Yet another P0420 code
Discussion in '1st Gen Tundras (2000-2006)' started by whodatschrome, Dec 9, 2023.
  1. Dec 9, 2023 at 4:56 PM
    whodatschrome
    whodatschrome [OP] New Member
    North of North Plains, Oregon
    lots of dents
    So my 2004 Access Cab 4.7 project truck has the check engine light on. With my code reader plugged in it shows the ubiquitous P0420 code. I just replaced all four of the o2 sensors with new Denso’s that i bought at rock auto. I cleared the codes with the reader, but the code popped back on again about 20 miles later.
    I’m trying to figure out the next best course of action to take that isn’t overly expensive. The engine has about 218k miles on it. I assume that it still has the original cats. My truck and exhaust is 100% rust free, so i’m positive i don’t have any pin hole leaked. When i removed the engine a few months ago, i didn’t see any signs of a leaky exhaust manifold gaskets. After i reinstalled the engine, i did install new exhaust gasket doughnuts at all the joints. I’m thinking about temporarily install some o2 sensor elimators in order to help narrow down what needs to be fixed.
    Does anyone have recommendations on what i should investigate next with my p0420 code?
  2. Dec 9, 2023 at 5:20 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I would check all the o2 sensor connectors for good connection (bent or loose pins), wiring for any fraying or bare spots, and clear the code again before I did anything else. Also take it on a 30 minute highway drive afterwards so that the ECU can run its checks. PITA I know, but its free troubleshooting.
    edit: Does your reader have live data? It's reassuring to see very close values on the o2 sensors.
    BluegrapeVr6 and shifty` like this.
  3. Dec 9, 2023 at 5:32 PM
    whodatschrome
    lots of dents
    The harness and wires are in excellent condition. I inspected every inch of the engine harness (before i reinstalled it and the engine back into the truck). All the pins very 100% corrosion free and rock solid.
    I already had a P0420 code before i replaced all four sensors. I cleared the code again after i installed the new sensors. After that i went for about a 30 mile drive. The code popped up again 20 miles later. I then plugged back in the reader and it’s still the same p0420 code.
    It’s a actually my friend’s code reader that i’m borrowing. I don’t think it has the live data?
  4. Dec 9, 2023 at 5:43 PM
    JakeJake
    2000 Tundra AC 4X4
    Good on you for inspecting the wiring and pins. Its often overlooked.
    I use an obd link mx and the free version of their app OBDlink. Having live data is very nice for troubleshooting, and would help verify that none of the new 02 sensors were defective.
    Other than the rare possibility a Denso part was DOA it could actually be a bad or clogged catalytic converter.
    BluegrapeVr6 and BroHon like this.
  5. Dec 9, 2023 at 5:46 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I'd say you need to see the data from the rear sensors to verify if the cats are working or not.
    An android phone and simple obd2 dongle will do this. My $1 elm327 off fleabay from years ago does (now $3'ish). You can get the veepeak(iirc) off the 'zon for about $15 or a nicer one like the obdlink for $100+.
    I use the torque app on android. The free will work but the pro version ($5?) is a bit better without adds.
    shifty` and JakeJake like this.
  6. Dec 10, 2023 at 8:10 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I had p0420, p0430 codes on our 04 Highlander. It has 226k on it. I ran two bottles of crc guaranteed to pass fuel treatment last Saturday, I cleared them and it’s been gone since. It’s been driven 400 miles since last Saturday. Worth a shot.
  7. Dec 10, 2023 at 8:43 AM
    shifty` We call it “riding the gravy train”
    2nd for the MX+, I've got it too. Very powerful, good smartphone app.
    I'm actually really surprised to hear your outcome. It doesn't fit the typical others have seen, and I'm shocked the truck re-popped the code in a scant 20 miles. I'd expect it to take longer to reach full readiness. Fluke?
    I'd clear again. And you can always consider throwing non-foulers in the rear, but I'd really want to see some live data to see what is being read. Do you know any history on it, if it'd had some condition prior that was causing it to run rich or lean for any period of time?
