Autoloc auto window up and down project
Discussion in '2.5 Gen Tundras (2014-2021)' started by SiberianTundra, Mar 3, 2019.
  1. Mar 10, 2019 at 5:42 PM
    #61
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    SiberianTundra[OP] likes this.
  2. Mar 10, 2019 at 5:44 PM
    #62
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Great job man! I completely slipped on this one and forgot to order the part. Did you get the blue/green and yellow sorted out?
  3. Mar 10, 2019 at 6:12 PM
    #63
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Thank you! But these are all for drivers door. I am looking to make my passenger comfortable. So the wiring is for passenger side. None of the colors match the drivers side. However it is easy to tell what 2 wires are motor. Question is what are the other 3 wires for on passenger side.
  4. Mar 10, 2019 at 6:13 PM
    #64
    SiberianTundra
    Greg
    War Machine
    Not yet. After I looked at the wires. I mixed some JD and COke and played video games on my PC :D
  5. Mar 10, 2019 at 6:14 PM
    #65
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Ahahah...priorities! I love it
    Sunday Funday
  6. Mar 10, 2019 at 7:13 PM
    #66
    SiberianTundra
    Greg
    War Machine
  7. Mar 12, 2019 at 1:02 PM
    #67
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
  8. Mar 13, 2019 at 10:04 PM
    #68
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
  9. Mar 13, 2019 at 10:19 PM
    #69
    SiberianTundra
    Greg
    War Machine
    Still trying to figure out what wire goes where. But I know passenger can be done. It is only a few wires.
    Sas and WFD473 like this.
  10. Mar 14, 2019 at 9:02 AM
    #70
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Based on what I read on the camry forum it appears 2 of the other wires are from the master switch and 1 is constant 12v power. If the module uses load to determine when to stop the motor once closed it seems you would only want to tap into the wires to the motor and not mess with the other 3 wires, but I am really not too sure.
    I wonder how the Toyota OEM auto up/down works. Since we already have auto down it must be controlled by the ecm somewhere which makes me wonder if I replace the master switch on the drivers side with one from a sequoia or platinum tundra that has the extra feature can I turn on the auto up/down with techstream??? The auto down switch appears to have an extra mechanical function by pressing the switch all the way down to activate the auto down (clicks past a certain point to activate it), assume it would be same with auto up on the platinum switch?
  11. Mar 14, 2019 at 9:38 AM
    #71
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    For the record, I don't actually know how Toyota's auto up/down feature works. I'm just trying to take a logical stab at this. I'm guessing that the OEM auto up/down function sends a signal to the ECM to provide power to the window motor until a certain criteria is met (time frame, position sensor, etc). Since that may not be available for the passenger and/or rear windows then there would need to be a module that can 'fake' holding the up/down button long enough for the window to complete its action. I'm guessing that a module would either come pre-programmed for a certain time period or maybe have to be initially taught how long to activate. If the module has the capability to interpret a button with an auto up/down feature then you should be able to keep the ability to partially roll the window up/down. Otherwise you'll likely lose that capability.
    I would think that you could use a multimeter to figure out which wires do what and at least gain some insight as to how those functions are operating by measuring the voltage fluctuation when the up, down and auto features are activated on the Toyota button. From there you should be able to match up the aftermarket button's wires with Toyota's wires so you're sending a signal that Toyota expects and can interpret properly.
    Someone please correct me if this is incorrect.
  12. Mar 16, 2019 at 11:37 AM
    #72
    jtwags
    League City, TX
    2018 Tundra CM
    Sas and SiberianTundra[OP] like this.
  13. Mar 16, 2019 at 12:34 PM
    #73
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
  14. Mar 16, 2019 at 1:24 PM
    #74
    SiberianTundra
    Greg
    War Machine
    jtwags[QUOTED] likes this.
