Let's see those Lawnmowers
Discussion in 'Home Improvement' started by Bob, Mar 22, 2017.
  1. Apr 1, 2020 at 7:42 PM
    #121
    MS22
    MS22 New Member
    02 Tundra 4x4
    I used to have a jx75! I picked it up at a yard sale for $150 and It was like brand new. Left it out one night and someone stole it. Hands down the best mower I ever had.
  2. Apr 1, 2020 at 9:14 PM
    #122
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    oh man that sucks! The Kawasaki engine with full pressure lubrication is great. Love how it has a blade brake clutch so you can run it without the blades on. Great mower! That is why I have 2! One is the newer style with the larger commercial Kawasaki in it.
  3. Apr 1, 2020 at 9:28 PM
    #123
    MS22
    MS22 New Member
    02 Tundra 4x4
    I had the older style, 1 pull and that thing would always start. Maybe it was the weight but that mower made an awesome cut. You have a nice setup.
    Rica25 likes this.
  4. Apr 1, 2020 at 9:45 PM
    #124
    Rica25
    Ricardo
    Tulare
    This works really well have had it for 12 yrs now
    WILLINH, GODZILLA, P-Factor and 4 others like this.
  5. Apr 1, 2020 at 10:50 PM
    #125
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Thanks Chris, appreciate it!
    ColoradoTJ[QUOTED] and Rica25 like this.
  6. Apr 6, 2020 at 12:06 PM
    #126
    Kung
    KG, VA
  7. Apr 6, 2020 at 12:39 PM
    #127
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    Retired cub cadet riding mower
  8. Jul 5, 2020 at 6:47 PM
    #128
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    Picked up a 2008 John Deere Z520A with the 7 Iron 60" deck for $500 from a kid who had seized the motor.IMG_20200531_151411.jpg
    Started looking around for a replacement motor and was told by multiple dealers that the complete motor is no longer available and all they could get was a short block for $750, which I would have to swap my existing head onto.
    I talked to a local guy who does small engine repair and he gave me the names of a couple companies that sell replacement engines. Sure enough, one of them, Small Engine Warehouse was able to cross reference the number and had a complete motor in stock for $869 that is the same 25 HP Kohler motor with the only difference being the new motor has the larger, commercial style air cleaner.
  9. Jul 5, 2020 at 7:10 PM
    #129
    SunTundra413
    Ned
    Massachusetts
    ARE Cap
    I removed the old motor and while I was getting ready to install the new one, I noticed a few parts that needed replacement so I got those from a local dealer. One was the pulley on the drive belt tensioner. Bearings were shot.IMG_20200704_110034.jpg
    The other part was the bell crank on the left side. Cast aluminum was broken halfway through.
    While I was at it, I also changed the oil and filters in the hydro transmissions. I figure it's cheap insurance since I'm putting a new motor on the machine.
    I'll post more pics when I finish installing the new motor. This should cut my mowing time considerably. I have about 2.5 acres of lawn to mow and mowing with my tractor with 42" deck takes forever.
    NewImprovedRon and jewsNbrews like this.
  10. Jul 5, 2020 at 7:14 PM
    #130
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Got an upgrade for Father's day. New Timemaster.
    camron1039, BIOHZRD, GODZILLA and 6 others like this.
  11. Jul 5, 2020 at 7:16 PM
    #131
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    How do you like it? I've been eyeballing one for a while as I want to go the electric route. How long does a charge last?
  12. Jul 5, 2020 at 7:24 PM
    #132
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I have a very small yard and the 40v Ryobi is perfect. Zero maintenance (ok maybe annual blade sharpening). The large capacity battery will power the mower, string trimmer, and have about 1/2 to 1/4 charge remaining on top of that
  13. Jul 5, 2020 at 7:27 PM
    #133
    Baja Mike
    South Bay, Ca.
    Yup, gotta get the trimmer too. And they gotta have the same battery. So, good to know. Thanks.
  14. Jul 13, 2020 at 4:13 PM
    #134
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Looking for a rider for my property. Mow about an acre of it. Had a used Cub LT1040 that ran ok but has a ton of hours on it and is jerry rigged together from the PO, i just got it super cheap. The stamped deck finally rusted completely through and one of the spindles is shot, not worth dumping money into. Looking at a replacement and was considering some older JD's with the cast iron Kohlers. Any suggestions? I was looking at a 314 and a 214. I mainly want something i can completely service myself and is very reliable.
  15. Jul 15, 2020 at 4:46 PM
    #135
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Just picked up this beauty today. So happy. :D
    Honda HRN 216. Not cheap, but buy once cry once eh?
    WILLINH, Sundog, 300BLK and 5 others like this.
  16. Jul 15, 2020 at 5:16 PM
    #136
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Picked this up a little over a month ago. Cub cadet 42in zero turn
    I like it. The 42 inch deck leaves a pretty good cut. Also does not bounce around like the 50 inch deck does. It’s a little twitchy on the right turns for some reason but I honestly think it’s the operator more than the mower lol
    61399B35-3037-4435-A187-6B79415E62A4.jpg 7C69FDB8-0750-41E1-8C03-A813401110F9.jpg 32A0A6D9-65A5-40CF-A5AC-45EAECB01DE4.jpg
  17. Jul 15, 2020 at 5:31 PM
    #137
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Nice just orders the Honda VersAttach thingy majjjiger haha. The one that has attachments like the hedge trimmer and weed eater
    Outbound[QUOTED] likes this.
