Does your Sirius sound quality suck?
Discussion in 'Audio & Video' started by KCTundra, Oct 31, 2016.
  1. Oct 31, 2016 at 9:19 AM
    KCTundra
    KCTundra [OP] -Caeleb
    Caeleb
    Kansas City
    2016 Crewmax Platinum
    3/2 Ready Lift, 35" Nitto Trail Grapplers, 20x10 Fuel Assault Wheels (-18 offset / 4.75" backspace), BAM Budget Exhaust
    Got the 60 day trial when I bought my truck. The sound for Sirius really sucks. Sounds really dull and flat. Is there an option with Sirius to make the quality better? Or some setting that I'm missing?
  2. Oct 31, 2016 at 9:22 AM
    TheBeast
    TheBeast The Beach
    sounds great. Most likely your sound system settings. You might be missing the Bass if it sounds flat/dull.
  3. Oct 31, 2016 at 11:18 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I have had Sirius on several vehicles. I've noticed that some channels sound better than others. However, in general, it does not sound as good as a CD.
    trayday likes this.
  4. Oct 31, 2016 at 11:22 AM
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Years ago I signed up with XM before the XM/Sirius merger. I went with XM over Sirius because I read the sound was less compressed. After the merger I could definitely tell the difference. It now does sound flat to me compared to the original XM. I have a couple other gripes with the service since the merger but not enough to drop it simply for the convenience of not having to station flip while traveling.
    The sound is not what it could be/used to be.
    All in all, I'm slowly getting closer to pulling the plug and dumping it.
    NewImprovedRon likes this.
  5. Nov 22, 2016 at 2:30 PM
    jwm9289
    jwm9289 New Member
    I agree, CD or radio sounds better.
  6. Nov 22, 2016 at 2:36 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    You have a JBL. Try adjusting the settings. CM-it's a big cab! Could be with the XM though/mine didn't sound great until I adjusted the settings.
  7. Nov 22, 2016 at 3:55 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    Mine didn,t sound all that good till i installed a full Alpine system and a browning antenna on my rear rack. it still does,t sound as good as my I-Pod but thats OK
  8. Nov 22, 2016 at 4:55 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    I'm not 100 percent sure how the actual antennas on the satellites that Sirius uses are configured, but with military "birds", you arrange the high bandwidth (higher quality) spot beams to smaller areas, like cities, whereas the earth coverage beams are of much lower quality but cover almost an entire hemisphere. If the quality is better in urban areas than out in the sticks, then that may prove my hypothesis.
  9. Nov 22, 2016 at 6:53 PM
    LML 3500HD
    I have always had excellent sound quality from XM/Sirius radio. Probably a setting that was overlooked.
    Keep us posted.
  10. Nov 22, 2016 at 6:58 PM
    GoHuskers
    GoHuskers New Member
    Lam
    Nebraska
    '16 Limited CM 5.7L 4x4, '15 GX460 premium
    I have a CM with JBL and Sirius sucks ass, same as on my Lexus.....it's so bad that I didn't even use it at all. USB and Bluetooth streaming works great.
    DalTee likes this.
  11. Nov 22, 2016 at 7:05 PM
    LML 3500HD
    Wow, that sucks. I do have to admit, XM is not in my Lexus or my 12' Tundra, but others have been great. My current tow rig, you feel like the concert is inside the cab.
  12. Jan 8, 2017 at 4:07 PM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I had Sirius/xm for 90 day trial. Never liked the sound. I use slacker with no commercials and the difference in sound quality is night and day. Not only that found satellite sales people constant badgering so annoying and pushy there was no way I would do business with them
    DalTee and NewImprovedRon like this.
  13. Jan 8, 2017 at 5:52 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    It does sound horrible. I let it go and because I have an old package from Sprint (unlimited data) that came from Nextel, I just run Bluetooth from my SiriusXM app. It sounds better and I have more stations. I don't have Nav in the truck so when I use Siri, her voice just meshes in with my music.
  14. Jan 8, 2017 at 6:00 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Mine has always sounded good.. my new one I just put in my tundra sound better than my old unit.
    Alot I believe is on the module you use. If running a factory tuner they suck and aftermarket ones are good..
    DalTee likes this.
  15. Jan 8, 2017 at 6:01 PM
    DalTee
    DalTee New Member
    Dal
    Agreed! I have a head unit ready to go too! Maybe I'll switch in the spring.
  16. Feb 12, 2017 at 11:23 AM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I just purchased a Sony deck that came with SiriusXM free for 3 months and a 70 gift card and it does sound good in my truck. I used to have Sirius before the merger with XM. I haven't had it for some time and I like it so far. It has only been for a few days but I do like having the option of playing a variety of music without a lot of commercials. I wasn't paying 25.00 a month at that time so the price has changed a lot. I also had the unit that you add to a deck that is already installed and uses a radio frequency to get your channels. I like the newer version I have now much better since the connection is much better without the static of using a non-existent radio signal. I don't know if I will keep the service for very long after my free trial just simply because of price.
