Noise while truck stops and goes help!
Discussion in '2.5 Gen Tundras (2014-2021)' started by P1pes1337, Jul 6, 2019.
  1. Jul 6, 2019 at 8:59 PM
    P1pes1337
    P1pes1337 [OP] New Member
    Josh
    2016 blazing blue pearl sr5 crew
    Leveled on 33x12.50R20
    When I accelerate and then stop right as you let off the brake and re apply , I hear a hissing ,scrapping type noise . I was thinking brake pads however they are new.
    Tires new/ mounted balanced.
    Still can’t confirm the location.
    Was thinking dust shrouds maybe so I bent them back a hair on each wheel noticed no differences in the sound .
    Was thinking maybe sticky a caliper ?
    I really want to find out what this is as we all know , little noises on our trucks drive us crazy m I right ? Any input would be great please thank you all.
  2. Jul 6, 2019 at 10:20 PM
    Just at start up or?
  3. Jul 7, 2019 at 8:49 AM
    P1pes1337
    Josh
    When you go stop and then drive off .
    Once you’re above 20 mph you can’t hear it anymore
  4. Jul 8, 2019 at 11:33 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Exhaust Dirty Deeds 8”SS, some led lights, Osram headlights, Pro Stop brakes, Pop Lock, AFE dry air filter with charcoal delete.
    I think what may be happening is were brake pads slide back-and-forth in the caliber there may be dirt, grease and grime in the brake caliber. When you release the brakes, the brake pads aren’t fully retracting and are rubbing the rotor making the noise. Used a brass brush to clean it and applied a very small amount of caliper grease. Also the two slide pins may need to be cleaned with a Scotch Brite pad and a little lube as well. See my pic. good luck hope this helps.
    P1pes1337[QUOTED][OP] likes this.
  5. Jul 8, 2019 at 11:46 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    New Noise with new pads and rotors? Or did not replace rotors?
    My napa rear rotors hit the inner lip on the dust shield (no amount of pushing the outer plate will help stop the noise) made an awful noise until it rubbed that area off.
    P1pes1337[OP] likes this.
  6. Jul 8, 2019 at 12:08 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    definitely something to do with brakes, calipers, etc