    JakeJake[QUOTED] likes this.
  8. Dec 10, 2023 at 11:34 AM
    whodatschrome
    lots of dents
    Full back story...
    The engine and the complete exhaust system is out of my 2000 tundra. For the past few years (while the 2000 truck was still drivable), the check engine light was always on. I never tried hooking up a code reader to it to see what the problem was. Since my brother in law was the previous owner, i’ll contact him to see if he ever tried to fix the code.
    Right after i swapped 2000 engine and exhaust into the 2004 truck, there was no codes. About 20 miles later the CEL turned on. I’ve cleared the CEL 4 times so far. So far each time it takes about 20 miles for it to turn back on...and that distance has been the same both before and after i replaced all four o2 sensors. I can only assume that the cats are original and have 218k miles on them.
    I did inspect my MAF sensor, and it looks clean to me.
  9. Dec 10, 2023 at 11:38 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think your cats are toast. But you could try the o2 spacer method. I've also been fighting p0420 and p0430 on my 03 for a long time. I replaced my cats and all four o2 sensors, and that helped for a while. I'm going to replace the cats again under warranty next week and see if that helps. If not, I'll try spacers. Keep us posted, and I'll keep you posted as well.
    I've tried that cat cleaner stuff on my original cats and it didn't do anything. I haven't tried it on these two years old aftermarket cats yet. I probably won't, since mine are still under warranty.
    Dalandshark likes this.
  10. Dec 10, 2023 at 11:42 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Was the 04 exhaust bad?
  11. Dec 10, 2023 at 11:44 AM
    whodatschrome
    lots of dents
    What brand cats did you install? I’d prefer to not break the bank by buying oem toyota cats.
  12. Dec 10, 2023 at 11:47 AM
    whodatschrome
    lots of dents
    I can only assume that the 04 cats are bad? There was something drastically wrong with the 04 engine, and it was spewing oil out of the tailpipe. When i removed the cats from the 04 truck, oil was pouring out though the honeycomb. I figured it wouldn’t even be worth my time to try to clean them up and install them for testing purposes.
  13. Dec 10, 2023 at 12:06 PM
    I agree. There's a solid chance PO/BIL probably had an upstread O2 failure previously and ran it that way, because a lot of poor suckers believe "Ah, O2 is just that damn federal big brother emissions crap, I don't need it!" (and couldn't be more wrong), it reading wrong caused the ECM to run a/f poorly for extended periods because it wasn't reading exhaust properly, and the mis-burn clogged the cat.
    I always try to remember to ask people coming here with inefficiency codes how long it's been going on, or if they've ever popped an O2 code in the past, but sometimes I forget.
    On cats, a few brands have been found to not throw codes. Last list I wrote down was: Magnaflow, Walker, Summit Racing's store brand, and OEM. I wish I'd written down a list of ones that throw codes, b/c there are a couple that do. I want to say someone mentioned "if it's listed as accepted for California use, it likely won't throw codes". Maybe that helps?
  14. Dec 10, 2023 at 12:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What ever the muffler shop had on hand. I'll find out when I take the truck in for the new ones this week.
  15. Dec 10, 2023 at 12:46 PM
    I'd be curious to know what brand also. Only because what you're describing, battling with P0420/P0430 is what others who didn't use the brands I just listed always bitch about. But I suspect in a few of those cases, the upstream O2 was their initial (and current) problem, and they tossed a perfectly good cat.
  16. Dec 10, 2023 at 1:03 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I crawled under the truck and couldn't find any identifying attributes to the cats.
  17. Dec 10, 2023 at 2:19 PM
    whodatschrome
    lots of dents
    well, huh....it turns out the borrowed code reader does do real time.
    JakeJake and 455h0le_dachshund like this.
  18. Dec 10, 2023 at 2:24 PM
    whodatschrome
    lots of dents
    I have absolutely no idea what all these numbers actually mean though.
    F1711FA6-FF99-4595-9DED-93A947B088B8.jpg 38CEFF2B-D009-472F-B874-5E783E9EBC5A.jpg 87017958-8545-49DF-BA87-8A37DF9F6380.jpg B0ECEA27-AA10-411A-9FB5-3FBCCC598E5F.jpg 1DA19724-B5D9-4593-A77D-E362FD067932.jpg
  19. Dec 10, 2023 at 2:34 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Will it do a voltage graph of s2 (post cat) while the engine is running?
    JakeJake likes this.
  20. Dec 10, 2023 at 3:13 PM
    whodatschrome
    lots of dents
    is this the correct screen you’re talking about?
    AE49E610-B9BB-4452-B7C3-04B2B59519B8.jpg 65B166AE-2FDA-41EB-BA5C-EFA68FC0BABA.jpg
  21. Dec 10, 2023 at 5:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yep.
    Is that after driving (engine & cats hot?) or before?
  22. Dec 10, 2023 at 5:11 PM
    whodatschrome
    lots of dents
    Zero driving. It’s just with about 5 minutes of idling. So the engine and cats are warm, but i wouldn’t say there were up to full operating temperature.
  23. Dec 10, 2023 at 6:40 PM
    whodatschrome
    lots of dents
    If i need a new cat, i’d probably just buy a weld in version. https://www.magnaflow.com/products/...compliant-universal-catalytic-converter-51204
    It costs WAY less that the direct fit version. I figure i can weld it into place myself for less than $497... https://www.magnaflow.com/products/...-epa-compliant-direct-fit-catalytic-converter
    Magnaflow does have some sort of buy back recycling program for your old cat. It’s a “maximum“ of $75 for an OEM cat. The only thing is that they’re a bit vague on just how how much of a rebate that’s you’ll realistically receive. The truck is from california, but is now living in oregon, so i should be find with just installing a federal cat and not a california cat.
  24. Dec 10, 2023 at 7:42 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Get it up to full temp then check the graph again.
    The 2nd sensor should be mostly level (minimal voltage swing). If it's not, then the cat isn't doing it's job.
    FrenchToasty and shifty` like this.
  25. Dec 10, 2023 at 7:55 PM
    whodatschrome
    lots of dents
    Thanks. It’s supposed to be dry tomorrow, so i’ll do that in the afternoon. I still haven’t reinstalled the bed on the back of the truck so i don’t want to be driving around out when it’s raining.
    Ironically my buddy text me this afternoon wondering if i was done with using his code reader. I replied that i was not. Maybe my text didn’t go through, because he showed up at my shop about 15 minutes later. He asked me if i was done using it yet. “nope”, i replied. “Good”, he said. “Because my uncle wants me to take a look at his CEL on his car and i’m not motivated to do that today.” So it looks like i got the reader for a few more days!
  26. Dec 11, 2023 at 8:46 AM
    whodatschrome
    lots of dents
    Here’s a pic of after 15 miles of driving. The first pic is when i was driving a steady 55mph on the highway. The second pic is when the engine is at an idle.
    95B6F475-5541-42BE-995B-450A6099C82A.jpg 1DFD043B-3D1D-4F15-BE83-0219CBDB3BA8.jpg
  27. Dec 11, 2023 at 10:32 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Looks like the cats may be toasted. My truck is an 05 which has wideband o2 sensors up front but the rears are standard. So newer efi but similar enough.
    At 65mph with cruise control on:
    At idle just after stopping:
    455h0le_dachshund and shifty` like this.
  28. Dec 12, 2023 at 7:46 AM
    whodatschrome
    lots of dents
    “Cats”...as in all both plural of them?
  29. Dec 12, 2023 at 8:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Are you also getting p0430? It usually comes something like 50 miles after p0420 if both cats are in question.
    P0420 being the driver side and p0430 passenger.
  30. Dec 12, 2023 at 8:36 AM
    whodatschrome
    lots of dents
    Only the p0420 code so far
