Yikes need help
Discussion in '1st Gen Tundras (2000-2006)' started by Bluetoyotaguy, Apr 15, 2022.
  1. Apr 15, 2022 at 8:21 PM
    Bluetoyotaguy
    Bluetoyotaguy [OP] New Member
    Yes I installed it on both passenger and driver side the struts that were bought should be the same size as OEM so they should not add any lift it should really only be a 2 1/2 inch lift.
  2. Apr 15, 2022 at 8:22 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Did you take any measurements before/after adding the lift?
  3. Apr 15, 2022 at 8:22 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    The leveling pulk won’t cause that problem. I’ve ran the same setup with no problems. Something else is screwy looie
  4. Apr 15, 2022 at 8:25 PM
    Bluetoyotaguy
    I’m not sure what’s going on but it will get looked at on Tuesday and it will get fixed before adding the lift I was sitting at just over 35 inches and after adding the lift I am just under 40 so it lifted the truck about 4 1/2 to 5 but I am a little confused as to how the replacement struts were supposed to be like OEM.
  5. Apr 15, 2022 at 8:27 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    The lift is your problem if you have 4 1/2 inches of lift. Downsize or get new UCAs
    Don’t go past 3 inches without new equipment.
  6. Apr 15, 2022 at 8:27 PM
    Bluetoyotaguy
    Here Is the strut that was put on the truck
  7. Apr 15, 2022 at 8:28 PM
    Bluetoyotaguy
    Definitely will get new UCA’sDo you think that the shop is accountable for their mistake?
  8. Apr 15, 2022 at 8:29 PM
    Bluetoyotaguy
    I feel as if they should have told me I would’ve needed new UCA’s in order to run the lift safely.
  9. Apr 15, 2022 at 8:31 PM
    Bluetoyotaguy
    I did not plan on going past 3 inches as far as I was concerned the new strut was the replacement and was the same dimensions as the OEM one and the rough country puck is only 2 1/2 inches
  10. Apr 15, 2022 at 8:35 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Without seeing proper pictures I think maybe you didn't get the struts you think you got.
    UCA won't help. You need to get your truck out of the clouds.
    FrenchToasty likes this.
  11. Apr 15, 2022 at 8:36 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    That autozone strut doesn’t mention any lift when I look it up.
    IDK man
  12. Apr 15, 2022 at 8:37 PM
    Bluetoyotaguy
    Well that is a possibility but I planned on getting new upper control arms anyway but now I have to get them so it’s not that big of a deal hopefully the shop will feel the need to charge less for the repair but it is what it is
  13. Apr 15, 2022 at 8:37 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    So the new strut was the same length as the one you took off?
  14. Apr 15, 2022 at 8:37 PM
    Bluetoyotaguy
    I’m not sure what’s going on all that I can hope is that it’s fixable and hope for the best come Tuesday
  15. Apr 15, 2022 at 8:37 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Random guess...
    you have the wrong shock that is longer than OEM and adding a spacer on top of that causes this bad of a bind.
  16. Apr 15, 2022 at 8:39 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    If your mechanic initially knew that he was only installing 2.5 inches of leveling pulk lift, it’s not his fault. IDK how you got 4 1/2 of lift, but if he knew it was going to raise that much, shame on him.
  17. Apr 15, 2022 at 8:39 PM
    Bluetoyotaguy
    The new strut was supposedly exactly like the OEM strut same dimensions and all but I guess it’s not I would wait it out to see if this strut would settle overtime but I don’t think my upper ball joint would hold on that long
  18. Apr 15, 2022 at 8:40 PM
    Bluetoyotaguy
    Well it should be fixable and like I said I was going to get new upper control arms anyway so now I have a reason to get them but that should fix this issue correct
  19. Apr 15, 2022 at 8:41 PM
    #49
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  20. Apr 15, 2022 at 8:41 PM
    #50
    Bluetoyotaguy
    I will see if I can get away with getting new upper control arms and keeping the 4 1/2 inches of lift I obtained but if it is too bad I will take the puck off and keep the struts
  21. Apr 15, 2022 at 8:41 PM
    #51
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Check your pulk height. It should only be about 1 1/4 thick.
    alb1k likes this.
  22. Apr 15, 2022 at 8:42 PM
    #52
    Bluetoyotaguy
  23. Apr 15, 2022 at 8:42 PM
    #53
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Friday thread!!!!
  24. Apr 15, 2022 at 8:43 PM
    #54
    Bluetoyotaguy
    Thanks for all the feedback I will get back to you guys tomorrow with more pictures and I’ll keep you posted as time goes on.
    Beefnbread, Blang805 and FrenchToasty like this.
  25. Apr 15, 2022 at 8:46 PM
    #55
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Arms won't get you functional. Don't throw money at arms until you find out what is wrong. You just need to:
    1) find out what was installed on your truck
    2) find out if it was installed wrong. Something as stupid as the lower coil perch has been known to do this on other shocks.
    3) plan from there and be glad you didn't buy arms, because you probably can ditch the pucks and be fine.
    Beefnbread likes this.
  26. Apr 15, 2022 at 8:49 PM
    #56
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I should mention a diff drop kit.
  27. Apr 15, 2022 at 8:50 PM
    #57
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    His part search SS is for 2wd
  28. Apr 15, 2022 at 8:52 PM
    #58
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    He’s 2wd?
    In that case he’s probably getting extra lift height from that.
  29. Apr 15, 2022 at 8:54 PM
    #59
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wouldn't be this much. Something is just wrong. Either wrong shocks (like maybe they belong on a Tacoma) or something is installed wrong.
    Beefnbread[QUOTED] likes this.
  30. Apr 15, 2022 at 8:56 PM
    #60
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I just want to see the pictures.
