Your thoughts on 10,000 mile oil changes.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rider0120, Jul 30, 2018.
  1. Jul 30, 2018 at 5:46 AM
    Rider0120
    Rider0120 [OP] New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    My truck is going in for his first service here in a couple days the 5000 one, here I thought they actually change the oil but I guess they’re just rotating the tires and doing a couple checks. This motor being the old technology over 10 years old but with new oil‘s and synthetics what is everyone’s thoughts on going 10,000 miles on oil changes or do you still do every five
  2. Jul 30, 2018 at 5:50 AM
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    I shoot for around 5k-7k. Been doing that with my last 3 vehicles and have had zero issues (full synthetic of course). In fact my last 2 (nissans) have had golden oil at about 7k miles and the techs didn't believe that I hadn't had the oil recently changed. I figured if I take care of the engine oil and filters the cars should run well for a looong time.
    Yota18 likes this.
  3. Jul 30, 2018 at 5:52 AM
    I still do the change with Mobile-1 around 5K to 7K too.
    Yota18 likes this.
  4. Jul 30, 2018 at 5:53 AM
    I use Mobil 1 and still always change at 5000 miles.
    Beep88 likes this.
  5. Jul 30, 2018 at 5:55 AM
    Blueknights75
    Ron
    Clayton, NC
    Honestly the 10K mile oil change scares the hell out of me. But, I am going to follow the manufacturers recommendations for my non FFV. Since I have a lifetime engine and power train warranty, along with free oil changes for life I figure as long as I get my vehicle serviced at the dealership I shouldn’t have any issues.:fingerscrossed:
    Yota18 likes this.
  6. Jul 30, 2018 at 5:56 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    The shop I use (fuck Toyota care) recommends every 7500 even with mobile 1. I just had them do a 3000k oil change idk if it matter but it puts my mind at rest lol so fuck it money well spent. But I’ll prolly do it every 7500. @92 and oil change every 7500 is still pretty good considering a cars every 3k @ 30$ Shop prices not on your own
    4x4_Angel likes this.
  7. Jul 30, 2018 at 5:58 AM
    I do mine at 5k miles.
  8. Jul 30, 2018 at 6:11 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    5k here as well but I also have the FFV so it’s required.
    Prostar 190 likes this.
  9. Jul 30, 2018 at 6:11 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Depends on what gas you're running thru it. If you're running pure gas then you might be able to get away with it. But if you're burning an ethanol blend I would stick to 5k. If you're doing e85 some of the time (FFV) then you may need to bump it down to 3,500. Toyota actually mentions it in the manual. I use an 'up to 10% ethanol' 87 octane gas and do it every 5k.
    Prostar 190 and Okietundra like this.
  10. Jul 30, 2018 at 6:22 AM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I do 5k miles with Mobil 1 0w20. I tow a lot and the manual says to stick to 5k for that.
  11. Jul 30, 2018 at 6:27 AM
    nodak67
    nodak67 New Member
    JR
    actually its 5k miles if using 50% or less than E85 fuel or 2500 miles if using E85 fuel more than 50%, otherwise you follow
    this only applies to engines that are flex fuel. even the maint. log says 5k/6m "replace engine oil and filter"
    the non FFV engine is 10k oil changes and the maint. log shows oil change under the 10k entry.
    FFV maint log : https://www.toyota.com/t3Portal/document/omms-s/T-MMS-18TundraFFV/pdf/T-MMS-18TundraFFV.pdf
    non FFV maint log : https://www.toyota.com/t3Portal/document/omms-s/T-MMS-18Tundra/pdf/T-MMS-18Tundra.pdf
    Okietundra likes this.
  12. Jul 30, 2018 at 9:51 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    In my 16 Gen 3 Tacoma I followed the manufacturers guidelines and had the dealer do it every 10,000 and didn't have an issues, but I got rid of the truck at 41,000 so it was still early. I will have to place some trust in Toyota, I can't believe they'd put their reputation of quality on the line for no real reason by recommending changes at intervals that are too great.
    Wynnded and Blueknights75 like this.
