Trailer maintenance
Discussion in 'Towing & Hauling' started by ColoradoTJ, May 7, 2020.
  1. May 7, 2020 at 10:24 AM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    LML 3500HD
    This thread is for buying/maintaining all trailers:
    -Travel Trailers/campers
    -Flatbed
    -Enclosed
    -Wood Deck/Metal deck
    -Boat
    We all buy trailers for work, play, or both. Regardless of size, build quality they will need continued maintenance. Depending on geographical location, some trailers will need more attention than others (salt, wet, snow, high heat, water for boat trailers).
    What do we need to do? Great question and hopefully this thread can teach us all new ideas and best practices.
    Brand new trailers:
    - When ordering/looking for a trailer, really sit down and think about the options you want and need. Adding them later can be difficult. Things to consider would be:
    1) Size. This right here has been my own personal nemesis. The tow vehicle often can dictate this decision. In the past 15 years, I have owned 4 flatbed trailers alone (7K, 10K, 14K, 14K). All these were due to size requirements for the most part...except the 7K. That one just fell apart.
    2) Capacity. This is probably one of the most important decisions you will make. Is this for personal use only, business, or both? Local laws should be researched and understood. Local DOT and Highway Patrol can point you in the right direction. There is nothing worse than getting pulled into a DOT checkpoint and getting the book thrown at you. This can add up to thousands in fines.
    Remember, not all states require both braking axles, so be cognizant when buying a trailer and ensure you are buying what’s needed.
    3) Use. What is the best trailer for your needs? (Majority of the time)
    4) Configuration. Tie down points, width, drive over fenders, removable fenders, adjustable coupler (size), wood or steel deck, ramp(s), lights (go LED, you’re welcome).
    5) Construction. What’s the difference in 4” C channel vs 5/6” C channel? Enclosed trailer siding thickness .024/.030/.040? I’m sure we have all seen the enclosed trailers that siding looks like a piece of aluminum foil that’s been crumpled up and attempted to make smooth again. Thickness matters.
    - Never assume everything is 100% completed.
    - Inspect very closely (welds, paint, wood decking, wiring, lights work, etc).
    - Read owners manual. Find out the options your specific trailer has and maintenance suggestions.
    - Take a grease gun when picking up the trailer for the first time (if the spindles have zirks). Put a couple good pumps in each. Most quality trailers have bearing buddy spindles and self adjusting brakes.
    -Warranties. Understand what you have, and get the best one you can afford.
    When you get home with the trailer:
    - Treat the deck. Trailer deck maintenance often gets forgotten. This is my new trailer, 2017 model that was never used or treated. Deck it not in good shape.
    Used trailers:
    What to look for is important. Here are some suggestions that might help later on.
    1) Overall condition. If the trailer looks like it wasn’t taken care of cosmetically, it most likely wasn’t mechanically.
    2) Decking. This can be a real pain to replace, and expensive. Regardless if you plan to do this yourself, it’s still expensive.
    Trust me, this sucks.
    3) Frame rust and weld condition. Research the manufacturer build quality. Not all trailer manufacturers are created equal, and in most cases you get what you pay for.
    4) Axles. This is a big one, especially with 3200 lb axles. Lots of times, these are purchased with the best of intentions, but often are overloaded. This is even a bigger issue when the trailer is a single axle. Look how bent the spindles/axle is? I followed this Tundra towing at 75 mph.
    This trailer most likely eats tires.
    Axles in good condition should have an arch in them like this:D5C48555-C4AF-460A-BB85-C8079B15947E.jpg
    When was the last brake shoe replacement? Bearings repacked? Receipts? If not, I would pull a hub to inspect. The seller might not want to do this, but if they want a sale and have done due diligence with maintenance there’s nothing to worry about. Look to see what new replacement bearing hub/brake assemblies cost x 4. Hubs, bearings, brake assemblies on my trailer are 205-250.00 each.
    Inspect the bearing cap, and rubber grommet. Tire shops beat these up a lot, but the grommets are very important. If you see cracks in the rubber, you can assume water got inside the hub.
