-...236292&sprefix=readyramp+bed+e,aps,521&sr=8-1,
    straps that hold onto the taligate latch points and straps that hoold to truck. Only thing missing was a tie-down to anchor it to the truck when used for motorcycle loading.
  12. Jul 8, 2020 at 1:20 PM
    Let's see the camper shell. I believe yes but would like to see a picture.
  13. Jul 8, 2020 at 1:33 PM
    If this is your Tundra it will clear.
  14. Jul 8, 2020 at 1:38 PM
    Redcon41318
    Thanks guys! That is my trophy truck! Minus the cooper tires i had shown on it, i had a horrible set! Tires wobbled and howled, made my $40k feel like a 40 yr old truck with half a mil miles on it.
  15. Jul 8, 2020 at 1:40 PM
    :thumbsup:
  16. Jul 8, 2020 at 3:11 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
  17. Jul 11, 2020 at 2:43 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I wanted a oem bed extender for my 2020 but was told I could not have it and the hard tonneau.
  18. Jul 11, 2020 at 3:43 PM
    Why? It fits way under the cover. I have mine under a soft tonneau cover.
    KingsAustin likes this.
  19. Jul 11, 2020 at 4:14 PM
    GCanuck
    Gary
    BC,Canada
    I want the hard tonneau. Dealer said I couldn’t have both installed.
  20. Jul 11, 2020 at 4:18 PM
    Redcon41318
    Full of chit
  21. Jul 11, 2020 at 4:19 PM
    I don't see how the hard cover would interfere.:notsure:
  22. Jul 25, 2020 at 9:01 AM
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    The hardcover may not hinge high enough to allow for 45deg install or maybe can’t flip into the bed to close the tailgate
  23. Jul 25, 2020 at 9:06 AM
    I'm not understanding your reply. The bed extender sits way below the cover or cover brackets. It works perfectly with my soft cover.
  24. Jul 25, 2020 at 9:12 AM
    kwebre
    kwebre New Member
    2020 Blck Tundra
    If the hard cover is the folding type I agree with everyone there is no reason it shouldn’t work. If its the solid fiberglass type it may not. I haven’t seen any video install with that configuration.
  25. Jul 25, 2020 at 9:16 AM
    kwebre
    kwebre New Member
    2020 Blck Tundra
  26. Jul 25, 2020 at 9:23 AM
    It fits under a Diamond Back.
    https://youtu.be/wCQzHOis-Bg
  27. Jul 25, 2020 at 9:54 AM
    GCanuck
    Gary
    BC,Canada
    Now that I have the factory hard tonneau I see why. They lowered the rail system to mount it by an inch or so.
  28. Jul 25, 2020 at 10:52 AM
    Can you post a picture?
  29. Jul 25, 2020 at 11:00 AM
    GCanuck
    Gary
    BC,Canada
  30. Jul 25, 2020 at 11:24 AM
    kwebre
    kwebre New Member
    2020 Blck Tundra
    I don’t see where that should matter. The Slide rail sticks out the same as the cover rail. I have the same setup and I am looking to purchase an extender. I will wait for the experts to comment.