  18. Jul 15, 2020 at 5:51 PM
    #138
    RLHULK
    Rich
    2022 Silverado LT.
    Yup I am. no problems runs great gives a pretty good cut.
  19. Jul 15, 2020 at 5:59 PM
    #139
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Leo wanted to drive the old Murray E77C3CD5-84C4-4325-A1EA-CB6C7BD3AE46.jpg Haven’t started it in almost two years
    A6D6B9B3-1554-456C-B9F4-07EFCFFED8A4.jpg Cleaned out the carb put in some fresh fuel and she fired up and ran pretty good it hunts at low rpm’s but it’s good enough for the kids to play around on
    I have him mow if he an attention span of more then 18 seconds
  20. Jul 16, 2020 at 5:18 AM
    #140
    Wahayes
    Will
    2017 tundra limited
    It lasts quite well. I have the 5ah battery and I can do my whole yard and usually have some left over for the trimmer. I have a ryobi trimmer 40v too.
  21. Jul 16, 2020 at 5:32 AM
    #141
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Times are getting tough around these parts.
  22. Jul 16, 2020 at 5:49 AM
    #142
    Skip_TRD_Sport
    Skip_TRD_Sport Less is More.
    2019 Cavalry Blue TRD Sport
    Westin Pro Traxx 4 Step Bars, Bed Mat, Color Matched Door Handles
    I got a sweet deal on this Honda Mower right after Christmas. I guess they phased out that model. $300 off!!!
    I use my Father in law's tractor to cut his grass.
    WILLINH, jewsNbrews, GODZILLA and 2 others like this.
  23. Apr 21, 2021 at 4:03 PM
    #143
    j_carlton
    j_carlton New Member
    Ann Arbor, Michigan
    2010 SR5 RCLB 4x4 5.7
    Scag V-Ride 60", which replaced the Land Pride 60" 3 Point mower behind it. The Scag mows so much faster, it's crazy.
  24. May 2, 2021 at 6:19 PM
    #144
    knoxville36
    Knoxville, TN
    Please excuse my mess in the garage right now, doing spring cleaning.....
    I have about 1/3 of an acre that is fenced in for dogs around the house. It is a little hilly in one small area and is a little rough. The bad thing about it is our gate is narrow. Not wood, it is metal and brick so not easy at all to widen it.
    It grows faster than any grass on earth as it has "natural fertilizer" from 3 dogs, haha. I could honestly mow it every couple days. Wife likes it bagged also since it is around the house. Takes forever with my little John Deere 21" mower. I still have my x758 for the rest of the yard outside of the fence.
    I fixed that today. I had a really simple Scag SW36 belt driven walk behind about 8 years ago and loved that thing. Sold it a while ago. Been looking and researching walk behinds for about a month now. Come to find out, they also are like Tundras right now and can be very hard to find. I found a dealer here in Knoxville that actually had a Ferris SW25 and Scag SWZT walk behind in 36" in stock. I have heard a lot of good things about the Ferris models and for the money you get a lot. Compared to the Scag I get 18 instead of 14.5 Kawasaki, electric start, better hydro/transaxle. Scag is a Scag though. I rolled the dice and went with the Ferris. Mowed for first time tonight and it is a great machine!!! Took like 1/10 the amount of time to mow our fenced in area, haha.6B1AD11D-DDE4-4879-BB66-DFAF73396CDB.jpg34F9B734-78D8-45E6-B2CD-4B1BBBFB1481.jpg3566F406-3311-48AC-908B-88330EE2C851.jpg
  25. May 2, 2021 at 6:38 PM
    #145
    BIOHZRD
    BIOHZRD New Member
    Gary
    2020 TRD Pro, Army Green
    Linex bed, running boards
    I have used Lawnboys in two stroke for years and years.........can't kill 'em. But I'm 70 now and the boss (GF) asked me if I wanted a Zero Turn for our postage stamp sized yard on Cape Cod. Curiosity made me say "yeah", so she bought me a John Deere Z335 E. Now I mow twice a week, just to keep it manicured. I'm old and lazy. What can I say.
    NewImprovedRon and Leo's first like this.
  26. May 7, 2021 at 9:31 AM
    #146
    300BLK
    300BLK New Member
    Picked up this low hour X500 with a 54" deck and cart a few weeks ago. My first "real deal" JD. Previously had a box store cub. What a difference. New fluids and a detail and it runs fantastic.
  27. May 7, 2021 at 11:15 AM
    #147
    TNCountrygal
    TNCountrygal New Member
    Lenoir City, TN
    2014 MGM 4X4 1794 Tundra
  28. May 7, 2021 at 11:29 AM
    #148
    War Machine
    War Machine SSEM # 5 3MW
    Y’all’s lawnmowers are filthy.
  29. May 7, 2021 at 12:05 PM
    #149
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I like your tire shine. What brand is it?
  30. May 7, 2021 at 12:31 PM
    #150
    War Machine
    That was Mother’s Speed Tire Shine.
