Yikes need help
Discussion in '1st Gen Tundras (2000-2006)' started by Bluetoyotaguy, Apr 15, 2022.
  1. Apr 15, 2022 at 9:01 PM
    #61
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Is your truck one of those squatting dog kinds? All front lift, and none in the rear?
    easleycrawler and Beefnbread like this.
  2. Apr 15, 2022 at 9:17 PM
    #62
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
  3. Apr 15, 2022 at 9:23 PM
    #63
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    No pics in that thread either. :monocle:
    Beefnbread[QUOTED] likes this.
  4. Apr 15, 2022 at 9:26 PM
    #64
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    We need a frickin’ detective
  5. Apr 15, 2022 at 9:42 PM
    #65
    Jack McCarthy
    Jack McCarthy Happy hour; beer goggles, not a fake profile.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Who’s got a pic of what the setup is supposed to look like? Maybe that will clue the OP in on what he did wrong.
  6. Apr 15, 2022 at 9:57 PM
    #66
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I’m confused to heck at this point.
    OP made another thread last month saying he has n3 rough country coilovers. Now he says he doesn’t, but has 41/2 inches of lift from autozone zone oem equivalent struts and a 2.5 inch leveling pulk.
    n3 struts + a 2.5 leveling pulk will get you at 5 inches more or less. Not healthy for your truck.
  7. Apr 15, 2022 at 10:06 PM
    #67
    easleycrawler
    Travis
    I believe that's exactly what has happened.
  8. Apr 16, 2022 at 4:37 AM
    #68
    Bluetoyotaguy
    Bluetoyotaguy [OP] New Member
    Yes previously I put on n3 struts and there was an issue with them so they got sent back and we bought the puck instead my old struts were completely shot so we bought the new one’s which should have been OEM replacements.
  9. Apr 16, 2022 at 6:20 AM
    #69
    Bluetoyotaguy
    The following are pictures of my current situation and show the replacement OEM struts and the ball joint binding.
    upload_2022-4-16_9-19-45.jpgupload_2022-4-16_9-19-45.jpgupload_2022-4-16_9-19-45.jpgupload_2022-4-16_9-19-45.jpgupload_2022-4-16_9-19-45.jpgupload_2022-4-16_9-19-45.jpg
    Beefnbread and Jack McCarthy like this.
  10. Apr 16, 2022 at 6:21 AM
    #70
    Bluetoyotaguy
    And to answer your question army of one my truck is level not squatted lol
  11. Apr 16, 2022 at 6:32 AM
    #71
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That is wild. Someone else mentioned those may not be the right coilovers for your truck and I wonder if they were right.
    Jack McCarthy likes this.
  12. Apr 16, 2022 at 6:35 AM
    #72
    Bluetoyotaguy
    I guess it’s a possibility that they aren’t correct but they were made out to be
  13. Apr 16, 2022 at 8:53 AM
    #73
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    You are sitting at 4.5 in these pics because the spindle is stuck under the spring. What does the ride height look like when the spindle is not stuck under the spring? Have checked to see if those balljoints are good? What is the thickness of that spacer? It looks like there is some sort of down travel issue letting the spindle get under the spring like that. Maybe those struts extend farther than stock?
    Darkness likes this.
  14. Apr 16, 2022 at 9:01 AM
    #74
    Jack McCarthy
    Bill
    North of Boston
    My guess is remove puck, problem solved.
  15. Apr 16, 2022 at 9:51 AM
    #75
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Similar to what @KNABORES said, I would lift the truck up and see if the spindles can be pried out, then lower the truck and see what happens. From there at least you'll see whats what.
    If your old struts were stock Toyota, hopefully you didn't throw them out. You'd be much better off keeping the springs from them and using 5100 shocks. For $300 you'd have level stance, no need for aftermarket UCA, and no binding. I wouldn't run an autozone even if they sponsored me.
  16. Apr 16, 2022 at 10:39 AM
    #76
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    OP, buying new upper control arms will only improve the angle of your ball joint going into the spindle. It won’t fix your problem. Your spindle is still going to be in the same spot if you continue this.
  17. Apr 16, 2022 at 10:47 AM
    #77
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Also, looking at your coilovers, they look like they are a crap ton wider around the coils than normal ones. Look at the top where it mounts before the coil on the coilovers and you will see that the coils stick out further. Compare to mine.
    Just an observation though, I don’t have measurements.
    Jack McCarthy and easleycrawler like this.
  18. Apr 16, 2022 at 10:52 AM
    #78
    easleycrawler
    Travis
    He definitely has the wrong coilovers.
  19. Apr 16, 2022 at 10:55 AM
    #79
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
  20. Apr 16, 2022 at 10:57 AM
    #80
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Yeah, I think so. He should be reusing the original coils anyways. Just change the strut.
  21. Apr 16, 2022 at 11:56 AM
    #81
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    OP, did you ever get an alignment? After altering suspension parts, you need to get an alignment afterwards. Especially adding 5 inches of lift.
    Are your wheels like this?
  22. Apr 16, 2022 at 12:38 PM
    #82
    Bluetoyotaguy
    Yes the alignment is fine and I see what you’re saying about the strut being wider than stock however the shop that did lift my threw my entire stock front strut assembly away So unfortunately I have no choice but to use the new struts.
  23. Apr 16, 2022 at 12:39 PM
    #83
    Bluetoyotaguy
    When I get home I will lift the truck up with a jack and go from there
  24. Apr 16, 2022 at 2:07 PM
    #84
    Bluetoyotaguy
    Almost wish I could take a sawzall to that one piece of the spring lol
  25. Apr 16, 2022 at 2:16 PM
    #85
    Windsor
    Homeless in Oregon
    Some.
    So, is that just where the UCA sits, or is it just stuck?
    Beefnbread likes this.
  26. Apr 16, 2022 at 2:51 PM
    #86
    Bluetoyotaguy
    It’s currently stuck but when you go down the road and hit bumps etc it frees up in other words when my strut compresses it frees up and when the strut relaxes again it get stuck but the constant pulling and stress has caused my boot to tear and my upper ball joint clanks.
  27. Apr 16, 2022 at 2:59 PM
    #87
    Windsor
    Homeless in Oregon
    Some.
    Take the spacers off and rethink what you need before wasting money on junk.
  28. Apr 16, 2022 at 3:43 PM
    #88
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Here’s mine
    Here’s yours
    Bent much?
  29. Apr 16, 2022 at 3:49 PM
    #89
    Windsor
    Homeless in Oregon
    Some.
    Ding ding ding. We have a winner.
    If you look at the dust shield, you can see it is not sitting right.
  30. Apr 16, 2022 at 3:49 PM
    #90
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    :yes::benchpress:
