285/60r20 vs 295/60r20 recommendations
Discussion in 'Wheels & Tires' started by pilot218, Feb 10, 2018.
  1. Feb 10, 2018 at 4:20 AM
    pilot218
    pilot218 [OP] New Member
    Kevin
    2008 Silver Tundra CM Limited 4x4
    Bilstein 6112s (1.9"), 2 CB shims driver side, 1 CB shim passenger side, front differential drop Bilstein 5160s, Toytec 1+ shackles (set at 1"), 1/2" block spacer driver side, carrier bearing drop, TRD rear sway bar TSS silver rims 20"x9" (+50) Toyo Open Country AT2s 295/60/20 Stock Limited wheels with 275/60r20 Michelin Defenders LineX BacFlip Cover
    I'm looking for some tire/size recommendations. I currently have 275/65r20 BFG KO2s. The height is good, but they are too narrow and will replace them with either a 285/60r20 or 295/60r20. I have no rubbing issues (after bending the edge of the skid plate up on both sides), with plenty of UCA clearance.
    My truck is a 2008 Tundra CM 4x4 (125K miles); Bilsteins 6112s (1.9") with 2 CB shims driver side, 1 CB shim passenger side; Bilsteins 5160s, Toytec 1+ shackles set at 1"; TSS wheels (20"x9", +50)
    Options I'm considering:
    285/60r20s BFG KO2s from Costco
    295/60r20 Nitto Ridge Grapplers
    295/60r20 Toyo AT IIs
    Choosing the size is my first priority, then the specific tire. If I choose the 285/60r20s, I will stick with Costco. With the 295/60r20s, I will most likely use TireBuyers or Direct Tires.
    I'm looking for recommendation on size and then which tire. I'm looking for an aggressive/semi-aggressive look and a quite ride. Is there much enough difference between the 275/75r60 and the 285/60r20 to notice the difference? I love the TSS wheels and the offset keeps them just inside of the fender line.
    My truck isn't my daily driver, and most of my miles are highway/around town. My stock limited wheels have Michelin Defenders 275/60r20s, which are great tires! If my truck was my daily driver, I would probably go the Michelin Defender route in a larger size. I think the 275/65r20 on stock 20"x8" rims look fine, but are too narrow on a 9" rim.
    Thanks
  2. Feb 10, 2018 at 7:20 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I originally had 275/65/20 KO2 and thought the same thing...too skinny. I returned them to discount tire 2 weeks later and upsized to 295/60 STT Pros. Much better size for sure. Honestly, I never considered 285/60, not really sure why.
  3. Feb 26, 2019 at 11:50 AM
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    Did discount credit you anything for the 275's? I recently did the same thing and want get the 285/65.
    Thanks,
  4. Aug 28, 2021 at 10:56 PM
    PlatinumXing1985
    PlatinumXing1985 New Member
    Kevin
    2015 Attitude Black Platinum Tundra
    Iron cross side steps, color matched door handle / side mirrors, s&b cold air intake, Trd shifter, MX4 tri-fold cover, tundra bed mat
    what size did you end up getting?
