Does the Bakflip MX4 rubber seal hold up over time?
Discussion in 'Tonneau Covers, Caps and Shells' started by cooper58, Sep 21, 2019.
  1. Sep 21, 2019 at 3:47 AM
    cooper58
    cooper58 [OP] New Member
    I'm looking to get a hard folding tonneau cover and really like the Bakflip MX4 for the low profile design and the ability to fold up closer to the cab for more bed access. I'm wondering how that weather seal that lays on the bed cap holds up to sun exposure and being folded up each time you open the cover compared to covers that sit on top the bed cap like the Rugged Cover Premium with a powder coated aluminum outter edge that still on top. It seems like that would be more durable in the long run than piece of rubber sitting on top like the MX4.
    OR18TRD likes this.
  2. Sep 21, 2019 at 5:22 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    ANY rubber and plastic exposed to direct sun will deteriorate with constant exposure. It doesn't matter if it's trim, weatherstrips, exterior, interior, Toyota's or Bakflip's. Preserve any rubber and plastic with frequent treatments of Aerospace Protectant 303 with UV inhibitors. Get the convenient wipes.
    619Tundra likes this.
  3. Oct 21, 2019 at 4:13 PM
    AYANG
    AYANG New Member
    Ontario, CA
    2016 Black Tundra Crewmax
    I’ve had mine for 3 years and it’s holding up fine
    OR18TRD likes this.
  4. Oct 21, 2019 at 4:26 PM
    Jota21
    Jota21 New Member
    i just put mine on, so i can't speak to longevity, but if you're referring to the gasket that you put on the bulkhead (top of the truck bed, closest to the cab), that foam strip is covered by that last section of the cover that doesn't fold up. No exposure to direct sun...[​IMG]
  5. Oct 21, 2019 at 4:34 PM
    Jota21
    Jota21 New Member
    oooooooooooooooh. gotcha. i have nothing to contribute then :)
    OR18TRD[QUOTED] likes this.
  6. Oct 21, 2019 at 5:36 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    I have mine for 2 years, so far so good
    OR18TRD likes this.
  7. Oct 21, 2019 at 5:48 PM
    gman31
    gman31 New Member
    New Orleans
    My MX4 leaks horribly since I first put it on. Waste of a $1000. My G2 worked great for years.
  8. Oct 21, 2019 at 8:46 PM
    AYANG
    AYANG New Member
    Ontario, CA
    Yeah same, where? I’ve had mine for 3 years and the only area that leaks is the tailgate area. The rest of the bed is nice and dry
  9. Oct 22, 2019 at 5:00 PM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    Same here, worst of the Bakflips I’ve had. My G2 leaked far less.
  10. Oct 22, 2019 at 5:25 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    My MX4 leaked like crazy. I was also surprised how quickly it dented. Screws rusted too. Junk. I got rid of it and got a Diamondback. So glad I made the switch.
    redhat[QUOTED] likes this.
  11. Oct 22, 2019 at 5:27 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I'm working on a solution. Almost there.
  12. Oct 22, 2019 at 5:42 PM
    gman31
    gman31 New Member
    New Orleans
    Everywhere. I first noticed it when I got caught in a light rain and there was water, a good amount, in the bed. So I took a house set on a fog pattern and lightly sprayed the sides. There was water leaking in like a water fall. I readjusted the bed cover and sprayed it again with the same results. I have a video but it won't load on this site. The water is literally constantly flowing in. I've posted a pic before on here in someone else's thread. I'll try to post some pics in this thread. Keep in mind, I expect these covers to leak a little on the corners, but for it to leak on the sides as much as mine does is ridiculous.
  13. Oct 22, 2019 at 5:47 PM
    gman31
    gman31 New Member
    New Orleans
  14. Oct 22, 2019 at 5:48 PM
    gman31
    gman31 New Member
    New Orleans
    Its the same on both sides.
  15. Oct 22, 2019 at 6:47 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Bak flip, side channels get clogged very easy, have to wash it like a gutter with a toothbrush, the channels only holds ⅛” of water, and the end cap that hold the drain tube cracks if you try to move things around and hit the tub. The lock is I joke, You could open it with a coat hanger. It’s ok for a weekend worrier that want a cover. But if you want a real cover I would recommend diamond back HD.
    Borgs likes this.
  16. Oct 25, 2019 at 8:24 PM
    Borgs
    Borgs New Member
    PA
    :eek:o_O :puke:
  17. Oct 25, 2019 at 8:25 PM
    Borgs
    Borgs New Member
    PA
    Agree. I was so frustrated with that $800 POS Bakflip.
    redhat likes this.
  18. Oct 28, 2019 at 8:57 AM
    AYANG
    AYANG New Member
    Ontario, CA
    Interesting.. mine only leaks in the tailgate area. I just washed my truck and double checked to see if any other areas leaked but nada.
  19. Oct 28, 2019 at 9:20 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Maybe you didn’t use your bed that much, when the hook that hold the pop rod start coming loose, that’s when it start leaking. They drill through the side rail that channel the water to put a hook in it, that’s a bad design