  15. Mar 16, 2019 at 3:22 PM
    #75
    jtwags
    League City, TX
    2018 Tundra CM
    I read through the manual and it appears if your vehicle did not come with the auto up feature then it would require more than a switch change. The motors with the "jam protection" are different than the motors without, which only have auto down for driver.
    Looks like this module is the easiest way to go. Looking forward to your install experience.
    Sas likes this.
  16. Nov 13, 2019 at 3:07 PM
    #76
    SiberianTundra
    Greg
    War Machine
    Ok now that my bumper is on and my killermat / noice is on its way to cover the doors for sound.
    Time to get back to auto up and down on front passenger side.
    Driver side seems to have way more switches and wires.
    Time to rip the skin of the door again.
    CO_Native, jaredmillerdvm and WFD473 like this.
  17. Nov 15, 2019 at 10:18 AM
    #77
    CO_Native
    CO_Native New Member
    Englewood, CO
    2019 MGM CM TRD Sport
  18. Nov 15, 2019 at 11:23 AM
    #78
    SiberianTundra
    Greg
    War Machine
    jeremyd, CO_Native and Sas like this.
  19. Feb 3, 2020 at 12:44 PM
    #79
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    #79
  20. Feb 3, 2020 at 7:17 PM
    #80
    SiberianTundra
    Greg
    War Machine
    No I did not. We need a ECU change for this to work. Easy to find auto up down switches. But ECU upgrade is required from a vehicle that has auto up down
  21. Feb 4, 2020 at 5:39 AM
    #81
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    So did anyone get this working?
  22. Feb 4, 2020 at 8:19 AM
    #82
    SiberianTundra
    Greg
    War Machine
    no. no one. However I still have my after market autoloc module I have not yet tried. Been to busy with stereo and other crap. I will be doing this. Not sure when. But due to my long project list it might be a few month or longer.
  23. Feb 4, 2020 at 12:54 PM
    #83
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    So, If I may intrude here, what are you all having trouble with getting these hooked up? you've peaked my interest as I'm an electrician. Just wondering what everyone is having so much trouble with on these things?
    jeremyd and SiberianTundra[OP] like this.
  24. Feb 4, 2020 at 2:33 PM
    #84
    SiberianTundra
    Greg
    War Machine
    I think mostly how to figure out what wire to hook up to. What wire drives the motors. I checked each door and coloring is unique.
    Now I will be starting with the passenger front side first. since it is only 1 switch and it is easy.
    However driver side has many switches and many wires. So for auto up down each switch would need to be wired.
    Rear doors I would do last.
    CO_Native likes this.
  25. Feb 5, 2020 at 3:17 PM
    #85
    SiberianTundra
    Greg
    War Machine
  26. Feb 6, 2020 at 6:06 AM
    #86
    Rebel Tundra Man
    Tyler
    Western Kentucky
    So according to what that guy in the video showed this is how it should be wired up. But I can’t verify that without having a multimeter and an actual switch set in front of me. Have you done that to see if that’s what is really going on?
    SiberianTundra[OP] and CO_Native like this.
  27. Feb 6, 2020 at 10:21 AM
    #87
    Rebel Tundra Man
    Tyler
    Western Kentucky
    And if that wiring is correct ^^ then that same wiring "pattern" should follow suit for the rest of the switches I would think.
  28. Feb 6, 2020 at 10:23 AM
    #88
    matictundra
    Franco
    AZ
    I would think this can be easily be verified with multimeter and operating the switch.
    Sas and Rebel Tundra Man like this.
  29. Feb 6, 2020 at 10:58 AM
    #89
    Rebel Tundra Man
    Tyler
    Western Kentucky
    It can. But I don’t know when I’ll be pulling my door panels again to check it. So somebody else that’s interested will have to do this.
  30. Feb 6, 2020 at 3:21 PM
    #90
    SiberianTundra
    Greg
    War Machine
    I will verify this weekend :)
    Thank you!
    This helps alot.
    So then I need to follow this
    matictundra likes this.
