What lift is good enough?
Discussion in 'Suspension' started by Brocksw, Mar 23, 2019.
  1. Mar 23, 2019 at 6:28 PM
    Brocksw
    Brocksw [OP] New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    So I've been comparing the bilstein 5100 and the ome 612 for my 12' DC. Using my stock 18" rims and trying to make room for a 285/75r18 tire... Currently have 275/75r18 duratracs.
    Everything I've researched says the 285/75r18 will fit with either lift with the obvious performance benefit in the OME.
    However, do I actually need the Ome? I'm not Baja racing, I'm not climbing rocks in a jeep. I'm driving rough mountain trails and going over bumps and deep ruts on Prairie trails while I'm out hunting. I've done a little damage to my truck doing those things, but those are issues of clearance not shock performance/travel.
    Is the 5100 good enough? What type of offroading or performance needs would warrant paying extra for the Ome 612?
    Thanks!
  2. Mar 23, 2019 at 7:23 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I’m running ome front coil overs on my 2002 tundra and the bilstein 5100’s on my 2007 tacoma with stock coils. I’ve got the bilsteins on the top perch. The ome lift is nice no doubt, but in my opinion the 5100’s ride just as good. From my experience with both, I wouldn’t spend the extra money.
  3. Mar 23, 2019 at 7:27 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I think for your use the OME or even something like 6112/5160 would be better options. The 5100s are basically the stock TRD shocks with option to level up front.
  4. Mar 23, 2019 at 7:28 PM
    Aurora CO
    I have the OME 614 setup which is perfect for all the old mining roads I hit here in CO. The OME 's aren't designed for Baja racing. Well worth the $.
  5. Mar 23, 2019 at 7:31 PM
    All of it
  6. Mar 23, 2019 at 7:33 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Take the extra money you’d save going with the bilstein shocks and get you some spc upper control arms.
  7. Mar 23, 2019 at 7:37 PM
    Aurora CO
    Not going to save that much...SPC's now list for $640 and keep in mind the OME 's are specifically tuned for the Tundra unlike the 5100's.
  8. Mar 23, 2019 at 7:42 PM
    Brocksw
    To get the ome (front and rear) plus the toytec shackle would actually be less money than the 5100(front and rear) plus a shackle plus a UCA.
    Black Wolf likes this.
  9. Mar 23, 2019 at 7:43 PM
    Brocksw
    I'm trying to avoid a UCA
  10. Mar 23, 2019 at 7:46 PM
    Aurora CO
    I still have my stock uca's. Will upgrade to SPC 's at some point but have decent alignment so no rush.
  11. Mar 23, 2019 at 8:00 PM
    Brocksw
    What do the OMEs really give me that the 5100 won't? I belive clearance is what in after... hitting a hole in a Prairie trail going a little to fast is about as hard as I'll push the actual shock. I won't be in many situations ever that require any heavy articulation.
  12. Mar 23, 2019 at 8:02 PM
    Aurora CO
    Plus.....ToyTec discount...
    ....then go with the Bilsteins.
  13. Mar 23, 2019 at 8:02 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I’m learning, I’m learning, you guys are definitely the experts on current tundras. I’ve got older s**t:D seriously it sounds like you can’t go wrong with any of those options y’all have mentioned. But I guess the 5100’s are kinda on the bottom of the totem poll for current gen tundras. Don’t know if the op looked yet, but you could also consider the toytec eibach lift kit.
  14. Mar 23, 2019 at 8:05 PM
    Brocksw
    For the price of the eibach I think im better off with the OME
  15. Mar 23, 2019 at 8:06 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
  16. Mar 23, 2019 at 8:07 PM
    Brocksw
    What toytec discount?
  17. Mar 23, 2019 at 8:09 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
  18. Mar 23, 2019 at 8:09 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    How much lift do want to achieve?
  19. Mar 23, 2019 at 8:11 PM
    Brocksw
    Enough to fit the tire... Ome 612 would get me about a half inch over the 5100 on the top setting.
  20. Mar 23, 2019 at 8:16 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Absolutely! A lot of members are running them @ mid setting or 1.9". I have that setup, but I'm running @ top setting with 1" tapered block in rear
  21. Mar 23, 2019 at 8:17 PM
    CCLJ03
    Craig
    @rons23
    Does the block in the rear affect the ride though? And are those rear shocks made to work with 1" rear blocks?
  22. Mar 23, 2019 at 8:18 PM
    Brocksw
    Talk about hijacking a thread.
  23. Mar 23, 2019 at 8:20 PM
    rons23
    Ron
    Kill Devil Hills
    No and Yes. But if you set them @ 1.9" you don't need the block. I needed something in rear to compensate for max setting up front
  24. Mar 23, 2019 at 8:22 PM
    rons23
    Ron
    Kill Devil Hills
    Sorry @Brocksw, you would be in good shape with either of those setups Ome or 6112/5160,5100
  25. Mar 23, 2019 at 8:23 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Well hell, all the more reason to get the ome lift. That 1/2 inch can make a huge difference when it comes to stuffing tires. If you’ve got the budget, go ahead and get the uppers. Do it once and be done.
  26. Mar 23, 2019 at 8:23 PM
    CCLJ03
    Craig
    @Brocksw You think so? Just conversing about a lift system that has been talked about since the first response...?
    @rons23 I need to measure my wheel wells, but you think I'd still have rake even after raising the front 2"?
  27. Mar 23, 2019 at 8:25 PM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    Like @Grey Wolf said, OME with 614s rear Dakar spring pack and greaseable shackles with SPC UCAs. Then again I am kind of biased. The last 4 or 5 lifts that I have had, has been OME. Great on the road, the trail.
    Black Wolf and Brocksw[OP] like this.
  28. Mar 23, 2019 at 8:28 PM
    rons23
    Ron
    Kill Devil Hills
    You could have a little bit of rake, more closer to level. You can always add a block, or shackles if need be.
  29. Mar 23, 2019 at 8:32 PM
    CCLJ03
    Craig
    Thanks Ron!
  30. Mar 23, 2019 at 8:41 PM
    rons23
    Ron
    Kill Devil Hills
    Anytime Craig, theres a dedicated thread for the 6112's, I tried copying text, but it's not working. You could put 6112 in the search box @ top and you will see it a few threads down
    CCLJ03[QUOTED] likes this.
