Humming/Rattle in cab when RPM 1800-2000
Discussion in '2.5 Gen Tundras (2014-2021)' started by JPritch22, Jan 12, 2018.
  1. Mar 12, 2019 at 2:29 PM
    #91
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I got the glove box half off, but I got nervous when it came to screwing around near the airbag and I didn't want to mess with it too much. That's all I need is to create some fault in the SRS system and have to take it to the dealer. So I put it back together, and somehow have a screw left over and can't figure out where the heck it goes. If my current solution doesn't work and the glove box must come off, I suppose I can figure it out then. I really, really hope my zip ties worked....
  2. Mar 12, 2019 at 3:12 PM
    #92
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    no one has a sound bite / video of this issue?
    Its like a drone / resonance sound?
  3. Mar 12, 2019 at 4:23 PM
    #93
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Got it fixed!!! I went ahead and wrapped each tube with radiator hose cut to fit. I zip tied the hose on and zip tied the two tubes together. This eliminated the rattle/buzzing sound. Word of caution; these pipes get HOT!!
  4. Mar 12, 2019 at 4:41 PM
    #94
    Finch
    Finch New Member
    Donnie
    Virginia
    '16 Inferno CM 5.7L TRD Off-Road
    Cool! Where are you taking this picture from? The piece removed above the glove box?
    I've only had my truck a month now but heard a buzzing noise when a truck with a loud exhaust and a car with some bass drove by me. It sounded low or underneath the dash. I removed that lowest piece under the glovebox and found two dry crunchy leaves. Im thinking I was hearing those. If not, I'll do what you did.
  5. Mar 12, 2019 at 5:03 PM
    #95
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
  6. Mar 12, 2019 at 5:06 PM
    #96
    ardnutoz
    ardnutoz
    OZ
    SE-PA
  7. Mar 12, 2019 at 5:45 PM
    #97
    r1-superstar
    DB
    UTAH
    The blower motor has the blue and white sticker on it that reads 44. In my first picture, the metal in the left foreground is the part that the glovebox attaches to. The two silver tubes are going through the firewall. Both pics are taken looking straight in. All the plastic to the left is behind the center console of the dash.
  8. Mar 12, 2019 at 6:31 PM
    #98
    Finch
    Finch New Member
    Donnie
    Virginia
    Gotcha...thanks.
    r1-superstar[QUOTED] likes this.
  9. Mar 12, 2019 at 9:52 PM
    #99
    r1-superstar
    DB
    UTAH
    Keep us posted on your scenario and hopeful fix.
    Finch[QUOTED] likes this.
  10. Mar 13, 2019 at 2:04 AM
    #100
    Finch
    Finch New Member
    Donnie
    Virginia
    Will do.
  11. Mar 15, 2019 at 5:48 AM
    #101
    Max Power
    My tip zie solution did not work. Next up, take a friend out with me to confirm that these two pipes are what is causing the noise, and try the solution shown above. I won't give up!
  12. Mar 15, 2019 at 6:06 AM
    #102
    War Machine
    War Machine SSEM # 5 3MW
    Easy fix.
    bvia likes this.
  13. Mar 17, 2019 at 7:49 AM
    #103
    Max Power
    I just confirmed it, this is the issue I'm having as well. I popped the dash piece off and had a friend reach back there. When the buzzing was happening, he pushed on the metal tube he could reach and the buzzing stopped. Now i just have to figure out how to get the glove box off. I might just take it into the dealer and ask them to do it. They genuinely seemed interested in trying to fix the issue last time I was there but the truck wasn't making the noise at the time and they couldn't pin point the source.
  14. Mar 18, 2019 at 3:53 PM
    #104
    Max Power
    Took her into the dealer to get an opinion. The dealer said they'd need to be able to replicate the noise, verify that it's the heater tubes, and would then have to consult with Toyota on a fix.
    So I'll fix it myself. I can access the tubes with the kick plate below the glove box removed. I'm not going to put the radiator hose on, but I found heat stabilized nylon zip ties on Amazon that are rated for continuous use in temperatures up to 257F. It won't be hard to snake a zip tie up there and across both tubes, which will hopefully tighten things up and remove the tolerance/play that is allowing the buzzing. I'll update if this relatively simple solution winds up working.
    r1-superstar likes this.
  15. Mar 18, 2019 at 4:00 PM
    #105
    r1-superstar
    DB
    UTAH
    My buzzing/rattle has stopped for good. I'm glad you found it was the same thing as mine. Just be sure to only zip tie the tubes enough to stop the noise. I didn't want to put too much stress on the tubes.
    Max Power[QUOTED] likes this.
  16. Mar 22, 2019 at 8:30 AM
    #106
    Max Power
    Alright, I need tips. I cannot get a zip tie on, there just isn't room. My hand is all cut up from trying to make it fit into an area it shouldn't fit. The glove box is going to have to come off, there is no other way. I know about removing the lower right pillar, then the piece that snaps off on the far right side of the dash. I know to take the screws out of the glove box. What else is there to do? Last time I tried taking the glove box off, I wasn't sure how much was necessary to remove to get it to come off.
