Pinay's Build...
Discussion in '2.5 Gen Builds (2014-2021)' started by Pinay, Jun 20, 2019.
  1. Aug 2, 2019 at 9:52 PM
    #211
    Pinay
    Pinay [OP] New Member
    Monet
    Mahal kita Kuya
    Yeah well Ford guys would make a song like that featuring their trucks lol
    Rica25 likes this.
  2. Aug 2, 2019 at 9:55 PM
    #212
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    True but I cant lie I laughed
    Pinay[QUOTED][OP] likes this.
  3. Aug 2, 2019 at 9:59 PM
    #213
    Pinay
    Monet
    Mahal kita Kuya
    You'd be weird if you didn't!
  4. Aug 3, 2019 at 1:57 PM
    #214
    Sunnier
    Sunny
    San Diego, CA
    You did a great job with this. Thanks for posting detailed pics, including the holes drilled in to hold the hooks, and the gauge of bracket that bent. :thumbsup:
  5. Aug 3, 2019 at 3:44 PM
    #215
    Pinay
    Monet
    Mahal kita Kuya
    Thanks Sunny! I knew you’d appreciate the details!
    I didn’t know I could get bigger gauge brackets, just eyed one I thought would do the job, so I will be heading back to Ace!
    Sunnier[QUOTED] likes this.
  6. Aug 3, 2019 at 3:52 PM
    #216
    Sunnier
    Sunny
    San Diego, CA
    Yeah, I think so. If not at Ace, ask there, and they’ll probably direct you to a local supply. Looks great though; you did well!
  7. Aug 3, 2019 at 4:08 PM
    #217
    Pinay
    Monet
    Mahal kita Kuya
    Thanks! Just need to figure out pulling the rope without knots for better grip. Amazon search!
  8. Aug 5, 2019 at 12:37 PM
    #218
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    This is what I used.... But mounted the opposite direction.
    Sunnier and Pinay[QUOTED][OP] like this.
  9. Aug 5, 2019 at 12:44 PM
    #219
    Pinay
    Monet
    Mahal kita Kuya
  10. Aug 5, 2019 at 12:46 PM
    #220
    Pinay
    Monet
    Mahal kita Kuya
    Kids should know better than to one-up you!
    Rica25 and Racingjohndeere55 like this.
  11. Aug 5, 2019 at 12:52 PM
    #221
    DividedSky
    Jeff
  12. Aug 8, 2019 at 7:43 AM
    #222
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    Awesome setup. Thanks for the lift idea. Hauling dirtbikes and having an RTT doesnt work too well. This lift would be a great help. Thank you!
    Pinay[OP] likes this.
  13. Aug 8, 2019 at 7:47 AM
    #223
    Pinay
    Monet
    Mahal kita Kuya
    You bet! And you are close enuf that it is not unreasonable to go to Vegas and have Matt at @M C M set you up!
    M C M likes this.
  14. Aug 8, 2019 at 8:55 AM
    #224
    ESTundra937
    Eddie
    San Diego
    Im already an MCM customer. Just installed some of Matt's UCA's..bitchin control arm. Will be back for more :thumbsup:
  15. Aug 8, 2019 at 8:22 PM
    #225
    Pinay
    Monet
    Mahal kita Kuya
    Update:
    Do-over on the recent RTT lift project; it has now turned into a dolly / lift project, thanks again to the idea from Jeff @DividedSky !!
    Now using heavy-duty shelf bracket from Home Depot, load capacity is 600lbs.
    Heavy-duty mover’s dolly from Harbor Freight, load capacity of 1,000lbs.
    I place the brackets along the edge but sorta in the middle of the bottom horizontal length. Also I am now using an eye bolt for the pulley to attach to.
    I used a cut piece of wood to hold up the long piece being used as a railing, at first up the ground and inch...
    ...end up propping the rail up higher.
    You will notice the carpeted area has a gap of an inch; later I will use another cut piece of wood in this center gap area, that way I can utilize the end hole of the bracket and screwing it all together, providing more stability and strength.
    I decided to use a 5-inch corner bracket for more support, after finding the rails were wanting to move side to side, left and right in the following pic.
    The HD shelf bracket with the corner L-bracket gives so much more stability!
    Finished piece with bracing up along the rail. Attaching this way, instead of a shorter piece in the middle, feels more stable.
    Cut piece of 1-inch piece of wood in between carpeted ends and under the end hole of HD shelf, screwed in providing strength and stability!
    Pulley attached, ready to go on bed rack.
    At this point I have not cut the length of the side rails, still at 8 foot. First go around I cut too much and thought I’d try full length to get the RTT slid on the rack better. Only downfall is getting entire piece rolled and stored in garage: I can get it in on an angle to clear garage door and some rafters.
    I did not load it on but I can tell the difference from the first attempt; this design being more stable and functions so much better!
    Thanks Jeff for the idea, and also motivation on coming up with some improvements!
    Feel free to copy or ask questions!!
  16. Aug 8, 2019 at 8:37 PM
    #226
    Sunnier
    Sunny
    San Diego, CA
    That day Monet started calling other member names, just because :rolleyes:.
    15whtrd and Pinay[QUOTED][OP] like this.
  17. Aug 8, 2019 at 8:40 PM
    #227
    Pinay
    Monet
    Mahal kita Kuya
    :angrygirl: And i always proofread before posting! :rofl: Get lazy on a day off of work! :humble:
  18. Aug 9, 2019 at 11:54 AM
    #228
    DividedSky
    Jeff
    Looks GREAT
    Sunnier and Pinay[OP] like this.
  19. Aug 16, 2019 at 9:02 AM
    #229
    Pinay
    Monet
    Mahal kita Kuya
    Anyone stuck and need a winch?? :smokertransformer:
    Bumpers install set for Aug. 28!!!
    Rica25, ChadsPride, 15whtrd and 4 others like this.
  20. Aug 16, 2019 at 9:22 AM
    #230
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Truck looks really bad ass even tho its black(slowest color)
    Rica25, jewsNbrews and Pinay[OP] like this.
  21. Aug 16, 2019 at 9:24 AM
    #231
    Pinay
    Monet
    Mahal kita Kuya
    Fixed it for ya! :fistbump:
  22. Aug 16, 2019 at 9:49 AM
    #232
    Pinay
    Monet
    Mahal kita Kuya
    jewsNbrews and T-Rex266 like this.
  23. Aug 16, 2019 at 11:23 AM
    #233
    TheBeast
    TheBeast The Beach
    new tires too ? :spy::spy:
  24. Aug 16, 2019 at 11:30 AM
    #234
    Pinay
    Monet
    Mahal kita Kuya
    Ha! I told Steve to give em to me!! And he said if I do need tires they could get em for me! I'm ok for now! Whew!
    jewsNbrews and TheBeast[QUOTED] like this.
  25. Aug 16, 2019 at 12:27 PM
    #235
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Ask me what? I'm lost lol
  26. Aug 16, 2019 at 12:34 PM
    #236
    Pinay
    Monet
    Mahal kita Kuya
    Saw you on the thread earlier, just saying welcome, sit and hang out anytime!
  27. Aug 17, 2019 at 6:18 AM
    #237
    ChadsPride
    ChadsPride New Member
    Austin, TX
    :muscleflexing:
  28. Aug 17, 2019 at 10:02 AM
    #238
    Pinay
    Monet
    Mahal kita Kuya
    Gettin closer, Chad!! Bumpers should be in in T- 11 days!! :goingcrazy:
    Take my money while I still have it!! :angrygirl:
  29. Aug 17, 2019 at 4:20 PM
    #239
    ChadsPride
    Austin, TX
    :woot:
  30. Aug 17, 2019 at 4:28 PM
    #240
    Shukidevdas
    Shukidevdas New Member
    Amit
    Southern California
    2020 Tundra Platinum CM 4x4
    Awesome build Monet! Can't wait to get my tundra, build, go on adventures and make some memories like you! #inspired
    Sunnier, ChadsPride and Pinay[OP] like this.