    Good sealed up bearings with 15k miles on grease.
    Seal was cracked, water was obviously inside hub and bearings/races replaced. This trailer is 3 years old with only 600 miles on it. Luckily I brought a grease gun and pumped some good bearing grease inside to make the trip home (600 miles away).
    5) Coupler. Is it in good working condition? Grease inside or ran dry?
    6) Jack. Accidents happen and jacks are left down. Is the jack in good operating condition? Bolted on or welded? Replacement costs? Some jacks are 300.00 and then you need to cut the damaged one off, and weld a new one on. Then you have paint/Powder coating to deal with.
    7) D-Rings, stake pockets, tie down mounts in good condition?
    8) Safety chains. Have they been drug on the ground? Safety clips still work?
    9) Tires. There will be a lot of opinions about trailer tires. Some people I know that tow huge RV's never let their tires get 3 years old. Good rule of thumb is 3-6 years old. Personally, my flatbeds never last over 5. On the RV, every 3 years due to what is located right above the tires (refrigerator, hot water heater) and can cost thousands in repairs.
    Speed ratings. Buy the tires that have the best speed rating. My RV has ST tires that are rated to 75 mph and the flatbed has tires rated to 81 mph.
    Hightide, Sundog, Ruggybuggy and 10 others like this.
  2. May 7, 2020 at 11:20 AM
    LML 3500HD
    Opened for comments/suggestions. This is just a start, so share your experiences.
    Personally, I would like to learn more about boat trailers and enclosed trailers. I may be owning some of those in the future.
    Tundyfundy likes this.
  3. May 7, 2020 at 11:23 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I re-packed my bearings and adjusted my trailer brakes. It’s an RV so it also has other maintanence points such as replacing heater anode, oiling slides, ouling blades for tank emptying and rolling on a new rubber roof. Also there’s paint chipping at the trailer tongue so I’ll sand and repaint soon to prevent rust. Also make sure to check you suspension for leaks!
  4. May 7, 2020 at 11:24 AM
    Tundyfundy
    Bay Area, CA
    Also don’t forget about the module and cable that locks the brakes of the trailer runs away. Leaving your chain down is very dangerous as if it snags it will pop the lock on the brakes.
  5. Jun 2, 2020 at 9:42 PM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    Thanks, after reading this it pushed me to replace my boat trailer tires. I upgraded to Goodyear endurance load D 8 Piles had 6 piles before. Two of the old tires were manufactured in 2010!!! :anonymous:
    GODZILLA and Tundyfundy like this.
  6. Jun 29, 2020 at 9:26 PM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    Just replaced the trailer lights and the coupler on the in-laws boat trailer. next thing on my list is the bearings and leaf springs. apparently these have never had the covers on them. they still seem pretty solid to me. no wiggle or noise. gets dunked in saltwater pretty regularly. i grease them up a few times a year or before moving her any real distance (20+miles). the boat ramp is only 2 miles from the house so we dont put many miles on her normally.on her normally.
  7. Jun 29, 2020 at 9:36 PM
    AZTundra
    Paul
    Phoenix, AZ
    Excellent write up and great advice. :thumbsup:
  8. Sep 13, 2021 at 1:27 PM
    Retired...finally
    Coming from a background where safety is paramount I was shocked at the overall condition of my new TT that had just been prepped by the dealer. Little green valve stem caps on tires 20 psi too low, 18 of 20 lug nuts not torqued too 100 ft/lb, wires, water hoses and LP lines against steel edges with no chaffing protection, trailer brake wires not secured and hanging in the breeze and that's just the safety related items. Many more items inside showing evidence of Covid era assembly quality.
  9. Sep 13, 2021 at 1:34 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    @ColoradoTJ when replacing deck on a trailer, do you know if the wood needs to be spaced out like when putting up a fence? Or just lay them together as they are treated wood?
  10. Sep 13, 2021 at 3:18 PM
    LML 3500HD
    Space them out for shrink and swell. This also helps drain (water/snow, etc).
