Exhaust question.
Discussion in 'Performance and Tuning' started by Rex Kramer, May 24, 2019.
  1. May 24, 2019 at 7:26 AM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    Would I benefit from, and is there room to add an H or X pipe
    to a Dirty Deeds stainless 10" cat-back system for the RCSB?
  2. May 24, 2019 at 7:38 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    X-pipe: Mid-pipes built with a crossover, or "X" shaped design, purposely cross exhaust streams to even out flow and streamline exhaust gasses through the rest of the system. ... H-Pipe: An H-pipe is better at balancing sound and produces a more consistent, classic muscle car growl.
    How this old school generalization correlates with a computer dependent 5.7 is relative to the user..
    Many have said other exhaust systems sound better than stock but torque seemed lost. Others say their Tundra turned into a rocket.
    You need an exhaust guy to chime in.. Or maybe a high performance crowd.
    Will you dyno it?
    Larger intake?
    Tune?
    What's your primary objective?
    Rex Kramer[OP] likes this.
  3. May 24, 2019 at 7:41 AM
    Rex Kramer
    Georgia
    No dyno.
    Stock intake.
    DAP tune.
    Primary objective: increased low RPM Torque without drone, or being louder than stock.
  4. May 24, 2019 at 7:42 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Keith would be the man to ask:pccoffee:
    dirtydeeds likes this.
  5. May 24, 2019 at 7:46 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    No it wouldn't if you have a y pipe
  6. May 24, 2019 at 7:50 AM
    Rex Kramer
    Georgia
    I believe the X pipe is more beneficial when the engine stays in the higher RPM range, and the H pipe is more for the lower RPM range typically used on the street.
    The H pipe sounds perfect for my needs.
  7. May 24, 2019 at 7:51 AM
    Rex Kramer
    Georgia
    Where is the Y pipe?
    I don't believe I have one.
  8. May 24, 2019 at 8:58 AM
    Rex Kramer
    Georgia
    Keith is welcome to comment...
  9. May 24, 2019 at 9:02 AM
    owb2gp
    owb2gp New Member
    ID
  10. May 24, 2019 at 9:38 AM
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    I thought you were getting Keith's system that hooks to your stock tailpipe ? If so it has a y-pipe which in that case there is no benefit to an x pipe. If you are doing a true duel system meaning two tailpipes than yes the x-pipe would keep your low end torque.
  11. May 24, 2019 at 9:43 AM
    Rex Kramer
    Georgia
    Okay, that's the information I was looking for - thank you!
  12. May 24, 2019 at 11:25 AM
    CMB
    CMB New Member
    Cecil County MD.
    Keith built my Brother a DUAL System that's as quiet as my 10" single. I'm sure he mentioned an X-Pipe being part of the package.
  13. May 27, 2019 at 2:42 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    If you’re running a single exhaust on a tundra then you have a Y pipe and don’t need an X pipe.
    If you have a dual exhaust, trust me, you want an X pipe. It builds better low end torque. And, on a tundra, better sound.
  14. Jul 7, 2019 at 6:15 AM
    Falconsfan
    Falconsfan New Member
    Southern Ohio
    Is there any difference/advantage to X pipe vs. H pipe? Would one be easier on my installer than the other?
