  1. Mar 3, 2019 at 10:02 PM
    #4711
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well pulled panels off to see what’s all pre wired for the doors on the truck. Looks like all I have to do is get door harnesses (or make my own) and I can have heated power mirrors, power windows. And there’s a few more un used plugs I found... EWD here I come. Lol
  2. Mar 3, 2019 at 11:47 PM
    #4712
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    If you're in Texas I see em on junk yard trucks on Craiglist all the time
  3. Mar 4, 2019 at 12:11 AM
    #4713
    empty_lord
    05 rollover special
    Indiana. I’ve found doors. But rust is what keeps me away. People wanting 400 bucks for used doors that are rotted along the bottom
  4. Mar 4, 2019 at 4:49 AM
    #4714
    Professional Hand Model
    Fred
    Hand Protectors
    Its your tires. If you try to inflate to negate the ‘wide footprint’, then you’ll feel like you are riding on wagon wheels. Trust me on this.
    Keep’em low pressure and enjoy what it is: A much safer tire that gets lower MPG.
    Darkness[QUOTED] likes this.
  5. Mar 4, 2019 at 6:13 AM
    #4715
    I was actually going to start a thread about this and ask what PSI folks are running. The door jamb on my truck says 26 front 29 rear. That seems ridiculous. I checked yesterday and I have 34-35 all around which I lowered to 33. I usually run them at 30 PSI and didn't realize Discount Tire must have topped them off during the last rotation.
    After thinking about it, I believe this is the more likely reason my MPG went up. Not because of the PCV replacement. Both were done around the same time.
  6. Mar 4, 2019 at 6:32 AM
    #4716
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    So After some miles on it and going up to the mountains.
    Two things I've noticed ,
    1. The truck does not feel as top heavy as before. Remember I have no sawy bars.
    2. I had a high pitched tire noise around 60mph. That is gone.
  7. Mar 4, 2019 at 6:45 AM
    #4717
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The interesting part is I believe these tires weigh the same or less as my last tires when they were new. They have stiffer sidewalls but less meat in the tread, guessing the tradeoff in wei8is sidewall.
    @Professional Hand Model yeah I considered that. I'm pretty sure these are running around 10psi lower than I normally would run but haven't pulled a gauge yet. If it is the tires I'm fine with that, since my truck sat a few months I'm hoping it isn't fuel turned into petroleum jelly caking up somewhere.
    @FirstGenVol it depends a lot on the tire. My first set of Yokos I did the chalk test and came to 38-36. The Mickey ATZ I landed around 35-33. My current Yokos are different than the early set I had and I'm sure the tire shop just went factory numbers on them.
  8. Mar 4, 2019 at 9:09 AM
    #4718
    Chalk test?
    because_wumbo-truck likes this.
  9. Mar 4, 2019 at 9:20 AM
    #4719
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    the red likes this.
  10. Mar 4, 2019 at 9:55 AM
    #4720
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    315/70/17s anyone?? (Compared to my 285/70/17s)
    I picked this guy up cheap off someone on Facebook Marketplace to do some testing/measuring... the tire is Brand new
    the red, Brown Bear, NUDRAT and 9 others like this.
  11. Mar 4, 2019 at 10:13 AM
    #4721
    Casper421
    In the woods
    06 DC
    I love the shovel wheel chock!
  12. Mar 4, 2019 at 10:21 AM
    #4722
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    The Truck Shovel is good for more than just digging! :D
  13. Mar 4, 2019 at 11:27 AM
    #4723
    Fred
    Hand Protectors
    Filled up and did a mileage calc today. All city driving with stop and go. A bit of idle time and hauling 80 extra pounds all week. 11.5mpg.
  14. Mar 4, 2019 at 11:42 AM
    #4724
    Fred
    Hand Protectors
    Oil weepage seems to be slowing with the new oil change switch from a few weeks ago. Switched from Mobil 1 Advanced ‘Extended Performance’ Synthetic to Full Synthetic label. Still a slight haze ring around the gasket, but it hasn't advanced like it normally would by this time after a wipe down.
