Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Dec 8, 2019 at 9:28 AM
    #1501
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've been a auto tech for 25+ years and a Toyota tech for the last 5. Hats off for Lotsoftoys for taking on this challenging thread. I've been off work for about 6 months because of carpal tunnel surgery that was performed in both wrists. I specialize in front end work and alignments. Now that I have some time off I may be willing to contribute if you need the help.
  2. Dec 10, 2019 at 4:17 AM
    #1502
    chris
    chris New Member
    OK, here is one for you mechanics. When I crank my steering wheel to the left to make a U-turn, about the middle of the turn I get a popping noise. I have taken it to 3 different mechanics, first 2 couldn't find anything and the last one got me for new CV joints. Problem is, it still makes the sound. Could someone please give me some reliable insight so I know where to go with this
  3. Dec 10, 2019 at 5:58 AM
    #1503
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Does it have a TRD skid plate? Regardless take down the skid plate and try the U turn again. Sand and Rocks can get trapped between the skid plate and frame and as the trucks frame flexes can cause this.
    NewImprovedRon and TundraDude18 like this.
  4. Dec 14, 2019 at 2:28 PM
    #1504
    Gabyson
    Gabyson New Member
    2011 white Tundra Limited
    Having an issue with ABS speed sensor on my '11 Limited. I have replaced the sensor three times and the harness and still showing an error when diagnostic hooked up.
  5. Dec 26, 2019 at 7:16 PM
    #1505
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It would be very hard for a tech to diag a clunk\twang on a forum. Have it checked out and don't ignore it. Leaving things usually costs more in the long run. Obvious things to check are rocks in the skis plate, front end check (ball joints, tie rods, struts and coils, a stabilizer bar). Also make sure the wheels are tight.
  6. Dec 30, 2019 at 8:45 AM
    #1506
    TXTundra13
    TXTundra13 New Member
    Wassup man. Truck is an 08 5.7. It doesn't overheat but gets warm at highway speeds, typically 70-75. It creeps a little past the halfway mark. It cools down to normal when i floor it, or if i run the heat. Is this the thermostat?
    Thank you.
  7. Dec 30, 2019 at 8:59 AM
    #1507
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    Same thing happened to my 2017 Tundra, and they wouldn't warranty it. I'm still under warranty, with #23K miles. Said it was a cosmetic part. So I ordered the part and need to install it myself.
  8. Dec 30, 2019 at 10:46 AM
    #1508
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I would contact Toyota corporate and square it away thru them. Many folks here have had to do that when the dealership tries to slither out of honoring warranties.
    Shaggie13[QUOTED] likes this.
  9. Feb 25, 2020 at 4:46 AM
    #1509
    Umpocoloco2014
    Umpocoloco2014 New Member
    Hello. I have a 2014 tundra sr 2x4 4.6l. It has 174,000 miles on the odo. At random the truck will not accelerate or open throttle when depressing the accelerator pedal. It will only idle. I have three tps codes popping up, and a transmission slip code. P0121, P0123, P2135, and P0894. After resetting the computer by disconnecting the battery, the truck will run fine (with more throttle response than usual) for about a day. Then at some random stop light, it will no longer accelerate. I replaced the accelerator pedal. Worked for a day, then same problem. Looking for some insight.
    Randy Morton likes this.
  10. Feb 25, 2020 at 5:37 AM
    #1510
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    I had the same symptoms on my previous truck (non-Toyota) and it was the throttle position sensor.
  11. Feb 25, 2020 at 5:39 AM
    #1511
    Kalashnikov 47
    Kalashnikov 47 New Member
    Minnesota
    2018 Sr5 double cab gang
    Can i get a list of all the parts neeses for a gas tank swao from a 26 gallon to a 38. Yes i know theres a thread but i have a flex fuel.
  12. Feb 25, 2020 at 5:53 AM
    #1512
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    On that A/C knock after it sit for a few it most likely lack of lubrication , when the system is run day it wel lubricated as the refrigerant carries the lubricant through the system , my educated guess is when it sit all the the oil settles to the bottom of the compressor , evaporator and condenser and it takes a bit to get the compressor good and lubricated again , especially because the compressor is a bit older not unlike a engine with 150-200k . Like I said just an educated guess .
  13. Feb 25, 2020 at 6:20 AM
    #1513
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    @Roman
  14. Feb 27, 2020 at 8:59 AM
    #1514
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    Broken transmission mount!
    See the attached photo, circled is the area that is broken or separated.
    How critical is that portion of the mount and could it the cause of a shudder I feel around 45mph?
    Thank you for any insight
  15. Feb 27, 2020 at 9:13 AM
    #1515
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Unsolicited opinion: Ya, I'd get that fixed/replaced, even if it isn't the origin of your shudder. Additionally, it eliminates that as the cause.
  16. Feb 27, 2020 at 9:15 AM
    #1516
    Kn4x2
    2010 DC 2WD
    All opinions welcomed. Thank you for yours
    Toyotoholic and Wynnded[QUOTED] like this.
  17. Feb 29, 2020 at 10:16 AM
    #1517
    @Roman
    AC compressor bolts, (long ones) that mount ac compressor to ac compressor bracket
    '97 T100 3.4 V6
    VIN# JT4UN22D9V0046609
  18. Mar 3, 2020 at 7:26 AM
    #1518
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  19. Mar 5, 2020 at 9:11 AM
    #1519
    CookieMonsterTundra
    CookieMonsterTundra New Member
    Trip
    2018 1794 Tundra
    Hi everyone, Not sure I have an issue but thought I would throw this out there in case anyone else has this issue or if it is considered normal. I have a 2018 1794 CrewMax and I have been experiencing an inconsistent output of light at each light bulb in my truck. This is wholistic in that is happens all the time (most noticeable at night) with all lights inside and outside the vehicle. This occurs during idling, accelerating and decelerating. The voltmeter on the dash is bouncing up and down between ~13-15V. Any suggestions? Anyone else experiencing this?
  20. Apr 7, 2020 at 12:34 PM
    #1520
    f.pecan
    f.pecan New Member
    Forest
    2007 Tundra DC 5.7L
    Eibach COs and rear AAL., Morimoto XBs, Rough Country 20" Light Bar, Rough County Ditch Lights, CBI ditch brackets, rock lights,
    I'm looking for the hitch electronic connection bracket bolt. I took it off for a second to do some rust control on the bracket and ended up shearing it off bolting it back on. I know the head is 10mm but can't figure out what it is.
  21. Apr 12, 2020 at 8:03 AM
    #1521
    TemujinNomad
    TemujinNomad New Member
    Hello everyone. I tried searching and only found results for greasing the driveshaft. Anybody have a diy guide on re torqueing the propeller bolts? Thanks in advance.
  22. Apr 12, 2020 at 8:13 AM
    #1522
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nothing special, make sure the flanges are clean then torque to spec using a cross pattern.
  23. Apr 14, 2020 at 3:15 PM
    #1523
    montymitch
    montymitch New Member
    2018 SR5 CM with the front bench/column shifter.
    I've got a problem with the shift lock and the local dealer says they fixed it but it's still clicking. If the vehicle is in park and I depress the brake pedal, there is a click in the steering column, which I believe is the normal sound of the shift lock.
    The problem is that it intermittently will click when I'm driving. Sometimes it does it, sometimes it doesn't. Should I just suck it up and live with it?
  24. Apr 14, 2020 at 3:49 PM
    #1524
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I know that with my column shift it sometimes feels like the shifter isn’t all the way in gear. Even though the trans drives normal the shifter doesn’t fell like its all the way seated in its slot. I don’t hear any clicking though.
  25. Apr 14, 2020 at 5:12 PM
    #1525
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check the connector at the brake pedal switch and make sure it's seated in properly. If it looks fine I'll check a wiring diagram. What year and trim is your truck?
  26. Apr 14, 2020 at 7:49 PM
    #1526
    Ronskii06
    Ronskii06 New Member
    I posted to the general forum but I figured I post in here as well.
    I just purchased my first tundra 2016 5.7 75k
    I have noticed a slight/faint diesel tick/knock when sitting at idle. It’s this normal? It’s very minuscule but enough that spending 23k on a truck I don’t want to hear any noise.
    thoughts? Am I just paranoid? Or is it normal for higher mileage motors to develope a slight knock.
    FYI I’m pretty sure it’s not injectors or valves because I hear it mostly in the exhaust and behind the motor and inside the cab
  27. Apr 14, 2020 at 7:51 PM
    #1527
    TemujinNomad
    Thank you. So there are two sets of bolts needed to be torqued, front and rear driveshaft?
  28. Apr 14, 2020 at 8:31 PM
    #1528
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Four bolts on each flange. To be honest with you nobody torques them at the dealer. We just bolt them up tight but make sure the bolts are clean and add a little blue loctite. Make sure the flanges are clean.
  29. Apr 14, 2020 at 8:33 PM
    #1529
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Parinoid, they all do that and will until the day you sell it.
    Ronskii06[QUOTED] likes this.
  30. Apr 15, 2020 at 7:09 AM
    #1530
    montymitch
    2018 sr5 Crewmax. I'll check that connector when I get a free minute today. Thanks!
