Fox TRD Pro or Fox 2.5 Resi system
Discussion in 'Suspension' started by 2019-1794, Jun 28, 2020.
  1. Jun 28, 2020 at 11:35 AM
    2019-1794 [OP] New Member
    2019 1794 Crew Max 4x4
    Need some pros and cons on each one of these. Can get the Pro Fox suspension for about $3K and can get the Fox factory 2.5 front and rear resi suspension for around $2300..... both get about 2” of front lift.....Any advantage of getting Fox factory over the Pro suspension besides being rebuildable? Thanks
    Rica25 likes this.
  2. Jun 28, 2020 at 11:44 AM
    art64
    art64 New Member
    Fox factory with resi is rebuildable, tunable. If you get the ones with DSC that'll even be better. TRD Pro is not rebuildable or tunable and we don't know for sure how long Toyota stock those as replacements. On the other hand, TRD Pro shocks are tuned specifically for the Tundra. And lastly, cost.
  3. Jun 28, 2020 at 1:16 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I do believe that the TRD Pro fox suspension is in fact rebuildable and can be sent in to fox.
  4. Jun 28, 2020 at 2:17 PM
    SM 2018 1794
    SM 2018 1794 New Member
    Yes I called FOX factory and the TRD PRO shocks are rebuildable by FOX. The tech i talked to really liked the shocks and did say Toyota tuned them just for the Tundra. He also said FOX may start copying the design for some of there other shocks.
    I just purchased a new set of the TRD PRO shocks and installed them on my 2018 1794. I have put about 200+ miles on them, on the road and off as well as mountains. I like them and you can actually feel them working. I do still have my rear sway bar attached and may see how it feels without after I disconnect it.
    The factory TRD PRO fox shocks work with the factory upper control arms on every other Tundra. I wasn’t going to be doing serious rock climbing or off-roading every weekend so adjustability really didn’t matter to me. Set it and forget it.
  5. Jun 28, 2020 at 2:21 PM
    Do you have any pics of your 1794 with the TRD Fox setup?
  6. Jun 28, 2020 at 3:22 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I would not pay more money for trd pro shocks that have less capacity for cooling.
    Bigger for less money? Yes please.
    Inquiringone, snivilous and 300BLK like this.
  7. Jun 28, 2020 at 4:04 PM
    SM 2018 1794
    Yes here are some pics after the install.
    AggiePhil, Wes_heppy, DIYDad and 9 others like this.
  8. Jun 28, 2020 at 4:37 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Did you need to have your radar recalibrated after the install?
  9. Jun 28, 2020 at 5:01 PM
    SM 2018 1794
    Actually no. I checked the use of the lane assistance and that worked, the assistance braking seems to work since it did go off once.
    The only I didn’t check was the cruise control but really I’m only sitting a couple inches taller so I really don’t think there will be any issues. Other have said they have had no issues as well.
    jtwags likes this.
  10. Jun 29, 2020 at 5:52 AM
    monaco730
    16 Inferno Tundra
    I have fox 2.5 up front and fox 2.0 in the back. I love my setup. My brother just got a 2019 pro with the fox shocks and it felt really nice. Can't go wrong with either.
  11. Jun 29, 2020 at 3:46 PM
    Gmanii
    Gmanii New Member
    Gmanii
    2019 CM Platinum SSM
    How difficult was the install of the TRD Pro?
  12. Jun 30, 2020 at 11:22 AM
    What are your measurements with the TRD Pro kit?
  13. Jun 30, 2020 at 11:54 AM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    I WOULD GET THE pRO SHCKS JUST BECAUSE THEYRE FRICKIN SICK DUDE!
    TelemarkTumalo and 2019-1794[OP] like this.
  14. Jun 30, 2020 at 12:22 PM
    SM 2018 1794
    To install the kit you will need to drop the lower control arms and make sure the (R) and the (L) on the springs are lined up with the notch on the upper control arms spring cup.
    The rears just bolt up pretty easy. You will need to get the TRD FOX speed sensor bracket. I actually have the rear TRD rear sway bar installed and the one legs on the bracket needed to trimmed a little to fit over the sway bar u-bolt.
