2019 Tundra Fuel Pump keeps running
Discussion in '2.5 Gen Tundras (2014-2021)' started by MVTRDPro, Jan 17, 2020.
  1. Jan 17, 2020 at 11:27 AM
    MVTRDPro
    MVTRDPro [OP] New Member
    2019 white TRD Pro
    Saw this thread and have same issue with 10k miles on it. Got a service coming up and will post what the dealership has to say.
  2. Jan 17, 2020 at 11:44 AM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    I've heard mine running a couple of times when it was parked in the garage. I've got a service appointment scheduled on Monday and plan to ask about it.
  3. Jan 17, 2020 at 12:00 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    My owners manual says:
    "Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check, and it does not indicate a malfunction."
  4. Jan 17, 2020 at 1:12 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    Ive heard this noise before on my 2017 sequoia. I thought my truck was broken or something. Web search led me to this forum and info said it's normal. Evap system.
  5. Jan 17, 2020 at 5:33 PM
    Mountaineer
    TN
    2019 MGM Platinum
    Novel idea reading the manual. Thanks for the info!
    1engineer likes this.
  6. Jan 17, 2020 at 5:41 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Well if your trucks fuel pump is running then I guess your truck is safe from the recall then....
    BAHAHAHAHAHAHAHAHAHAHAHA ya I had to...
    panicman likes this.
  7. Jan 17, 2020 at 7:32 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    RLHOK- that’s asinine!
    if his pump is running-
    ...he’d better go catch it!!!
    Joe333x, RLHULK and landphil like this.
  8. Jan 17, 2020 at 9:28 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    RLHULK and panicman[QUOTED] like this.
  9. Jan 17, 2020 at 10:51 PM
    RLHULK
    Rich
    2022 Silverado LT.
    LOL well ya that to...
  10. Jan 17, 2020 at 10:56 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I have heard mine do this as well, dealer said it’s normal.
  11. Jan 20, 2020 at 9:45 AM
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    I was told the same.
    I live in WI and I have not heard this noise since November 2019, seems to be a summer thing or over 30 degrees.
    Bear
    gladecreekwy likes this.
  12. Jan 20, 2020 at 7:35 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Well I’m in Oklahoma, I don’t remember if it was cold or not but the first time I heard it was definitely in winter. Was super weird though because it had been like 5 hours since it had been driven that day.
  13. Jan 20, 2020 at 7:50 PM
    gosolo
    Ray
    NW Oregon
    If your nose is running and your feet are smelling, you might be built upside down... just saying
    panicman[QUOTED] likes this.
  14. Apr 14, 2023 at 9:39 PM
    ND90
    ND90 New Member
    2019 Limited Off-road
    Just experienced this fiasco. I come to the garage and I’m searching for this noise for at least 10 minutes then I finally bent down under the truck and it was the fuel pump. I put the key in and turned it to on and not to start and back off and it went away. Weird. And I didn’t go catch it lmao.
    gosolo likes this.
  15. Apr 15, 2023 at 5:45 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    It’s just the tank evap system…totally normal…my 14 Tundra does that as does our 14 highlander…don’t take it to the dealer.
  16. Apr 15, 2023 at 2:04 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    My 2016 does it..
