Autostart WITHOUT the App...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kable, Mar 24, 2020.
  1. Mar 24, 2020 at 8:26 AM
    Kable
    Kable [OP] New Member
    Kenny
    Roswell,NM
    2020 Barcelona Red Platinum
    Stock....for now
    This may have been posted, but we had zero clue you did not need the app to autostart your vehicle.
    This works on my 2020 Platinum and my wife's 2020 Camry, but not on my son's Corolla.
  2. Mar 24, 2020 at 8:34 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are you talking about remote start? Three clicks on the lock button on your remote?
  3. Mar 24, 2020 at 8:40 AM
    Kable
    Kenny
    Roswell,NM
    Stock....for now
    Yes. Just hit LOCK LOCK LOCK (hold). It takes a few seconds but the lights will flash and she starts. Dealer told me the secret yesterday...if it is a secret...lol
    Probably should have said in the original post. Oops. Dealer said they used to tell owners, but stopped because they want to push the $10 per month subscription. Might be old news here. Just joined.
  4. Mar 24, 2020 at 8:47 AM
    swampshark
    swampshark New Member
    south la
    2020 MGM SR5
    restricted to certain models? My 2020 SR5 won't do that:(
    Kable[OP] likes this.
  5. Mar 24, 2020 at 8:53 AM
    Kable
    Kenny
    Roswell,NM
    Stock....for now
    Not sure...he just told my Platinum would and we tried it on my wife's camry and it worked. It didn't work on my son's corolla.
  6. Mar 24, 2020 at 8:56 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I believe you need to have Entune 3.0 and/or the factory remote start option.
  7. Mar 24, 2020 at 9:03 AM
    Kable
    Kenny
    Roswell,NM
    Stock....for now
    And I do have that.
  8. Mar 25, 2020 at 6:28 AM
    ptat
    ptat New Member
    The base SR5 doesn't have that. You have to have the OR or Sport package to do that.
    Durania and Kable[OP] like this.
  9. Mar 25, 2020 at 1:05 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Doesn't seem to work on my 1794.
  10. Mar 25, 2020 at 1:06 PM
    swampshark
    south la
    2020 MGM SR5
    I have the TSS Off Road package...not the same?
  11. Mar 25, 2020 at 1:15 PM
    Kung
    KG, VA
    I just bought a 2020; and while I don't technically need the app to do it, I *did* have to register the vehicle through connected services or whatever it's called. Soon as I did that, it allowed me to use the fob to start the vehicle.
  12. Mar 25, 2020 at 1:27 PM
    Bigkeeper
    Bigkeeper New Member
    Kelly
    2020 TRD Pro MGM
    None Yet
    This was news to me and it works on my 2020 Plat Tundra, has the same limitation as app truck turns off when you hit unlock, great for warming up the truck glad you brought it to our attention....
  13. Mar 31, 2020 at 1:46 PM
    2020TundraVooDooBlue
    2020TundraVooDooBlue New Member
    I guess on the '20 Tundra SR5 TSS Offroad package it doesn't work. I can't get it to register in my app and the console gives me some message about Connected Services not being available.
  14. Mar 31, 2020 at 2:12 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Works fine on my 1794, I do not have an app just hit lock three times and hold on the third.
  15. Mar 31, 2020 at 2:21 PM
    Just got off the phone with Toyota and she told me that it wasn't compatible with the head unit in the truck. I would have to get another head unit. I asked 'then why is it an option on the screen'? she said i would need to go to the dealer and ask them. I guess I don't understand.
  16. Apr 1, 2020 at 5:52 AM
    ptat
    ptat New Member
    I think that the app only works if you have the premium audio system (non-JBL).
  17. Apr 1, 2020 at 6:30 AM
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    Works on my 2020 Limited with Premium JBL Audio. No app needed and no need to pay the monthly fee. Just the key fob and three clicks...hold for a few seconds on the third. Dealer specifically told me it didn't have remote start and he could have it installed for me for around $800. Crooks! I've called them and their management chain to let them know how I feel! Most probably have little need for Remote Connect, Safety Connect, and Destination Assist Connect, each of which is $8/month. https://www.toyota.com/content/entune/responsive/pdf/Connected_Services_Pricing.pdf
  18. Apr 1, 2020 at 6:47 AM
    co2owen
    co2owen New Member
    VA
    Per the .pdf below, I'll be able to use the key fob to remote-start the truck without downloading and paying for the app for 10 years. So, that tells me the remote start software that allows the key-fob functionality without the app is set to allow it to function through a specific date or 10 years from manufacture. After that date, the software is likely set to disable the key-fob functionality or it'll check to see if you've decided to pay your $8/month or whatever the price will be in 10 years. If you've decided to pay, the software will allow the key fob to continue working. Interesting that Toyota is doing this. Do other manufacturers make their customers pay for apps in order to have what's considered a fairly standard feature (remote start) on a $40K+ vehicle?
    https://www.toyota.com/content/connectedservices/marketing/PDF/Remote_Connect_CFA.pdf
  19. Apr 1, 2020 at 7:57 AM
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    Yeah, you have to have the service. I called Toyota to cancel everything and the 3-click start doesn't work on my truck.
