Newbie looking for used Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by kenstl, Jan 7, 2020.
  1. Jan 7, 2020 at 8:26 PM
    kenstl
    kenstl [OP] New Member
    Hi All..
    I went through this a couple of years ago in purchasing a used FJ which we love. After driving a car for the past 4 years, I am ready to move over to a truck. It will be a daily driver (highway princess) for my commute and business use, but looking forward to having a larger vehicle for the family and road trips. I will be driving approximlaty 22,000 miles a year. Budget is under $30k, and definitely want a gen3 truck. The only "must have" is heated seats. If I buy a SR5, I will have heated seats installed at an additional cost. Not agains the Limited etc, but most of the ones I am finding in my price range have 80,000 and up miles on them and the prices are still $29-$32k.
    After looking at a number of trucks it's almost like there is more of a price difference due to mileage vs the year of the vehicle. I have seen some 2018 models almost as cheap as some 2015 models, or at least within 5%.
    2018 CM SR5 4wd, 52000 miles, $32,800
    2018 CM SR5 2wd, 47,000 miles, $27500
    2016 CM SR5 2wd, 64,000 miles $25,000
    2016 CM SR5 4wd 37,000 miles $31,500
    2014 CM SR5 4wd 57,000 miles $28,000
    Would you put more value on getting a newer model or lower mileage, regardless of year? Also, was the 38 gallon tank standard on SR5 CM in 2016?
  2. Jan 7, 2020 at 8:32 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Not standard. It needs an upgrade package (fairly common) to get the 38 gallon tank. I had the same buying parameters as you 3 years ago and ended up buying new because I couldn’t bring myself to buy a 4 year old truck with 50k miles to save $5,000.
    ptat, rebmo, Tchase and 1 other person like this.
  3. Jan 7, 2020 at 8:52 PM
    kenstl
    I would consider it but I am not finding anything new for $35k or under in a CM with upgrade package. A new SR5 CM in 2wd stickers at $46,000, 4wd at $50k. I haven't been able to get anyone to discount a $46k truck down to $35k between rebate and dealer discounts.
  4. Jan 7, 2020 at 9:07 PM
    AZBoatHauler
    So.Arizona
    NewImprovedRon likes this.
  5. Jan 8, 2020 at 4:12 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Don’t forget to consider the finance rate from new to used. I choose new as I usually buy used but I planned to keep this until long after it’s paid off. I run about 18,000 miles per year. So if and that’s a big if I figure in 5 years I’ll be pushing 90,000 if I still have it. I plan to! So at the low finance rates they have I’d choose new.
    AZBoatHauler likes this.
  6. Jan 8, 2020 at 5:20 AM
    db52282
    db52282 New Member
    Georgia
    2017 Silver Tundra Limited
    I was in the same boat you are in right now. I looked for 3 years and shopped until I was going crazy. Seemed like every truck I looked at either had a ton of miles or was basically new. I even looked in a 500 mile radius from where I live and was planning on doing a "fly and drive". Finally found what I wanted within an hour of my house and pulled the trigger. Very happy with my purchase. Keep looking ... the right one will eventually pop up.
    mundra likes this.
  7. Jan 8, 2020 at 5:45 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    The worst deals you will encounter will be from the Yota Stealerships...
  8. Jan 8, 2020 at 8:13 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Get a newer model if you value the features they offer and be prepared to pay a bit more: Led lights, safety package, etc...
    if you don’t value those, go for an older one and some possible savings.
  9. Jan 8, 2020 at 1:42 PM
    panicman
    Eric
    Geography also effects price- where are you?
  10. Jan 8, 2020 at 2:55 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Personally I think it is worth it to have 4x4. I would even by a higher mileage truck to get at the right price point.
  11. Jan 8, 2020 at 3:34 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    The prices you list are in line. You need to look at the features on each. Such as upgrade packages etc. Figure $4K+ for 4WD over 2WD. #2 on the list looks to be better. Then #3 if 2WD is fine. But it all depends on how clean the truck is, wheel upgrades, bucket seats etc. SR5s with upgrade packages are nice. Leather is great for me. Not because it's luxurious but because I spill shit all the time or have a taco shell disintegrate going down the road. I bought used because that's what I could afford and pay cash for.
    panicman likes this.
  12. Jan 8, 2020 at 4:01 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Also consider that you'll have a lower APR with a new truck vs used. As for 4x4 vs 2wd, I go with 4x4. I always get stuck somewhere with a 2wd, I end up having my AWD vehicles pull me out of the situation or a bulldozer. Getting a base model 4x4 and do the upgrades in cash will save you at least 1K interests.
  13. Jan 8, 2020 at 7:25 PM
    panicman
    Eric
    OP, if I could give you any advice to chew on, it is to plan out first what exactly you want. I can’t imagine the actual year is all that important to you, but consider stuff like the gas tank (26 vs 38gal), headlights (led vs standard), safety sense (which includes the cool adaptive cruise), maybe a sliding sunroof is a freaking MUST... whatever, just pencil out what you want, and THEN gather pricing.
    After that, you can return to your plan and figure out if you need to cut, what can you add later, and get the price into range that way.
    I had my list of non-negotiables. I wanted the new TSS stuff, mostly for the adaptive cruise, so I had to wait for ‘18. I also wouldn’t budge on the 5.7l, 4WD, 38gal tank, and I wanted leather.
    The leather is what killed every deal I tried to work out with the dealership to get what I wanted and stay in my price range. I wound up with an inflated quote for dealer leather, or I was into Limiteds and paying for other stuff that I didn’t want or care about.
    So, the leather requirement went bye bye after I researched Katzkin kits.
    I landed in an SR5 with the SR5 and TRD Offroad upgrades, and I installed my leather a year later and I honestly couldn’t be any more pleased with the truck.
    Mileage was not a consideration for me, as I was buying new. But I would still have approached it the same way; what truck do I want, exactly- and then go find it.
    good luck, and please come back with pictures when you bite the bullet and make the deal!
  14. Jan 8, 2020 at 7:44 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    With the anticipated mileage driven expected, I would lean lower miles as they will add up. Not much if any differences in 3rd gen year models.
  15. Jan 8, 2020 at 7:57 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
  16. Jan 8, 2020 at 7:59 PM
    kenstl
    I am in the St. Louis MO area, but am also looking in the DFW area as well as I travel there a couple times a years. I flew to NC for our FJ, so I am not opposed to traveling for the right vehicle.
  17. Jan 8, 2020 at 8:59 PM
    kenstl
    Thank you everyone for the responses, some good info to assist in narrowing down my search. Since the prices never seem to really dip under $24k unless they have very high mileage, I am pretty much dealing with vehicles in the $25k - $32k range. That is one of the reasons I am probably not going the "high mileage" route as it just doesn't seem like there is much of a discount for a 120 - 140,000 mile vehicle as I see those still in the $21k - $24k range. I am trying to pay cash, so the lower the better, but it just seems like it will be worth paying an extra $4k-$7k to get something with mileage under 50,000 or so, which is about 4 years of use compared to the higher mileage vehicles.
    I agree with you panicman in picking the "must have" items; the one must have is to get the console with bucket seats which come with the SR5 upgrade package. Many of the other items I am most particular about can be added later like heated seats, leather, bed cover etc. I am fine with the 4.6 or 5.7 engine choices and if I thought I would actually get better mpg with the 4.6, I would only go that way but from what I have read, that seems to be crap shoot. I think the biggest decision I need to settle on is whether I am ok to go with 2wd only.
    I think 7.6Tundra stated 4wd is about a $4k difference, and that is what I am seeing out there as well on a comparable year and mileage vehicles. I think I am ok with purchasing a "non Toyota Certified", just not sure if the $4-$5k for 4wd is worth it based on my use of the vehicle and the fact that if needed, we have a FJ Cruiser if the need arises. The only thing I may miss is the possible occurrence of being out on the road when a snow storm occurs or the one week every other year or two when we get snow that hangs around for a week or two due to very cold weather vs the norm of it disappearing after a day or two.
    I'll post a pic once I pull the trigger on one, until then, attached is our FJ.
  18. Jan 16, 2020 at 2:23 PM
    kenstl
    I think I found a Tundra but have question. The vehicle was previously purchased as Toyota Certified vehicle with 12,000 miles on it. It currently has 24,000 miles so it is under factory warranty still, but from calling my dealer, he states the "certified" warranty does not transfer but the mfg warranty would obviously still be in place.
    Has anyone purchased low mile vehicle and then went though the trouble of having a dealership certify it and pay for the Certified warranty? Not sure that is worth it but curious.
  19. Jan 16, 2020 at 2:28 PM
    AZBoatHauler
    So.Arizona
    I'm assuming the dealer with the vehicle is not a Toyota dealer?
  20. Jan 16, 2020 at 2:33 PM
    kenstl
    Correct. It is an off lease vehicle being sold by the leasing company. I am going to have it inspected by a shop, but want to make sure I am not missing anything on future warranty options.
  21. Jan 16, 2020 at 2:40 PM
    AZBoatHauler
    So.Arizona
  22. Jan 16, 2020 at 2:45 PM
    panicman
    Eric
    Consider running the VINs of any possible purchase through the Toyota website. They just announced a recall on some Tundra fuel pumps. Seems to mostly be affecting 26 gal tank trucks.
    best of luck!!
  23. Jan 16, 2020 at 2:55 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Exactly why I bought new..
    ptat and rebmo like this.
  24. Jan 16, 2020 at 2:55 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    If the vehicle is still within the 3 yr 36k warranty, you can get a platinum warranty for up to 8 yr 100k for a very reasonable price. We have a forum contact at wolverine Toyota that can sell your the warranty directly (many on this forum can attest to this). This is a Toyota warranty, not a third party warranty.
    plumber802 likes this.
  25. Jan 16, 2020 at 3:18 PM
    kenstl
    Thanks! I just ran it through, looks like Toy Care service at 5 and 10 miles and an SRS Sensor update that was done. It looks like Toy Care ends at 25,000 miles or 11/22/19, so I am out of luck on that end, although the Roadside Asst expires 3/28/2020.
  26. Jan 16, 2020 at 3:19 PM
    kenstl
    Good to know, thanks. I am usually not a warranty guy, but I will probably make the call just to see if I can justify the cost.
  27. Jan 17, 2020 at 3:17 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    4WD is a "must Have" on any truck...
  28. Jan 17, 2020 at 5:47 AM
    kenstl
    Well I will be breaking all of the forum advice rules on this one as I am looking at the purchase of a 2018 Tundra 2wd 4.6 with 23,000 miles!
    Cpl_Punishment likes this.
  29. Jan 17, 2020 at 6:13 AM
    SprinterAE86
    Ian
    If it's still under factory warranty you can get an extended warranty on it still.
  30. Jan 19, 2020 at 9:48 PM
    kenstl
    Everything checked out on the inspection! Looks like I will be moving forward, hope to be able to pick it up within the next couple of weeks.
