Can I run stock 20s with 33x12.50s and clear upper control arm?
Discussion in 'Wheels & Tires' started by hunterpedrick6, Jun 30, 2019.
  1. Jun 30, 2019 at 4:01 PM
    hunterpedrick6
    hunterpedrick6 [OP] Hunter Pedrick from Quitman ga
    Hunter
    Quitman,ga
    2019 Toyota Tundra trd off-road sport white
    I have have stock 20s wanting to run. 33x12.50r20 will it clear upper control arm I have ranch hand full replace I’m not worried about height because I know it will clear with 3/1 lifting kit that have on it I ran nitto trail grapplers 295/70r18 before with no problems. I’m worried that there going to be to wide. Thought about going with a very small spacer that will fit over factor stubs. Please help me out.
  2. Jun 30, 2019 at 4:19 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No you cannot. They will hit.
  3. Jul 1, 2019 at 10:40 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    Well dang what is my options than....
  4. Jul 1, 2019 at 10:43 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I think you'll be ok with wheel spacers.
  5. Jul 1, 2019 at 10:44 AM
    619Tundra
    Maybe 33 X 11.5 wide?
    sundance likes this.
  6. Jul 1, 2019 at 10:46 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    I’ve ran 295/70r18 before with no problems. But they don’t make a mudd grappler In that size. It’s either 33x12.50 or 35x12.50
  7. Jul 1, 2019 at 11:01 AM
    Danman34
    Danman34 New Member
    Danny
    The sport 20s have a higher offset than the factory 18s do, which means less clearance for wide tires. A 285 is about as wide as you can go on the sport 20s without adding spacers. This is why I ultimately bought new lower offset wheels for mine and sold the stocks.
  8. Jul 1, 2019 at 11:07 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    I wonder if I got aftermarket control arms?
  9. Jul 1, 2019 at 11:09 AM
    Danman34
    Danman34 New Member
    Danny
    That would probably be worse. It’s not the uca that are the problem, it’s the wheels and the high offset that places the center line of the wheel close to the hub. You need a lower offset wheel to push the face of the wheel away from the hub, hence giving you the clearance from the UCA.
    JoshuaA likes this.
  10. Jul 1, 2019 at 11:10 AM
    Danman34
    Danman34 New Member
    Danny
    This will help explain high offset vs low offset and how you gain clearance from suspension components with offset change.
    JoshuaA likes this.
  11. Jul 1, 2019 at 11:50 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    no, you will rub.
    here are 295/55/20's (about 12 inches wide) and they are about 1/4 inch from the UCA:
  12. Jul 1, 2019 at 11:53 AM
    MSbowhunter48
    MSbowhunter48 New Member
    2011 White Tundra Rock Warrior Edition
    Fat Bob’s 3/1 Leveling kit Rock Warrior Wheels 317/70R17 Cooper AT3 XLT
    Get 1” bora spacers and you’ll be good to go. Or get skinnier tires, your call.
    619Tundra likes this.
  13. Jul 1, 2019 at 11:58 AM
    Danman34
    Danman34 New Member
    Danny
    And this is with a +50 wheel. The Sport wheels are +60, making it worse.
  14. Jul 1, 2019 at 12:12 PM
    15whtrd
    15whtrd Mr. Blonde
    I was almost positive that the stock TRD 18’s are +60 as well.
  15. Jul 1, 2019 at 12:30 PM
    Danman34
    Danman34 New Member
    Danny
    Hmm. I think you may be correct.
    15whtrd[QUOTED] likes this.
  16. Jul 1, 2019 at 12:31 PM
    15whtrd
    15whtrd Mr. Blonde
    But the 17” rock warriors, if I remember correctly are +50. So you are part right!
    JoshuaA and Danman34[QUOTED] like this.
  17. Jul 1, 2019 at 12:35 PM
    Danman34
    Danman34 New Member
    Danny
    Haha. Sweet! I’ll take it. My 295/55s are actually 12.2” wide. When I measured the gap between the stock 275s and the UCA....there would have been like 1/32” of clearance . Good excuse to get new wheels! Lol
  18. Jul 1, 2019 at 1:09 PM
    15whtrd
    15whtrd Mr. Blonde
    It would be cool to find a different offset stock 18 because I like the way they look. I wish they were like +40. Then I can put the width tires that I like and have them sitting in the fender where I would prefer.
  19. Jul 1, 2019 at 3:29 PM
    hunterpedrick6
    Hunter
    Quitman,ga
    Well I have 2 options the wheel spacer , off set rims...... guess there is no after market upper control that will let you run a wider tire.
  20. Jul 1, 2019 at 4:28 PM
    Danman34
    Danman34 New Member
    Danny
    New wheels. New UCAs are for added camber adjustments you can’t get with stock. Most aftermarket are bigger than oem.
  21. Jul 1, 2019 at 5:18 PM
    Netmonkey
    Georgetown, TX
    yes, it is a 20x9 +50mm offset.
  22. Jul 1, 2019 at 6:10 PM
    MSbowhunter48
    If you’re still worried about hitting the UCA, you won’t be close with that offset. But going that far out with a 12.5” wide tire may put you close to the body mount. Hopefully someone else can give you a better answer.
  23. Jul 1, 2019 at 6:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I could not agree more. Thats why i love the 1.25 wheel spacers with the oe trd wheels
  24. Jul 2, 2019 at 3:06 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    Okay well what wheel spacer is the best I don’t my wheel and tire rolling down the road in front of me.
  25. Jul 2, 2019 at 3:32 AM
    MSbowhunter48
    BORA and Spidertraxx are the only two brands I would run.
    15whtrd and JoshuaA like this.
  26. Jul 2, 2019 at 3:33 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    I just need someone to clear this up for me what do I need to run 12.50 please get what off set rim do I need or what wheel spacer.
  27. Jul 2, 2019 at 4:27 AM
    MSbowhunter48
    If you are wanting to stick with the stock wheels then a 1” spacer will put you around +35 offset, 1.25” spacer will put you around +30 offset, 1.5” spacer will put you around +25 offset (all good for getting tire away from uca).
    If you’re going the aftermarket route, then look for any wheel in the +18 to +35 offset range. Those tend to be the sweet spots on these trucks with 12.5” tires.
  28. Jul 2, 2019 at 5:06 AM
    hunterpedrick6
    Hunter
    Quitman,ga
    Can I run a 295/60r20? Or is it still to wide?
  29. Jul 2, 2019 at 5:41 AM
    Danman34
    Danman34 New Member
    Danny
    295/60/18? I don’t think anybody makes a tire that size...
  30. Jul 2, 2019 at 6:27 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Think he means 295/60R20. I’d check the specific tire specs too as it may vary from the standard 33.9x11.6