    Clunk clunk has returned, but is just a single clunk. My shim is being squeezed out on one side. Will try shimming and caulking it back in later this week. One more try before having to buy new springs.
    New Mobil ‘High Mileage’ 3 pks oil jugs (Wallywurl $25 jug) and DEX III (big gurl from Brasil $12 jug) ordered for delivery by Wednesday.
    NUDRAT and Filthyphil like this.
  15. Mar 4, 2019 at 11:43 AM
    #4725
    Fred
    Hand Protectors
  16. Mar 4, 2019 at 12:08 PM
    #4726
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I saw a first gen last week on that same size tire with maybe 2" lift. I got excited and looked closer, he cut less metal than I did. He must never hit bumps or dips.
  17. Mar 4, 2019 at 2:22 PM
    #4727
    Fred
    Hand Protectors
    Something feels weird about receiving an order of transmission fluid at your front door.
  18. Mar 4, 2019 at 6:09 PM
    #4728
    empty_lord
    05 rollover special
    Are the leds white or green in the gauge cluster on the 05-06 trucks. If it’s white with a tiny can it be removed? I’m kinda wanting to
    Go with white backlighting
  19. Mar 4, 2019 at 6:32 PM
    #4729
    Casper421
    In the woods
    06 DC
    They’re white and the gauge backing has a green film that you can wet sand off.
  20. Mar 4, 2019 at 7:26 PM
    #4730
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    If the weather cooperates this weekend I'll start working on fitting my different center caps.
  21. Mar 4, 2019 at 7:45 PM
    #4731
    empty_lord
    05 rollover special
    Cool ty, what grit y’all recommend?
  22. Mar 4, 2019 at 7:55 PM
    #4732
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    the red likes this.
  23. Mar 4, 2019 at 10:28 PM
    #4733
    empty_lord
    05 rollover special
    Jerry311SD[QUOTED] likes this.
  24. Mar 5, 2019 at 5:19 AM
    #4734
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Ha, glanced at the first pic & thought 'I don't think it will fit, I think the BASKET will hit the roof'. :anonymous:
    Rheywood456[QUOTED] likes this.
  25. Mar 5, 2019 at 9:25 AM
    #4735
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have 35s with a 6 inch Lift. I had to remove the front mud flaps and in full Flex I still have a very minor rub. It is fixable for the amount that I am rubbing I just haven't gotten around to it yet. I think I just need to take a heat gun to the plastic right above where the mud flap mounted. How much lift do you have in the front?
  26. Mar 5, 2019 at 10:15 AM
    #4736
    I've been seeing white smoke out of the tail pipe that has my attention. It's not much but doesn't seem to go away even when the truck is warmed up.
    Anyone else notice this on theirs?
  27. Mar 5, 2019 at 10:19 AM
    #4737
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    How cold is it there? You can get white smoke even after it's warmed up if it's colder.
  28. Mar 5, 2019 at 10:22 AM
    #4738
    The outside temp definitely crossed my mind. It was around 50 degrees saturday when I was working on it. It is around 30 today when I noticed it again but the other vehicles around me were not producing any visible exhaust like mine.
  29. Mar 5, 2019 at 2:55 PM
    #4739
    Fred
    Hand Protectors
    @empty_lord
    Can you post up the procedures for doing a ‘complete transmission service’ on the 2002 Tundra V8 4wd SR5? Maybe a screen grab from the stealership books? Or, info from the tranny specialist.
    I’m considering doing a pan drop and replacing the ‘screen filter’ with a new one. Need info on tightening the bolts on the circuit board inside the pan and info on solenoids replace if needed?
    I’ve seen kits online that sell combo filters screens and solenoid kits for the transmission. Looking for any guidance. No current problems and just doing this for prevent maintenance. 161k on the OD. Thanks in advance.
    FirstGenVol likes this.
  30. Mar 5, 2019 at 3:11 PM
    #4740
    Not sure if it helps but I found a great video for our trucks online. I'll see if I can track it down.