  17. Mar 22, 2019 at 4:58 PM
    #107
    r1-superstar
    DB
    UTAH
    All the above, plus take off the knee airbag, and whatever remaining screws you see holding the glovebox. Then pull it firmly toward you.
  18. Mar 27, 2019 at 5:40 AM
    #108
    Max Power
    I GOT IT! Didn't need to take the glove box off, either. It dawned on me, maybe I could get to the pipes by going through the panel where you put the air filter in the glove box. There was just enough room to snake my right hand in, and I was able to reach up from under the glove box with my left to get the zip tie wrapped around. Pulled her tight (but not too tight) and took her for a ride, and the noise is gone!!! This has tormented me for several thousand miles now.
    For anyone else that has a similar issue, the zip tie I used was purchased from Amazon and is a "heat stabilized" zip tie. Those pipes get very hot and I was concerned that a regular nylon zip tie would melt/warp. These ones are allegedly good for continual use in temperatures up to 257 F. Hopefully this is the last I have to deal with this superficial, albeit INCREDIBLY ANNOYING buzzing noise.
    VICTORY!!!
    TundraDude18, r1-superstar and B737 like this.
  19. Mar 27, 2019 at 6:16 AM
    #109
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  20. May 23, 2019 at 3:32 PM
    #110
    r1-superstar
    DB
    UTAH
    AWESOME!!!! Glad I could help.
  21. Jul 23, 2019 at 10:02 PM
    #111
    cbeatie
    cbeatie New Member
    2016 Tundra Platinum CrewMax
    Would anyone describe this as an almost ground loop type noise? Mine is most prevalent between 1800-2200rpm. Super high pitched and gone the second I'm off the gas.
  22. Aug 18, 2019 at 9:34 AM
    #112
    vanoss101
    vanoss101 New Member
    2015 SR5 Tundra DC
    Well I ended up solving my buzzing/hissing sound on my 2015. It wasn’t the ECM at all. It was the throttle body gasket! I know a lot of other guys have already found and performed this fix but I just wanted to update everyone because I was sure that the hissing (at 1,800 rpm under load) sound I was hearing had to be something inside the cabin. In reality it was coming through the intake. So all I did was pull the throttle body off, take the gasket out, and cut the metal screen off of it.
  23. Aug 19, 2019 at 4:54 AM
    #113
    Drew C
    Drew C New Member
    I had this issue too - the stealership corrected it for me. Took them a while to find it tho.
    vanoss101 likes this.
  24. Nov 9, 2019 at 10:26 AM
    #114
    Nortonja10
    Nortonja10 New Member
    Jarrod
    just did the same. No need to take the glove box off, just access small panel beside the air filter. Posting step by step pics. Take the 3 screws off the front of the glove box, that gives you more opening play to get your hand back on that small opening to access the pipes. Next, take the zip tie, run it under the pipe closest to you and take your hand and find the end and connect to the other end. His part is tricky but I just practiced closing the loop and connecting the ends with one have prior. Hope this and the pics help.
  25. Nov 9, 2019 at 10:56 AM
    #115
    Max Power
    There's at least a few of us having this annoying problem, I see. I few weeks back I got a private message on the forum from someone with the same problem, asking how exactly I fixed it as he must have wanted more specific information than is in this thread. I told him, and the zip tie solved the buzzing for him as well. This said, I had mentioned this to the service guys at my dealership, and they were baffled. After the problem got fixed, I told them what I did, just in case any other Tundra owners showed up with the same cryptic problem.
  26. Dec 5, 2019 at 6:41 PM
    #116
    Nortonja10
    Jarrod
    Ok so I took my Tundra to the dealer for an oil change and noticed my dash was slightly warped. Brought it up to the dealer and they said they would take a look at it, long story short they said they would replace it for free ($1200 parts and labor). Also I told them while they’re at it please check the metal tubes and ECU/ECM for buzzing at high rpms. They replaced the dash and drove it around after and no buzzing. Have come to the realization after driving about 50 miles after with no buzzing at all that it was not infact the metal tubes or ECM but was directly related to the dash. Don’t know if the clips or mounts were loose but whatever it was is gone now, no buzz or rattle. I would check the dash and surrounding area between and around dash first as something within the dash seems to be the issue.
  27. Sep 28, 2023 at 7:00 AM
    #117
    ljburns
    ljburns New Member
    I know this is an old post, but I wanted to say THANK YOU!!!!!!!!!! I have been driving with that damn buzz during cool/cold weather for over nine years. I found the loose washer/bolt, and have stuffed foam and anything that will dampen noise in any place that might vibrate or buzz. Nothing worked. I have searched the forum and web multiple times and somehow didn't see this post. Put the zip tie in place last night. No noise this morning at all. Cabin is completely quite for the first time in a while. I'm so happy.
