***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Feb 9, 2019 at 5:05 PM
    #241
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Me too! :headbang:
  2. Feb 9, 2019 at 5:22 PM
    #242
    BigGreek
    BigGreek New Member
    Evan
    2016 Tundra Platinum
    Me 3!!
    ARES35 likes this.
  3. Feb 10, 2019 at 12:17 PM
    #243
    trddriver
    trddriver New Member
    '14 1794
    open to discussion
    Question: I read on this or the sub thread that the door speakers receive signals already with crossover from factory amp. Is this true, or able to be verified? If so that means front door will not be full range, correct?
    So I assume, if that's true, that's where the infinity (dash) left and right channels will provide the mid range. If that's not true then the doors will all be full range ..?
    Just trying to put it together in my head.
  4. Feb 10, 2019 at 12:52 PM
    #244
    ARES35
    ARES35 New member for life
    Mile high
    Dang I’m jealous! No Tracking for me:(
  5. Feb 10, 2019 at 2:58 PM
    #245
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    The crossover is indeed in the JBL amp as I understand it anyway. So when we wire our new speakers we will wire the mid range to mid range wires and tweeter to tweeter wires. This will not change the current range of sound at all, same frequencies from better quality speakers. The corner dash speakers are 2 way coaxial speakers so they will put out mid and high frequencies which is an upgrade from a crappy "full range" paper speaker. the center channel will be dual tweeters for highs. So we will not be losing any range if wired correctly. If you wire it wrong, such as running the tweeter wires from the mid range then yes it won't sound right.
    trddriver[QUOTED] likes this.
  6. Feb 10, 2019 at 3:08 PM
    #246
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    Could we buy a plug and play four channel amp? I mean a true plug and play, as in "here's the adapter harness that you plug one end into the cable connectors on the factory side and the other side plugs into the new non-OEM amp".
    What I'm looking at is buying this GB speakers and installing them. At some point, at the same time or here and there over the next year, buying a Kenwood HU, a five channel amp, and a sub box.
    I'd rather it all be simple plug and play with very little, if anything extra. I do know that extra cables and wires will need to be ran for the sub box.
  7. Feb 10, 2019 at 3:14 PM
    #247
    Pudge
    CT
    James posted a while back about the "plug and play" myths. I do not think it's this simple. I know high level inputs on some amps will work out and you can buy harnesses but you still need a power from battery, a ground, and remote turn on wire that would have to be somehow hooked to the headunit or you would have to buy some kinda line out controller and wire that in so sense the power from the speakers and send a signal to the amp to turn on, and you would need power and ground and harnesses for the LOC as well.
  8. Feb 10, 2019 at 3:17 PM
    #248
    FoghornTX
    Ft Worth, Texas
    Yeah, I'm thinking that at some point that I'll need to seek out a professional installer.
    Pinay and Pudge[OP] like this.
  9. Feb 10, 2019 at 3:18 PM
    #249
    Pudge
    CT
    Nothing worth doing is truly plug and play
  10. Feb 10, 2019 at 4:45 PM
    #250
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    @james@tech12volts has been working on making the install very simple, but you still will need to run a power cable thru the firewall boot, install a fuse and attach the cable to the battery. Also will need to attach a ground cable. Here is a post he made a week or so ago of a setup that he made very easy.
    A true plug and play setup that does not require a larger gauge power and ground cable is either a very low power amp (like the factory amp) or is risking an electrical fire by over heating the factory wire. Hopefully you would blow a fuse first, but I have seen people install higher rated fuses in the factory fuse box of cars.
    aperezsh, Pudge[OP] and 831Tun like this.
  11. Feb 10, 2019 at 4:48 PM
    #251
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It says "run power" so I'm guessing that's exactly what he means and what you said, run a larger (properly sized) power wire and a ground wire of the same size as the power wire?
  12. Feb 10, 2019 at 5:01 PM
    #252
    TXTundra2722
    2015 Black Tundra
    Very curious as to what "this setup" that he's coming up with will cost.
  13. Feb 10, 2019 at 5:23 PM
    #253
    FoghornTX
    Ft Worth, Texas
    After the $320 for the GB speakers, I'll have $1200 to see about buying a HU, 5 channel amp, and sub box with one or two 10 inch woofers in it.
    I like the Kenwood DDX8905S, so that takes about $600 off of the amount that's left.
    Not sure that I want to go with a HU that has the availability to play DVDs/CDs. I guess I could go digital and convert all 300+ CDs of mine to FLAC. and put on a single USB memory key.
    I've got options that I need to sort out after I buy the GB speakers.
    aperezsh likes this.
  14. Feb 10, 2019 at 5:28 PM
    #254
    Cfincke
    San Antonio
    Yes, looking at the photo of the setup James built, the main ground wire looks to be 4 gauge, that is connected to the distribution block and then connected to the amps with 8 gauge wire. I would say the power wire needed would also be 4 gauge for that particular setup. Larger amps or more amps, you may have to run 2 gauge or 0 gauge wire
    Or the ground is 0 gauge and then 4 gauge to the amps
  15. Feb 10, 2019 at 5:37 PM
    #255
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    ********* has plug and play amps, with the exception of running a power wire. They also require some tuning but they come with instructions. The set up James is developing is supposed to have pre-tuned amps. My plan is to get in on this GB before the end of month and pair it with sub/amps from *********. I may change my mind in the spring if James releases his amps at a competitive price/performance range with *********.
  16. Feb 10, 2019 at 5:53 PM
    #256
    TXTundra2722
    2015 Black Tundra
    No pressure James!
  17. Feb 10, 2019 at 6:16 PM
    #257
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Argh......taco tunes setup isn't more PNP than any other setup. You have to run a power wire. Taco tunes is lying to you if they say it's PNP.
    And you are much better off getting a good brand amp vs who knows what the hell supplier taco tunes is using.
    Black Tundra TRD and Cfincke like this.
  18. Feb 10, 2019 at 6:28 PM
    #258
    Pudge
    CT
    The issue I have always had with ********* is they don't or won't say what brand their amps are, and some speakers as well. Their stuff isn't any more plug and play than other kits that are out there. And any amp you don't need to run a power wire for is not likely to be better than the stock amp. So many people rave about ********* but I have also heard several terrible experiences. I just don't think their quality is even close to what tech12volts is putting together. And James is very honest and upfront, you know exactly what you're getting from James.
    JoshuaA, TomC843, Norfolk757 and 4 others like this.
  19. Feb 11, 2019 at 5:04 PM
    #259
    00Tyler10
    Tyler
    Bowling Green, Ky
    Mine get here Wednesday! :oldglory:
    FoghornTX likes this.
  20. Feb 11, 2019 at 8:21 PM
    #260
    Pudge
    CT
    vol375 and 831Tun like this.
  21. Feb 11, 2019 at 8:26 PM
    #261
    00Tyler10
    Tyler
    Bowling Green, Ky
    TomC843 and Pudge[QUOTED][OP] like this.
  22. Feb 11, 2019 at 8:27 PM
    #262
    TXTundra2722
    2015 Black Tundra
  23. Feb 11, 2019 at 8:29 PM
    #263
    TXTundra2722
    2015 Black Tundra
    Can you find out if non jbl guys can use this as the replacement for the system that we don't have.... I'm assuming it will (one channel for the sub and four other for the door speakers).
    Pudge[OP] likes this.
  24. Feb 11, 2019 at 8:36 PM
    #264
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    CrewMaxT and Pudge[QUOTED][OP] like this.
  25. Feb 11, 2019 at 8:54 PM
    #265
    Pudge
    CT
  26. Feb 11, 2019 at 8:57 PM
    #266
    Pudge
    CT
    Lol, I hear ya man.
    I'm not gonna be in on the amp buy. I'm broke lol. James put this out there so I'm just throwing it out here for him. He ended up upside down after the subwoofer group buy due to shipping issues and whatnot so I feel if I can help him out in any way by simply posting up info I will do that. Hes such a great guy and I hope some people here will benefit. i for one can not swing this one unfortunately
  27. Feb 11, 2019 at 9:02 PM
    #267
    Pudge
    CT
    I think you will wire your current speaker wires into the hi level inputs and then run wires from the amp to your new speakers but I just emailed James to confirm how this works for non JBL people. I'll let you know asap
  28. Feb 11, 2019 at 9:04 PM
    #268
    TXTundra2722
    2015 Black Tundra
    Thanks buddy... also, do we need to upgrade our speaker wire for this or is stock sufficient?
  29. Feb 11, 2019 at 9:09 PM
    #269
    FoghornTX
    Ft Worth, Texas
    I'm gonna get divorced and be broke AF because of this website.
    But I'll have a nice truck.
  30. Feb 11, 2019 at 9:11 PM
    #270
    Pudge
    CT
    Not sure about wiring but I'll find out
Thread Status:
