Travel Trailer Mods
Discussion in 'Outdoors' started by Alloutdrs1, Jan 13, 2019.
  1. Feb 24, 2019 at 3:43 PM
    #91
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Like this :thumbsup:
  2. Feb 24, 2019 at 6:02 PM
    #92
    Mnorris1206
    08 tundra
    Yep that's it .This yr I'm going to wire some led lights all under my camper also for more light all the way around it .
  3. Feb 27, 2019 at 2:24 PM
    #93
    Alloutdrs1
    Alloutdrs1 [OP] New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    For you veteran travel trailer owners, I'm getting ready to install my fantastic fan in mine and on my pop up that had a metal roof so I just used butyl tape and then Dicor sealant around the edges on top of the screw holes. Upon looking at my current vent it looks like its overlapped with some type of exterior tape or something? I had butyl tape and dicor ready for the install but it looks like I might need something else as well?
  4. Feb 27, 2019 at 2:32 PM
    #94
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    The factory fan is pathetic, looks like a computer fan stuck in the vent! I removed my fantastic fan before I sold my pop up so it will be welcome addition.
  5. Feb 27, 2019 at 4:37 PM
    #95
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I think that is just as you described, tape under the flange that is screwed down then they flood the hell out of the top, screws and flange with the caulk.
  6. Feb 27, 2019 at 5:37 PM
    #96
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Ok so its how I was going to install with the butyl tape but instead of a nice bead around the lip of the fan they just flooded it with the self leveling Dicor. Just wanted to make sure before I get into it.
  7. Feb 27, 2019 at 5:39 PM
    #97
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    New tires also arrived today, Goodyear endurance. These things are pretty stout and made in USA, I'm impressed.
    IMG_20190227_202658_01.jpg IMG_20190227_202658_01.jpg IMG_20190227_202712_01.jpg
    Watt maker likes this.
  8. Feb 27, 2019 at 6:12 PM
    #98
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    We have those Andersen levelers
    mentioned earlier, great product and these stuck on the front corner:
    Floor doesn’t shake:
    I don’t have a side attached RV ladder, so got one of these:
    RV antifreeze bypass, attach jugs, pump it through:
    Behind the door storage:
    Closet storage (ikea):
    Bathroom storage (ikea):
    Amazon over stove cutting board, adds counter space:
    For dry camping, I keep wine buckets for campground water taps, and drill pump it in (non-potable):
    More will come to mind...
  9. Feb 28, 2019 at 4:12 AM
    #99
    Capt J-Rod
    Ohio
    @Alloutdrs1 ... You will love those tires. I switched out the Chinese blow-pops on my trailer last year. The goodyears run way cooler when you pull over and touch them. The sidewall is very stout in those as well.
    Markman likes this.
  10. Feb 28, 2019 at 5:12 AM
    #100
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yes the sidewall is very stout, I was surprised in how much difference there is in just handling them. I have seen and had to many friends with blowouts from the cheap Chinese tires so this is a welcome investment IMO. Its worth it to me to not have any issues and be on the side of the highway while traveling.
  11. Mar 3, 2019 at 12:58 PM
    #101
    TxTaco
    TxTaco New Member
    2019 White 1794
    One of the best mods I did was take a 6x6 vinyl fence post ... glue a post cap on one end, attach the other cap with a hinge/lock. Mount under the trailer with the hinge side by sewer. Get a plastic gutter that will slide in and out of said hollow fence post. Store stinky slinky in the gutter. Pull up ... open the cap ... pull the gutter out a bit ... full access to the sewage connection. Sold my RV or else I could show pics
    twistedcricket likes this.
  12. Mar 10, 2019 at 4:14 PM
    #102
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Got the new fan installed today, man removing that old sealant was a pain.
    Also installed a shower dispenser so we won't have to keep bottles in the camper for personal care products.
    Dropped of the new wheels and tires to get mounted!IMG_20190310_152111_01_01.jpg IMG_20190310_171029_01.jpg IMG_20190310_170959_01.jpg
  13. Mar 13, 2019 at 7:02 PM
    #103
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Wife and I bit the bullet two weeks and picked up this 2019 Keystone Bullet 287QBS. It's currently sitting in a storage building winterized and I'm dying to use it. Tundra pulled the old girl like a champ.
  14. Mar 13, 2019 at 7:55 PM
    #104
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Nice looking camper and truck!! I cant wait to get mine out either, April is my first trip!
    Durania[QUOTED] likes this.
  15. Mar 18, 2019 at 11:23 AM
    #105
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    The vent fan upgrades are absolutely necessary!
  16. Mar 18, 2019 at 1:21 PM
    #106
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    renogy is a great system. looking into putting one on the truck.
    here are the kits. https://www.renogy.com/products/solar-kits/
    most of them come with charge controllers. the controllers go between the panels and the battery.
    twistedcricket and Jrharvey02 like this.
  17. Jul 22, 2021 at 10:32 AM
    #107
    twistedcricket
    Paul
    Omahell, NE
    2014 SR5
    I have a kit from renogy and really like it so far. It's nothing great, but the single 175w solar panel keeps the two batteries charged while the camper is in storage. We're going to try a weekend trip using just the house batteries to see how long they can go. Sort of a mini boondocking experience using just the batteries (lights, vent fan, water pump, other 12v options) and propane (water heater. stove top). I'm not expecting a whole weekend from two deep cycle batteries but we'll see.
