Your suggestions on upgrades while changing valve gasket
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Jan 13, 2021.
  1. Jan 13, 2021 at 11:51 AM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Hi all, I'd appreciate any suggestions you may have on upgrades/maintenance I should consider while changing my valve gaskets. So far I'm planning on getting the 12 hole fuel injectors from Dirtydeeds and think I want to upgrade/replace the ignition coils but don't really know which brand/grade to get. Any suggestions on this? I've seen them from about $100 - $1,000. I don't want to go cheap but $1k is out of the question.
    Thinking maybe replacing more of the electrical lines, maybe the Distributer cap/rotor as well. Just so I have peace of mind going out into the unknown.
    All input is greatly appreciated! Thanks
  2. Jan 13, 2021 at 12:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    For the coils I would just get the OEM Denso equivalent. They cost around $55 each.
    Voss[OP] likes this.
  3. Jan 13, 2021 at 12:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Denso coils. New wires (sumitomo oem or ngk) if 3.4l v6.
    Neither the v6 or v8 have a distributor cap.
  4. Jan 13, 2021 at 1:15 PM
    Professional Hand Model
    Hand Protectors
    The Denso 1303 is the Coil I bought for $54 each on the Big Guurrll. Not sure what they cost now. I know Stealers wanted $170 each for the same Denso. Fuggetaboouit!
    Just checked and they are now $52. Buy some new spark plugs and do them.
    Hitachi makes our MAF Sensor ($55). Its Toyota Brand and they scratch off the stamp.
    You’ll need the Toy FIPG 103 Gasket Maker and 18 new Valve Cover bolts with the rubber washers. A new PCV Valve and grommet, as well.
    Tacopashka and Voss[OP] like this.
  5. Jan 13, 2021 at 1:55 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Good stuff. Thanks my dude!
  6. Jan 13, 2021 at 3:18 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Can you point me in the right direction of where the Hitachi MAF is $55 bud? Cheapest I found was $117.
    Ordered the ignition coils. $49 on Carid. Checked mine and they were Denso as well but look pretty old and if I'm not mistaken, a cheaper version as they were $118 for the entire set of 8 online.
  7. Jan 13, 2021 at 3:23 PM
    Hand Protectors
  8. Jan 13, 2021 at 3:25 PM
    Voss
    Valod
    2003 AC TRD 4x4
    One day Ima have to buy you a beer man. Thanks!