  13. Jul 30, 2018 at 10:06 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The wife is on her 2nd lease vehicle, both GX460's, same oil recommendations - even for first change. Was kind of surprised, but since it is a lease don't really care as much. The oil doesn't look bad when checked.
  14. Jul 30, 2018 at 10:13 AM
    Rica25
    Ricardo
    Tulare
    I service mine every 5k no matter what
  15. Jul 30, 2018 at 10:34 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I used Castrol Syn on both Tacomas and did 7500 mile changes. I put almost 100k on both and never a problem. There is no difference in the short block on a FFV (what service writer told me) so I am guessing the only reason for 5k is the type of fuel.
  16. Jul 30, 2018 at 10:37 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    7500 for me...
  17. Jul 30, 2018 at 10:38 AM
    Max Power
    Have you guys seen those commercials that were on a while back, I think it's for a Castrol brand of oil, they claim it's the "once a year oil change" oil, I think they allege you can change it every 20,000 miles. I don't think I'd take that risk.
  18. Jul 30, 2018 at 10:48 AM
    incredibillhulk
    incredibillhulk New Member
    Bill
    I'm doing my first oil change myself at 1,000 miles (this weekend) but that's mostly because I want to go ahead and install my Fumoto valve.
    sprtbkr likes this.
  19. Jul 30, 2018 at 10:55 AM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Mobil 1 has a similar oil. Believe it’s called annual protection.
  20. Jul 30, 2018 at 11:03 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Amsoil Full Synthetic, 7500 mile change. :D
    lewi3069 and SouthBoundSteve like this.
  21. Jul 30, 2018 at 11:16 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    coconut oil is the best. 20K miles
    Ike74 and 4x4_Angel like this.
  22. Jul 30, 2018 at 11:32 AM
    Sas
    OKC, OK
    When they can run an F1 engine w/turbos and race fuel for 20k miles w/o damage, then I'll believe it.
  23. Jul 30, 2018 at 12:24 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    2007 tundra- 146k with 10k intervals- no issues
    2014 tundra- 94k w/ 10k intervals- no issues
    2016 tundra- 77k w/ 10k intervals and no issues
    I think its fine
  24. Jul 30, 2018 at 12:29 PM
    Jengel451
    The Bitterroot, MT
    people are funny, even comparing F1 engines to car engines? C'mon. In today's day and age, you have more than enough information at your fingertips to figure out that the manufacturers have improved in the past 40 years.
    and if you REALLY want to know, get your oil samples done, blackstone etc, spend the 35 bucks and save yourself hundreds. Easy math there.
    Again, coconut oil.
  25. Jul 30, 2018 at 12:36 PM
    Sas
    OKC, OK
    It was a little tongue-in-cheek, but I think you missed the point anyway of 'if it'll hold up that long in extreme conditions then it'll be fine in our trucks regardless of what power adders we throw on them'.
    Jengel451[QUOTED] likes this.
  26. Jul 30, 2018 at 1:26 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I change mine every 2-3,000 miles, which usually takes me one year. I use Mobil 1, 0w-20.
    DalTee and 4x4_Angel like this.
  27. Jul 30, 2018 at 1:34 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    For normal use, in non FFV engines, 10,000 miles is good with me. 3k and 5k changes are old thinking when using a full syn like Mobile 1, plain and simple. Do a 3-5k change and send it to Blackstone. Do a 10k change and send it to Blackstone. I'm going to guess you keep doing 10k changes from that point forward.
    Why do we all "trust" 3k oil changes anyway?... Because there was a time when that was the recommended interval by experts such as the manufacturers of the vehicles, and the oil. The experts have moved on...
    Tierhog, usmchawk and Blueknights75 like this.
  28. Jul 30, 2018 at 1:47 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Agree and similar results on my last 3 tundras, had 350k for highest miles.
    Wynnded, Blueknights75 and Max Power like this.
  29. Jul 30, 2018 at 1:49 PM
    nodak67
    nodak67 New Member
    JR
    I would love to see you go 10k miles on E85, heck I would like to see what it looks like after 5k on E85 :)
    but then again I think you didn't read the maint. manual on the FFV engines
    Sas likes this.
  30. Jul 30, 2018 at 1:59 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Think you missed the non ffv in the first sentence.
