Colorado BS Thread
Discussion in 'Colorado' started by T-Rex266, Jan 6, 2014.
  1. Sep 13, 2016 at 4:37 PM
    #481
    T-Rex266 [OP] Elon approved Staff Member
    Tacogeuse likes this.
  2. Sep 13, 2016 at 6:28 PM
    #482
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Bring it on in, I'll align it
    bandit and T-Rex266[OP] like this.
  3. Sep 15, 2016 at 6:28 AM
    #483
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    @LOTSOFTOYS has also aligned my truck. He does an awesome job. Highly recommended.
    T-Rex266[OP] likes this.
  4. Sep 15, 2016 at 8:09 AM
    #484
  5. Sep 16, 2016 at 1:24 PM
    #485
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Colorado brethren. Anyone know of some easy off road trails, that are not too far from Denver (<2 hr drive), that are good for a Sunday fall drive to check out the fall colors? (and yes, I like doing that and I have a Starbucks Pumpkin Spice Latte with me at the same time. Judge me if you must!:rofl:)
    Wanna get away from the crowds and avoid popular spots (unless it is a must do trail). Let me know if you know of some good spots. Thanks in advance.
    zcarpenter92 and T-Rex266[OP] like this.
  6. Sep 16, 2016 at 1:38 PM
    #486
    Which malls are we considering? :stirthepot:
    JC303 likes this.
  7. Sep 16, 2016 at 1:47 PM
    #487
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    @COMiamiFan you could try hall valley rd off of 285, deer creek or st. John trail near Montezuma Rd. / Keystone. Your Starbucks will taste better in the altitude. :cheers:
    T-Rex266[OP] and TXMiamiFan like this.
  8. Sep 16, 2016 at 1:49 PM
    #488
    TXMiamiFan
    Jose
    Outlet mall in Silverthorne. Scenic enough. :laugh:
    T-Rex266[QUOTED][OP] likes this.
  9. Sep 16, 2016 at 7:27 PM
    #489
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    When u coming in?
  10. Sep 16, 2016 at 8:01 PM
    #490
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    https://www.tundras.com/threads/middle-st-vrain-lyons-co.6866/
  11. Sep 17, 2016 at 12:33 PM
    #491
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Go up bill more lake. I bet u can make it with out pinstripes
    Tacogeuse and T-Rex266[OP] like this.
  12. Sep 18, 2016 at 1:13 PM
    #492
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
  13. Sep 18, 2016 at 5:30 PM
    #493
    TXMiamiFan
    Jose
  14. Sep 18, 2016 at 5:52 PM
    #494
    Tracker
    Tracker New Member
    Shane
    This is from a Ford Dealer lol
  15. Sep 20, 2016 at 12:20 PM
    #495
    GTABurnout
    GTABurnout New Member
    New to Durango Area, With winter coming Looking for advice on chains and over all what I need to be prepared. I drive from Durango to Farmington for work leave around 5:30-6am return around 5pm.
    Should I have a set of chains in the truck? Chains or cables? Truck is 4X4 and should be on some new 315 K02's soon. I plan to put some weight in the bed. Any advice would be awesome I am from Arizona where we see snow on the local Mt. once or twice a year.
  16. Sep 20, 2016 at 12:40 PM
    #496
    8 years strong and never had to use chains. Know how to drive in the snow first.
    There may be certain highways that require chains to keep going and the chain Las will go into effect. If you plan on being on a busy highway that may require them (i70, for example) bring them just in case.
    Plenty of suggestions for new snow drivers...one being- if you're at a light and it's now green, do NOT go. Wait a few seconds and look both ways multiple times.
    4x4 does not mean better stopping. There may be a time where you'll need to run the red vs trying to stop (you'll spin out)
    If you ever find yourself in a spinout, look at where you want to go; not where you don't (pole, car, etc) don't want to go. Practice this in a empty parking lot.
    I can keep going :D
    zcarpenter92 likes this.
  17. Sep 20, 2016 at 7:43 PM
    #497
    TXMiamiFan
    Jose
    Assuming you know not to be in 4x4 high when making slow turns. Trucks don't like that ;)
    Tundras handle great I the snow. Sounds like you have good tires coming too. + what Sean said and you'll be aiight.
  18. Sep 21, 2016 at 7:29 AM
    #498
    kemosabee
    kemosabee New Member
    James
    Pagosa Springs
    07 Tundra
    I drive from Pagosa to Durango every M-F, I have studded snow tires but I also deal with a lot more snow than you would. I would make sure that you have weight in the back so it doesn't get squirrely. From my experience with the area you might need chains\studded tires once a winter season going down 550.
  19. Sep 22, 2016 at 5:18 PM
    #499
    Solid choice!
  20. Sep 22, 2016 at 5:20 PM
    #500
    What year Tundra do you have? You don't have any specs listed.
  21. Sep 22, 2016 at 7:02 PM
    #501
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Man, going through this thread makes me want to move to CO.
  22. Sep 22, 2016 at 7:25 PM
    #502
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I bet Arizona's winters are a lot nicer than ours lol.
    GTABurnout likes this.
  23. Sep 27, 2016 at 7:29 AM
    #503
    GTABurnout
    But Colorado Summers kick the crap out of AZ summers.
  24. Sep 27, 2016 at 9:39 AM
    #504
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Oh I'd believe that! I know a few rich farmers up on the NE plains that head to AZ the minute corn harvest is done in the fall, then come back once it starts warming up.
  25. Sep 27, 2016 at 3:04 PM
    #505
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Hey Z, do any of these rich farmers let Tundra owners hunt pheasant on their land while they are basking in the sun??
  26. Sep 27, 2016 at 4:06 PM
    #506
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Possibly, I've never thought to ask for some reason ha.
  27. Sep 28, 2016 at 8:31 AM
    #507
    mtntop
    mtntop New Member
    I used to hunt phez out east every season, but then it dried up out there. I should head out there this year and see whats up. Its been at least 3 years since I headed that way.
  28. Sep 28, 2016 at 11:42 AM
    #508
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Since moving out here to Burlington, I've seen more pheasants than anywhere else. I've been told that the reason is how much sorghum is grown down here.
  29. Sep 28, 2016 at 1:49 PM
    #509
    mtntop
    mtntop New Member
    ahh yes, I intentionally look for that in new fields, they love it
  30. Oct 28, 2016 at 3:09 PM
    #510
    TXMiamiFan
    Jose
    :spy: Hampden and Yosemite around noon today. Anyone here?
