Zerks?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Nov 13, 2017.
  1. Jan 1, 2020 at 3:21 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Anyone got a Zerkless................in Seattle??? :deadhorse:
    tundra_20 likes this.
  2. Jan 1, 2020 at 4:10 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    There is no definite for zerks per my Toyota chassis buddy. So have them, some don't.
  3. Jan 1, 2020 at 10:18 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    You could add your own.....many do.
    Oh and three (3) pumps MAX, especially the driveshaft.
    Luck and enjoy those Toyotas. : ^ )))
  4. Jan 2, 2020 at 3:13 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    My 2017 has none. I think they changed sometime during the 2017 model year. On the rear.
  5. Jan 14, 2020 at 2:01 PM
    rockfordhx
    rockfordhx New Member
    My 2017 DC 2WD does not have any zerk fittings
  6. Jan 14, 2020 at 2:01 PM
    rockfordhx
  7. Jan 14, 2020 at 2:38 PM
    AZBoatHauler
    So.Arizona
    I guess I got lucky... 5 of them (2 front, 3 rear) on my 2017.
  8. Jan 15, 2020 at 3:27 PM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    Joe333x, Bulldog9 and tundra_20 like this.
  9. Feb 10, 2020 at 9:29 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Interesting thanks for posting, I haven't looked yet since I only have just over 2000 miles but I'd assume no 2019 has zerks?
    NCTundra1980[QUOTED] likes this.
  10. Mar 7, 2020 at 7:29 PM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    I was just under there adding a carrier bearing drop kit and didn’t see any zerks on my 2019 CM TRD Sport.
    Ronin73 and Joe333x[QUOTED] like this.
  11. Mar 8, 2020 at 5:59 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Curious about this as well. I have a 2019 CM 4x4. Do 2019 and 2020 not have zerks?
  12. Mar 8, 2020 at 6:45 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I've read that you shouldn't mix 2 separate grease types. I'm not sure what is in my u joints now (183k miles). Should I remove and clean all the old grease out of my u joints and use the grease I have on hand? I have a few tubes of Schaeffer 238 ngli#2
    https://www.schaefferoil.com/238-ultra-supreme.html
  13. Mar 8, 2020 at 7:14 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I had an incident on my first gen. I greased the slip yoke(on the rear for first gen) and didn't realize there can be too much. I eventually undid the zerk to relieve pressure and the shaft slipped back to where it's supposed to be. Too much pressure there will wreck your carrier bearing. :oops:
  14. Mar 8, 2020 at 11:24 AM
    Blue Thunder
    Washington
    Interesting to hear there are no zerks in the most recent years of production. My manual still says to check/lube them every service.
  15. Jun 21, 2020 at 2:49 PM
    Psvendsen
    Psvendsen New Member
    Pete
    2017 SR5 Crewmax
    Front leveling kit
    I'm late to the party, my 2017 SR5 Crewmax doesn't have any zerks on the rear drive shaft. None on the yokes or u joint body, I checked all three u joints. I haven't checked my front shaft yet. My manual also says to lube the shaft every 30k.
  16. Jun 21, 2020 at 2:53 PM
    tunamac
    tunamac New Member
    2016 CM 4x4
    My 2016 has 3 on the rear drive shaft, none on the front. Interesting how many variations there are out there.
  17. Jun 21, 2020 at 3:07 PM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    my 2019 doesnt have any zerks. went under to grease them up and nada.
    Rocko9999 and Joe333x like this.
  18. Mar 10, 2021 at 11:33 AM
    Lowcoco
    Lowcoco New Member
    Jose
    2017 Tundra SR5 Crewmax 4X4
    Bilstein 6112/5160
    Sorry for bringing this up again but my mine has 2 at the front but non in the back
  19. Mar 10, 2021 at 11:50 AM
    #49
    Rocko9999
    Rocko9999 New Member
    2014 DC 4x2. I checked and have zero zerks.
  20. Mar 14, 2021 at 7:05 AM
    #50
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    so r they the same? other than the zerks. would you be doing the same neglecting the zerks as not having them? or are they different were if they have zerks they need yo be maintained
  21. Mar 14, 2021 at 7:13 AM
    #51
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    2017 Limited with zerks that I have been servicing regularly. I guess I am screwing up. Hopefully I’ll have no issues.
  22. Mar 31, 2021 at 12:53 PM
    #52
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Anyone know if toyota would be able to tell by VIN if truck has zerks or not? I know i can just crawl under there but for curiousity, wondering how well this is documented for toyota since it seems that there SHOULD be zerks, per the manual.
  23. Mar 31, 2021 at 12:56 PM
    #53
    AZBoatHauler
    So.Arizona
    I think 2018 was the last year with Zerks on the drivelines. From what I recall, some 2017s-2018s have them and some don't. I don't think any Tundra 2019 and newer has Zerks.
  24. Mar 31, 2021 at 12:57 PM
    #54
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Thanks for that. I will try to confirm when i put on my new skids later this week. Would it be correct to assume that if you dont have zerks, your U joints would be more sturdy when compared to greasable u joints and thus, would likely last well past 100k miles without needing service?
  25. Mar 31, 2021 at 12:58 PM
    #55
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think you would get random, conflicting, and unreliable answers.
    JohnLakeman likes this.
  26. Mar 31, 2021 at 1:01 PM
    #56
    AZBoatHauler
    So.Arizona
    I don't think the U-joints would be any different other than not having the fitting to add grease. I'd think they should be gtg at least 100k miles but I'm sure the level of use/abuse one sees could make that interval longer or shorter. Let's be honest, I'd bet 50% of the Tundras with Zerks never get serviced so I'd try not to worry too much about it.
  27. Mar 31, 2021 at 1:07 PM
    #57
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    I would say that is a fair statement. The main reason for my question i guess was because i am going to be adding some mid body skid plates to cover the cats and I was going to try to come up with a mounting solution to make it easier to take on and off if i was going to be needing to grease the U joints. If i can confirm there are no zerks, then it would make mounting much easier to not have to worry about regular removal of plates to get to zerks.
  28. Mar 31, 2021 at 1:12 PM
    #58
    AZBoatHauler
    So.Arizona
    I just installed RCI skids two weekends ago and thought the same about having to remove both of them to service my front diff and t-case in 15,000 miles. I'll grease the u-joints then. Glad I bought aluminum rather than steel.
  29. Mar 31, 2021 at 1:14 PM
    #59
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    :D Yeah, there is probably one short, chubby, myopic purchasing agent with thick glasses, in a basement office somewhere in Toyota, USA, that has that piece of information right on the front of his brain! All other such inquires to others are wasted breath. :rofl:
    Wynnded[QUOTED] likes this.
  30. Mar 31, 2021 at 3:29 PM
    #60
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    I can picture that now.....
