Slow to start
Discussion in '2nd Gen Tundras (2007-2013)' started by MookTastic, Jan 4, 2017.
  1. Jan 4, 2017 at 4:39 AM
    MookTastic
    MookTastic [OP] Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    Lately I've had a few slow starts. More so when the engine is cold. It will crank just find but then its just a little slow to rev up. Drives, accelerates just fine. Just those slow start ups from time to time. Any ideas???
  2. Jan 4, 2017 at 5:37 AM
    LML 3500HD
    Check easy stuff first: posts clean, connections are tight.
    Check your battery voltage and let us know. May have a cell going bad. Great thing is toyota batteries are under warranty for 8 years. If you do not have a multimeter, most auto parts stores can load test the battery.
    Any off-roading lately to include mud and water? Alternator is at the bottom of motor.
  3. Jan 4, 2017 at 5:39 AM
    MookTastic
    Trice
    Rapid City, SD
    Already had the battery checked. Checked good. I get under there and take a look at the alternator. Thanks for the advice
    ColoradoTJ likes this.
  4. Jan 4, 2017 at 5:41 AM
    LML 3500HD
    Good deal. Check all connections. Probably something simple that is causing your issues (hopefully).
  5. Jan 4, 2017 at 6:12 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    I had a similar issue with my RAM.
    Turned ignition truck would start would take its time to idle/rev up sometimes a little rough. Weather condition did not matter. That lasted for about 3 months
    Then starting issue evolved into turning the ignition once, let it crank for a few seconds. Stop and on the second attempt
    it started with no idle issues at all. That lasted for about three years. Then one day it would not start at all. Replace fuel pump.
    worked like a champ. One crank truck started and no slow idle. Month later junked the truck bought new Tundra.
    Kurt
  6. Jan 4, 2017 at 8:24 AM
    T-Rex266 Moderator Staff Member
    Wonder if it needs more cranking amps for the cold?
  7. Jan 4, 2017 at 8:46 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Mine does this as well. I live in south Texas and dosnt get that cold here. Do you have the flex fuel engine? I've heard you might have to get the ecu flashed. Keep us posted
  8. Jan 4, 2017 at 9:41 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    How cold does it get where your from in Texas? Mine does this when its cold, it seems like it takes about a second or so to kick up the RPMs on a cold start. I also experienced this after disconnecting the battery for a while and reconnecting it and starting it but after a few starts it back to normal. Easy thing to do is to check, clean, and protect the connections.
    By "slow to start" you mean the engine is hesitant to start, or the RPM's are slow to get up to where they should normally be for a cold start.
  9. Jan 4, 2017 at 3:10 PM
    MookTastic
    Trice
    Rapid City, SD
    North Texas Wichita falls. Cold doesn't mean cold to me. Was stationed in South Dakota at one point but not with this truck. And I'm referring to slow to build rpms. Usually just first crank in the morning. But yes it is the flex fuel engine
  10. Jan 4, 2017 at 3:15 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    you say the battery was checked...did you only check the voltage reading or did you load test the battery as well? just a simple voltage reading can/but won't tell you the battery is on its way out or bad.
  11. Jan 4, 2017 at 3:29 PM
    MookTastic
    Trice
    Rapid City, SD
    Idk. Whatever AutoZone does for free. Lol. I don't own a battery tester or a multimeter
  12. Jan 4, 2017 at 3:33 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    what year and whats the mileage?
    nvm 2013
    , just noticed your signature
    if all they did was hook up a little hand held, more than likely just a voltage check. Should be able to go to a Goodyear or any automotive place like that, they should be able to load test it without any issue. Even Walmart automotive section might be able too.
    J4RR3N4 likes this.
  13. Jan 4, 2017 at 3:34 PM
    MookTastic
    Trice
    Rapid City, SD
    2013 W/ 90k
  14. Jan 5, 2017 at 9:59 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Here's a good test:
    Turn the key to on, but don't start, then off, then on, then off, then try to crank. If that solves the problem then your issue is the fuel pump having trouble priming.
    equin, Bones2012, J4RR3N4 and 2 others like this.