  18. May 1, 2022 at 4:10 PM
    #108
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I like that. How do you turn it on and off? And where can I get one like that?
  19. May 1, 2022 at 4:25 PM
    #109
    2014 Black tundra
    2014 tundra sr5
    D5337934-7891-4CD0-9C3C-1EB0934D7F2F.jpg C543B715-6E32-454C-9FF6-C3427BC98AEC.jpg 49010E7B-BB04-4712-B89C-DF7D49417920.jpg Get extra cords and hoses. Sometimes the average length won’t reach. I found out the hard way. And a surge protector. And what was already said. One of my favorites is the telescopic tow mirrors. They help a lot. And make the truck look nicer too. Wife and I are going this Wednesday for 7 days in Gettysburg. A lot of history there. Got the truck loaded already. And lots of lights, some in the camper and some in the truck. Wife said you can never have enough lights. She got more lights for this season.
  20. May 2, 2022 at 5:55 AM
    #110
    twistedcricket
    Paul
    Omahell, NE
    2014 SR5
    That sounds like a great trip!
    Extra hoses & cords are a must. The one time you're more than 25ft from a water spigot or shore power and you realize the need.
  21. May 17, 2023 at 1:56 PM
    #111
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Solar... lots and lots of solar!
    Throw in a couple hundred Ah of Lithium batteries (very affordable now) and you're golden. Decent quality lithiums are the same price as an AGM battery and give you nearly double the usable amp hours while shaving off nearly half the weight... Win/Win.
    600W of panels and 200Ah of lithium batteries and I basically never have to worry about power. (or maintaining flooded LA batteries, which I am historically very bad and forgetful about)
    100W Renogy portable for when I'm parked in a shady campsite, and the Honda 2200 genny for when I need to run the AC or microwave some Bacon!
    2014 Black tundra likes this.
  22. May 17, 2023 at 2:07 PM
    #112
    Not to thread jack, but could you possibly answer this?
    https://www.tundras.com/threads/sol...stion-for-davis-air-dyer.124858/#post-3194068
  23. May 17, 2023 at 2:41 PM
    #113
    SD Surfer
    Bruce
    So Cal
  24. Jul 7, 2023 at 11:23 AM
    #114
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    How did I miss this thread?!?
    Quick Connect propane hose for our firepit that connects at the rear of the trailer. No more fiddling with extra tanks.
    Bunkbed lights with USB ports (for kids devices) was an easy 5 minute upgrade.
    Keyless Door Lock allows for the family to get in easily if they want to go back to the camper.
    Installed an over the door shoe organizer into the shower area- this holds all our personal toiletries and dries out well.
  25. Jul 7, 2023 at 11:36 AM
    #115
    justcuz
    justcuz 2.5 Gen Member
    Changed color on propane cover from white to black. Painted bucket black that I place over electric jack to protect it from rain. IMG_2306.jpg
  26. Jul 7, 2023 at 11:49 AM
    #116
    Interested in the propane hose. Any details or links? Thanks.
  27. Jul 7, 2023 at 12:06 PM
    #117
    SD Surfer
    Bruce
    So Cal
    I think this https://www.amazon.com/gp/product/B06XKB82HP?ie=UTF8 is the one I bought... haven't actually used it yet.
    *Worth noting* The QD fitting on my trailer is downstream of the regulator, so already low pressure. If the regulator of your firepit, BBQ, etc. is part of the hose, no problem. Swap hoses and you're good.
    If the regulator is integral to the appliance it'll need to be removed or you'll be "double regulating" it down to an insufficient propane flow.
    Rabidllamas and bflooks like this.
  28. Jul 7, 2023 at 12:31 PM
    #118
    Thanks. I'll check it out. This would be perfect for my Camp Chef grill.
  29. Jul 8, 2023 at 5:32 AM
    #119
    bflooks
    bflooks New Member
    Metrowest MA
    2019 Silver Sky Metallic Tundra Limited
    Turbokits.com Stage 1 kit (Precision 7675) Innovate SCG-1 Boost Controller AEM water/methanol injection Nitro 5.29s Powertrax Grip Pro Bilstein 5100 middle setting CB shims (2 driver, 1 passenger) Bilstein 5160 rears Firestone Ride-Rite bags Daystar cradles Roadmaster Active Suspension (RAS) HD TRD rear sway bar 18" TRD wheels 275/70r18 Falken Wildpeak AT3W X2 Power Group 24 battery Power fold tow mirror (OEM) Genuine Cooling Systems 15-row Setrab kit Valhalla's Shields (front/rear) Dirty Deeds Bamf 21" Stainless
    Levelmate - worth every penny, especially when combined with the rear camera (furions have audio).
    https://www.amazon.com/LogicBlue-Te..._csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfYXRm
    X-Chocks
    https://www.amazon.com/X-Chock-Whee...lizer&qid=1688818433&sprefix=x-,aps,87&sr=8-3
    Real water filtration - the canisters you attach to the hose are only 25 micron. You can build a system for ~ $100, or buy one of these RV/Marine systems already built. Use standard whole house filters, down to 1 micron or less. It's concerning to see what they capture
    silverhack and Tundra234 like this.
  30. Jul 8, 2023 at 5:41 AM
    #120
    +1 on the X-Chocks. I have this as well.....36 gallon.
    bflooks[QUOTED] likes this.
