Yellow Sticker?
Discussion in 'General Tundra Discussion' started by Albinator, Oct 19, 2018.
  1. Oct 19, 2018 at 8:12 AM
    Albinator
    Albinator [OP] Jehovah-Nissi
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Hey guys,
    Any of you know what this means for my truck? Is it because it’s a crew cab? There is no lift on this truck.
  2. Oct 19, 2018 at 10:00 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Any aftermarket parts on it? Or completely stock? Seen these stickers on moded trucks, not just lifted.
    Aftermarket wheels, tires, bumpers ect without a lift add weight.
    GNTundra likes this.
  3. Oct 19, 2018 at 10:20 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The dealer/port adds that for anything they add to the truck after it leaves the factory; anything that adds weight that essentially reduce your carrying capacity and/or makes the truck's gross weight heavier than the way it left the factory. (I guess some lawyer was involved in that decision).
    Bedliner, step bars, hitch, etc.
    jewsNbrews likes this.
  4. Oct 19, 2018 at 1:45 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    My truck has that sticker too. It came w spray on bedliner and side steps that probably causes it. Anything that adds weight to the truck subtracts load
    jewsNbrews and Ericsopa like this.
  5. Oct 19, 2018 at 1:55 PM
    Ericsopa
    Ericsopa Old man and the sea
    Ditto, side boards, spray-in bedliner, bed rails. All added weight...
  6. Oct 19, 2018 at 1:57 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    My '13 has that sticker also. It's something like 30lbs on mine.
  7. Oct 19, 2018 at 2:45 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    This started when Toyota got burned on the Sienna minivan by adding the factory trailer hitch and pushing some vans beyond the GVWR. They actually discontinued offering the OEM Toyota hitch over this.
    More idiocy from lawyers just like the "check drivers floor mat" is part of every vehicle service recommendation as a response to unintended acceleration claims against Toyota.
    Boerseun likes this.
  8. Oct 19, 2018 at 2:48 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    It's also why you can't get moonroof and factory bed liner together (dealers just do the accessory liner and add the sticker instead)
  9. Oct 19, 2018 at 5:11 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Upgraded wheels/tires add weight too.
  10. Oct 19, 2018 at 5:54 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Mine has it too, but it says zero on the sticker :rolleyes:
    GNTundra and 4x4_Angel like this.
  11. Oct 23, 2018 at 6:18 AM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    I know why, mine had original tank of 26, it is upgraded to 38 gallons. That would lower the total carrying capacity since its total to entire vehicle.
    Did you get the upgraded fuel tank or something like that? It would augment the original factory value on an upgrade.
    4x4_Angel and 15whtrd like this.
  12. Oct 23, 2018 at 6:23 AM
    Albinator
    Utah
    That’s a good point, but no. I filled up when pretty low at it stopped pumping at almost 25 gallons.
    Someone said there could have been mods done before then put back to factory but I have no idea.
  13. Oct 23, 2018 at 6:26 AM
    15whtrd
    15whtrd Mr. Blonde
    Pretty low at 25 gallons would be only 1 gallon left if you had the small tank. I bet you have 38 gallon tank.
  14. Oct 23, 2018 at 6:34 AM
    phabej
    phabej New Member
    Did you buy it new or used? If it's new you should see the "upgrade" items on the window sticker. If it's used then no saying what was upgraded. I wonder if they upgrade the engine like how Chevy does, it can come with a V6 and upgrade to a V8 something like that would change the GVWR rating. Doesn't Toyota make 2 engine size displacements for the Tundra? Sorry I don't know since this is my first Tundra. :D
  15. Oct 23, 2018 at 6:41 AM
    Albinator
    Utah
    Used. Got in in April. I doubt it since this truck has the labeled 5.7L engine and the VIN indicates the same thing. I’ll have to check stickers or something to see if there is anything like that on it.
    phabej[QUOTED] likes this.
  16. Oct 23, 2018 at 7:42 AM
    Albinator
    Utah
    How so if when I fill up after the low fuel light comes on and it pumps to 22-23 gallons of fuel to put it back to full? Is there a label on the tank that would say that?
  17. Oct 23, 2018 at 7:44 AM
    phabej
    phabej New Member
    You're most likely on 26 gallon, from what I've heard 38 will make you fill up at 30 so you would need to fill 30 gallons or so. I haven't had to fill up my tank yet so.. i don't know LOL, I always fill it half way on all my trucks.
  18. Oct 23, 2018 at 7:47 AM
    15whtrd
    15whtrd Mr. Blonde
    When my low fuel light comes on it usually takes 19 or 20 gallons. They like to leave about 6 gallons of fuel in there to keep the pump cool. But I just realized you have a second generation which doesn’t have a 38 gallon option. Sorry my mistake. I was just surprised how low your tank gets before the light comes on.
  19. Oct 23, 2018 at 7:54 AM
    Albinator
    Utah
    Oh got it. I actually don’t know when I actually comes on, but it seems to do so when there’s around 4 gallons left.
    Yeah this sticker is a mystery.
  20. Oct 23, 2018 at 8:02 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I think the sticker itself is not a mystery anymore, but the 380 pounds certainly is. My truck came with the larger fuel tank, bed liner, deck rail system, tow bar (which might be standard), but my sticker only shows 33 pounds. 380 pounds is quite a bit.
    It will take some heavy iron like tow bar, skid plates etc. to add up to that. :notsure:
  21. Oct 23, 2018 at 10:52 AM
    Albinator
    Utah
    I got this in April of this year and haven’t noticed anything out of the ordinary to add this weight. Wheels, bumper, hitch look stock. There is the plastic bed liner in it but that can’t be 380 pounds.
  22. Oct 23, 2018 at 10:53 AM
    Albinator
    Utah
    So in order for this sticker to be added, this would have been a customized truck built at the factory and stuck on by them? Is there a way to find out by its VIN number or calling Toyota?
  23. Oct 23, 2018 at 11:17 AM
    ninjajay
    Spoolston, TX
    No, customized at the dealer or distributor, after it leaves the factory.
    Albinator[QUOTED][OP] likes this.
  24. Oct 23, 2018 at 11:57 AM
    15whtrd
    15whtrd Mr. Blonde
    Mine is in the door jam on the drivers side
    Albinator[OP] and NewImprovedRon like this.
  25. Oct 23, 2018 at 11:58 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t see what could’ve been added to make that much weight. I want to say it’s a typo
  26. Oct 23, 2018 at 12:15 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    No, but the SR5 upgrade or TRD off road upgrade will add weight. Factory has stickers for factory weights, then add additional stickers to upgraded packages would be my guess.
    15whtrd likes this.
  27. Oct 23, 2018 at 12:18 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    After Thanksgiving, your truck will have another 5-10 lbs reduced carry capacity as well.
    15whtrd and jewsNbrews like this.
  28. Oct 23, 2018 at 12:23 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    It means no fat chicks
    jewsNbrews and 15whtrd like this.
  29. Oct 23, 2018 at 1:47 PM
    Albinator
    Utah
    Yep, same here.
  30. Oct 23, 2018 at 1:48 PM
    Albinator
    Utah
    Mine isn’t the TRD model nor does it have the SR5 emblem on the truck, but the VIN does show it as an SR5.