  15. Jan 5, 2017 at 10:06 AM
    MookTastic
    Trice
    Rapid City, SD
    Will definitely give that a try. Thanks for the advice
  16. Jan 5, 2017 at 12:33 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    I remember reading somewhere on here about the flex fuel engines and cold starting ( could be wrong ) something about the ecm thinking it was running e85. Mine only does this sometimes, takes a second it seems like to idle up.
  17. Jan 5, 2017 at 1:11 PM
    MookTastic
    Trice
    Rapid City, SD
    Yeah it doesn't seem to be an issue. Like I said it starts everytime, runs like a champ. Just slow to idle sometimes
  18. Jan 22, 2017 at 4:57 PM
    MookTastic
    Trice
    Rapid City, SD
    Is our fuel pump a gas tank drop? Or is there an access under the seat?
  19. Jan 22, 2017 at 5:26 PM
    LML 3500HD
    I am pretty sure it is the tank.
  20. Jan 22, 2017 at 5:40 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Gas tank
  21. Jan 22, 2017 at 5:47 PM
    MookTastic
    Trice
    Rapid City, SD
    That's what I figured. Thanks fellas! Any guestimates to how much it will run me to have this replaced?
  22. Jan 22, 2017 at 5:51 PM
    LML 3500HD
    You handy with the tools and have access to a lift or a way to elevate the truck at least 1' off the ground? Drive your truck until the DTE reads zero and do the job. The tank is lightest then. Have a buddy help you with dropping the tank. I dropped my tank on my 05 Dodge by myself with a floor jack.
  23. Jan 22, 2017 at 5:53 PM
    MookTastic
    Trice
    Rapid City, SD
    Yeah im good with doing it myself prolly. I'm sure a buddy from work would help. I'll just have to put up with the Yoga smack talk cause they are helping me fix it.
  24. Jan 22, 2017 at 6:04 PM
    LML 3500HD
    Well, then if you want to purchase the whole assembly, that is easiest. However, if your sending unit is fine, I would just change out the pump. It is pretty easy disassembling the pump housing, replace pump and put it all back together.
    The whole module is ~350.00. The pump is just 70.00. Have you verified that your fuel pressure is bad? I would start there.
  25. Jan 22, 2017 at 6:07 PM
    MookTastic
    Trice
    Rapid City, SD
    My slow to start has turned into an every now and tben fail to start. She will try and crank but no fire. Sounds likes it not getting fuel. Second crank starts and the rest of the day it starts fine. Just the first one in the morning. No codes or lights thrown though.
  26. Jan 22, 2017 at 6:09 PM
    LML 3500HD
    Sounds like you have an air leak and losing prime.
    Do you have the ability to park at an angle where the truck is nose down?
  27. Jan 22, 2017 at 6:10 PM
    MookTastic
    Trice
    Rapid City, SD
    Uh...For how long?
  28. Jan 22, 2017 at 6:15 PM
    LML 3500HD
    Overnight. Then see if you still have a slow to start, or failure to start. If you have some vehicle ramps, back up on them with the nose down the driveway. That should be sufficient enough.
    What I am trying to troubleshoot, is an air leak in the system. Most driveways or garages have a slight slope to them. If you have a small air leak, the fuel will run back to the tank overnight. When you come out in the morning, you have hard to start or failure to start since the fuel has lost prime.
  29. Jan 22, 2017 at 6:17 PM
    MookTastic
    Trice
    Rapid City, SD
    Makes sense. My driveway isn't very sloped but I got some ramps. I'll try it out. Thanks man!
  30. Jan 22, 2017 at 6:22 PM
    LML 3500HD
    I would sure hate to see you drop a tank, the cost of a pump, and still have the problem. This happens a lot in the diesel world, more so than gas vehicles. Usually when you have a vacuum leak, it is a fuel leak as well due to higher pressures. Most diesel lift pumps are 8-13 psi, where a fuel injected gas motor is much more.
    This might help as well. As much as I hate linking this site to here....
    http://www.tundratalk.net/forums/tu...sues-e85-fuel-pressure-fuel-sending-unit.html
