Snow plow questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by 68 RS/SS, Aug 31, 2019.
  1. Aug 31, 2019 at 2:24 PM
    68 RS/SS
    68 RS/SS [OP] New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I recently traded in my 16 2500hd that i had an 8’ fisher hd2 on. I kept the plow blade. I bought a 19 limited dc that I want to put the plow on. What are you guys using beside timbrens in the front end? I only plow my driveway and my parents, no commercial use. Thanks
  2. Aug 31, 2019 at 3:24 PM
    longbedlife
    longbedlife New Member
    New England
    2020 DCLB
    I've run a 7.5' Fisher SD on two Tundras. I'm sure your plow weighs a bit more than mine but both of my trucks handled it fine completely stock. I am running Bilstein 6112s now and the weight of the plow is even less noticeable. I think the upgraded bump stops can't hurt but your money is probably better spent on shocks and springs IMHO
    JoshuaA, Black Wolf and BestGen like this.
  3. Aug 31, 2019 at 5:06 PM
    68 RS/SS
    MIke
    New Hampshire
    2020 TRD Sport DC
    Agreed. Did you just add shocks?
  4. Aug 31, 2019 at 6:01 PM
    longbedlife
    New England
    2020 DCLB
    The Bilstein 6112 is actually shock and spring combo. They have adjustable spring perches so you can add some lift as well. I run mine at the max height. I also did the Bilstein 5160 struts in the rear and Toytec shackles to lift the rear (I wanted to keep the factory rake), but you could do just the front. There are some other options out there as well with different spring rates that may be even better suited to the weight of the plow, so you might want to check around a little
  5. Aug 31, 2019 at 11:27 PM
    68 RS/SS
    MIke
    New Hampshire
    2020 TRD Sport DC
    I’ll probably end up doing the same in combination with the timbrens. I looked into OME springs and struts as well but I’ve read the heavy springs ride horribly unloaded. How does yours ride with no plow?
    longbedlife[QUOTED] likes this.
  6. Sep 1, 2019 at 6:25 AM
    longbedlife
    New England
    2020 DCLB
    It's stiffer, but subjectively "better" overall than stock, I think. I will probably do the same setup again on my next truck.
  7. Sep 1, 2019 at 6:34 AM
    Aurora CO
    There are three different OME coil springs to choose from depending on use.
  8. Sep 1, 2019 at 9:12 PM
    68 RS/SS
    MIke
    New Hampshire
    2020 TRD Sport DC
    I’m well aware of that. I think Bilstein is a bit cheaper
  9. Sep 5, 2019 at 12:40 PM
    longbedlife
    New England
    2020 DCLB
    I put my truck up for sale so I took some pics today, figured I might as well post them here
    Here's how little it sags with the weight of the plow on stock suspension
    This is with no ballast either, and I think Fisher calls for around 150lbs
    Mountun Goat likes this.
  10. Sep 5, 2019 at 1:04 PM
    68 RS/SS
    MIke
    New Hampshire
    2020 TRD Sport DC
    Excellent, thank you. I actually ordered 6112’s for mine. I found out fisher has no wiring figured out for the led lights yet too so that kind of sucks
  11. Dec 3, 2019 at 2:54 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    After these past two storms I'm thinking about a small plow, I like the idea of those ones that appear to be made out of a clear plastic and reenforced by metal behind, typically seen on mid size trucks or jeeps, I just want it to do a few driveways. Any recommendations and what I'd be looking at cost wise?