    I may be removing the rear sway bar so I I purchased two brackets.
  15. Jun 30, 2020 at 12:23 PM
    SM 2018 1794
    YES THEY ARE!!!!!!! Now looking for a set of the PRO Rims.
  16. Jun 30, 2020 at 12:24 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    24 Camaro SS 6.2 Liter Loaded
    To much to list:)
    Genuine Toyota Tundra TRD PRO Fox Suspension Kit PTR61-34190
    From Elmhurst Toyota an Authorized Toyota Dealer
    $2,941.11Free Shipping
    Est. Delivery Tue, Jul 7
    NoRcptn likes this.
  17. Jun 30, 2020 at 12:25 PM
    SM 2018 1794
    I need to find my notes of before and after the TRD FOX shocks install and I’ll post them.
    The trucks front end definitely came up. I m thinking about 2” in the front.
  18. Jun 30, 2020 at 1:21 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Found this on OfferUp.. maybe someone local (SoCal) is looking for a set. Not Mine
  19. Jun 30, 2020 at 1:45 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    i went with fox 0-3" ultimate stage 4 kit. currently sitting at 4/2. ride is fully hand/knob tunable. no tools. better than stock ride when i want it to be, fully offroad capable when i want it to be. maybe overkill for what you want tho.
  20. Jul 3, 2020 at 5:44 AM
    I got a even better deal on the Fox TRD’s than I originally found and went ahead and ordered them.... I’m thinking about installing the Westcott spring collars in them before i install them to add slightly more lift
    Thanks for the helpful replies folks
    AggiePhil likes this.
  21. Jul 3, 2020 at 10:31 AM
    SM 2018 1794
    Cool 2019-1794 you got them on order? Did you order the sensor mount as well?
    Take the measurements of your truck in different areas before the install then after. I’m still looking for the paper I wrote mine down on and I’ll post them.
    Let’s us know when they arrive.
  22. Jul 3, 2020 at 10:49 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
  23. Jul 3, 2020 at 1:37 PM
    yes I ordered them from a Toyota dealership... I’ve got 5100 on middle setting right now I’ll do a before and after measurement.... it looks like the speed sensor bracket it isn’t really needed but I ordered it anyways... looks easy to install.
  24. Jul 3, 2020 at 2:26 PM
    SM 2018 1794
    I attached some pics of the speed sensor bracket. It basically extends the original on the truck. Mine had to be trimmed due to rear swaybar.
    ryanwgregg and 2019-1794[OP] like this.
  25. Jul 3, 2020 at 3:21 PM
    2019-1794
    That looks simple enough! What size tires are you gonna try and run? You have anymore pics of your truck with the pro suspension?
  26. Jul 3, 2020 at 3:56 PM
    SM 2018 1794
    I’m still thinking about the tires sizes and rims. I really like the 2019-2020 PRO rims. So I’m thinking maybe a 275/65/18 think I’ll just need to remove the little wind guard from the front????
    Right now I’ll be paying off my shocks so I’ll have to run the stock ones for a while.
    What about yourself for tire and rims?
    I’ll have to take some pics and upload them.
  27. Jul 3, 2020 at 4:20 PM
    2019-1794
    If I can find TRD Pro wheels for a reasonable price, like $1500 or so I plan on running the 295/70/18 but more than likely stick with the 20” stock wheels and hopefully run a 285/65/20.... I’m on 275/65/20 right now with no rub... I also have removed the front flap and bent the skid plate slightly.
    AZCementTundra likes this.
  28. Jul 3, 2020 at 4:27 PM
    SM 2018 1794
    I’m looking for around the same price for the Pro Rims. I see a lot posted but over $2000 can’t do that right now. The 295/70/18 sounds good however.
    Running the 20’s that size is good. I changed my skid plates to the RCI ones. Full engine, transmission and fuel tank. They sit back pretty good so I don’t have to worry about trimming those.
  29. Jul 25, 2020 at 7:49 AM
    2019-1794
  30. Jul 25, 2020 at 8:33 AM
    Kanobi13
    Kanobi13 New Member
    2019-1794[QUOTED][OP] likes this.
