Your 2nd Gen Controls And How They Work
Discussion in '2nd Gen Tundras (2007-2013)' started by TruckyTruck, Jun 30, 2014.
  1. Jan 12, 2017 at 6:48 AM
    #61
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Wow that sucks. Can't have alsd on with Trac and vsm off i guess....
  2. Jun 2, 2017 at 9:44 PM
    #62
    zackbremer
    zackbremer New Member
    Da Z
    i have an 08 whats this 4th setting you speak of?
  3. Jun 2, 2017 at 10:33 PM
    #63
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
  4. Jun 3, 2017 at 6:19 PM
    #64
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    The 2008 model has the ability to have everything off except for the lsd.
  5. Jun 11, 2017 at 1:52 AM
    #65
    zackbremer
    Da Z
    by pressing it a 4th time?
  6. Jun 11, 2017 at 6:59 AM
    #66
    TruckyTruck
    Gary
    Do you still have your manual in your glove box? I can't remember the sequence
  7. Jun 11, 2017 at 3:55 PM
    #67
    zackbremer
    Da Z
    ^^ nope, bought truck used, never came with it
  8. Jul 4, 2017 at 10:09 PM
    #68
    TruckyTruck
    Gary
    I didn't know if I should make a whole new thread for this, so I thought I'd post it here.
    I was convinced I knew everything about my 13 tundra, but tonight I found out I was wrong. Maybe you guys already knew this, but... Did you know you can have your tundra running and not have your amber running lights on?!
    I was watching fireworks tonight and had the parking break on because I was at a bit of an incline. When I got in the cab to leave, I started the truck and immediately noticed my running lights were not on. I turned the light switch and they turned on, but when I turned it back to the off position, the running lights turned back off. As soon as I released the parking break the running lights came back on.
    Anyway, I just thought it was interesting. I could have had the truck running with the air conditioner on and not bothered anyone else with lights being on.
  9. Jul 5, 2017 at 3:37 AM
    #69
    I found out by accident too. Probably something else I haven't figured out yet no doubt.
    TruckyTruck[OP] likes this.
  10. Jul 5, 2017 at 8:10 AM
    #70
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, our 07 Sienna behaves the same way.
  11. Nov 12, 2017 at 11:29 AM
    #71
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    I had a GM truck at some point, and if you pushed the park brake pedal down 1-click, the DRLs shut off. It was nice when going on base, to actually dim the lights for the SF folks checking IDs.... maybe these are the same?(not needing Full engagement to shut off the lights...)
  12. Mar 6, 2018 at 8:21 AM
    #72
    glewis25
    glewis25 New Member
  13. Mar 18, 2018 at 9:56 AM
    #73
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    the PDF link is dead.
  14. Dec 4, 2018 at 3:56 PM
    #74
    Yoda111
    Yoda111 New Member
    So I have an 08 tundra 5.7
    It has 3 inch body lift and 35’s on it.
    It seems like my abs kicks in too quickly if I brake hard. But a more important issue, is that my vsc will engage on on/off ramps on highways when it’s not even necessary. I’m wondering if by having the lift and bigger tires would cause the computer to think it’s tipping or something?
    Any info would help
    Oh and tires are 12.5 wide if that makes any difference as well
    dhsmith06 likes this.
  15. Feb 3, 2019 at 11:50 AM
    #75
    2013 Tundra TRD 4X4
    2013 Tundra TRD 4X4 LuvMyToyTruck
    Knoxville, TN
    2013 Tundra SR5 4X4
    Cosmetics only thus far
    My ‘13 does the same thing... headed don an on/off ramp it feels as if by brakes are coming apart.
  16. Jul 15, 2019 at 5:08 AM
    #76
    TruckyTruck
    Gary
    Year and a half late, but fixed. Downloaded the full manual.
    08crewmax likes this.
  17. Jul 15, 2019 at 5:13 AM
    #77
    TruckyTruck
    Gary
    Zero Point Calibration.
    This is what needs to be done for both of your situations. If you haven't already solved your problem, just Google how you can accomplish it. Sorry for the very late response.
  18. Dec 27, 2019 at 4:22 PM
    #78
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    All Gen 2s minus the 2007 models have the following options.
    chrisf111 likes this.
  19. Feb 6, 2020 at 10:05 PM
    #79
    The Shaggy Fox
    The Shaggy Fox Astronaut Cat
    Yep - this.
    Can be done with a simple paper clip and a pdf (or Techstream).
    If this doesn't work, you may want to try shimming the yaw sensor (under the middle storage compartment), as well.
    All of the info is on the Google (for both of these procedures).
  20. Feb 7, 2020 at 7:07 AM
    #80
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Is the vehicle completely stopped? I'm asking as it wasn't mentioned, covering that base. Also, I'm not sure that TC is on in 4X4 for it to be turned off. Honestly, I haven't been keeping up on this functionality recently. Where I am, it's 4X4 100% of the time with the mountains/snow/winter.
  21. Feb 7, 2020 at 7:13 AM
    #81
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You haven't had your dash apart recently for any reason have you? Where the connector to the back side of the switch may not have been restored? I'm trying to think of all the really easy things to check.
  22. Feb 7, 2020 at 10:30 AM
    #82
    TruckyTruck
    Gary
    That's what I'm thinking. Something not plugged in or wrong with the button.
    Wynnded[QUOTED] likes this.
  23. Feb 7, 2020 at 11:45 AM
    #83
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I didn't think I was going to be out in the truck today, but I was. So, while in 4X4, I pressed and held the TC button. After a few seconds (3-4) the TC disabled (truck w/squiggles) indicator in the cluster came on.
    TruckyTruck[OP] and Fiesta346 like this.
  24. Feb 7, 2020 at 2:11 PM
    #84
    TruckyTruck
    Gary
  25. Feb 7, 2020 at 2:12 PM
    #85
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nice! Mission accomplished then.
    Fiesta346[QUOTED] likes this.
  26. Feb 20, 2020 at 6:36 AM
    #86
    TruckyTruck
    Gary
    Restart your phone, try someone else's phone, replace radio. That would be my train of thought. It's most likely the phone.
  27. Mar 25, 2020 at 6:37 AM
    #87
    Albinator
    Albinator SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Awesome, thank you! I have the 2008 5.7. I point this out because you mentioned it may have a 4th option? My manual will say and explain everything like you did?
  28. Mar 25, 2020 at 6:46 AM
    #88
    Albinator
    Albinator SAINTRIOT
    Utah
    There’s three 3 second modes?
    Did you find the video?
  29. Mar 25, 2020 at 4:38 PM
    #89
    TruckyTruck
    Gary
    No, I was kidding. The 2008 model does have 4 choices though
    Wynnded likes this.
  30. Mar 25, 2020 at 4:47 PM
    #90
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine has a mode that's so secret.....