  20. Apr 1, 2020 at 8:09 AM
    co2owen
    co2owen New Member
    VA
    Thanks Green Thunder. I guess I'm in the trial period since I did not waive the Connected Services Registration. I won't be paying for it after the trial ends. I'll have to see if the key fob keeps working after the trial. That'll be June for me. My guess is it'll continue to work since I didn't cancel my registration, but I'll also likely be asked once a month by Toyota if I want to sign up to pay the $8/month.
  21. Apr 1, 2020 at 1:21 PM
    G10dra
    G10dra Not a New Member
    Just be aware that the app is sending your driving info to Toyota and its affiliates
  22. Apr 1, 2020 at 1:50 PM
    Rngr188
    Chad
    Harrison AR
    Not sure about affiliates and I don't have the app but my last two trucks I get a letter from Toyota telling me it's time to schedule a service apt right before I reach the 5k miles, doesn't matter if I put 5k in one month or three that letter comes right around 4-4.2k.
  23. Apr 1, 2020 at 2:26 PM
    PJR202
    PJR202 New Member
    Dont feel bad. My wife had her Acadia for four months before I noticed the little circle on her key fob. We didn't even know it had remote start at all.
  24. Apr 1, 2020 at 2:29 PM
    co2owen
    co2owen New Member
    VA
    I don't have the Remote Connect app either but I agreed at the dealer to register for "Connected Services". They're definitely tracking me and sharing my information with insurance companies and who knows who else. Based on my driving (I drive like an old man) I've been offered a 35% discount on my insurance, or so the emails say. Probably a bunch of BS. All that said, if you're registered with Connected Services, they're definitely tracking you. If you're not registered, I wouldn't be surprised if they're still tracking you. I'll be interested to see what happens as I approach 5,000 miles like Rngr188.
  25. Apr 1, 2020 at 2:30 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    yeah... my 2016 SR5 has the remote start. click lock 3 times and hold.
  26. Apr 1, 2020 at 5:59 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    Only silly thing is it turns off the moment you open the door... well gee thanks now I have to turn it on again :p
  27. Apr 1, 2020 at 8:12 PM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
  28. Apr 2, 2020 at 7:09 AM
    Kung
    KG, VA
    Hell yes they do, and for less features. I traded in my 2013 F150 on the 2020 Tundra; and the XLT with a package or two is roughly similar to the SR5, except the SR5 came with FAR more features than the XLT did. Here's a list off the top of my head:
    - better build quality (naturally)
    - better media package
    - crapload of safety features (on an F150 you have to get something like the Limited or King Ranch to get this)
    - LED accent lights
    - heated rear view mirrors
    - windshield wiper de-icer
    - rear tailgate easy-down
    - easy access cabin filter
    - integrated brake controller
    - tow package (on the XLT it's an actual extra package; it just comes with the SR5)
    - 4.30 gears (yeah, this comes with all Tundras that tow, but you can't GET these standard on ANY F150)
    There's more, but you get the idea. Considering all of that, even if I DID have to pay $80/year to unlock the truck/turn it on, I'm totally fine with that.
  29. Apr 2, 2020 at 8:03 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    To be fair, does a 2020 XLT come with any of those features? Did a 2013 SR5?
  30. Apr 2, 2020 at 11:03 AM
    Kung
    KG, VA
    A 2013 SR5 did not...but neither does a 2020 XLT configured almost exactly the same way my 2020 SR5 is. If I add the stuff that I can add, it gets me to right around an MSRP of $50K (MSRP on my 2020 Tundra was $48K), but it *still* doesn't have the safety features. To get those (adaptive radar, lane departure, etc.) I'd have to step up to the Lariat.
    (This isn't counting any customized shocks or any of that stuff.)
    I'm not saying that F150's don't have their strengths. I'm just saying that there are indeed features offered as standard on Tundras that aren't offered on F150s as standard (or at all, for that matter).
