Yellow Box Speedo Calibrator
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Sep 22, 2018.
  1. Jul 23, 2020 at 6:29 PM
    #91
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Godspeed son
    04TundraTRD likes this.
  2. Jul 23, 2020 at 8:08 PM
    #92
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Yup, I unplugged all four sensors and the speedo wasn’t working.
  3. Jul 23, 2020 at 8:57 PM
    #93
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    BUT DID YOU STOP THE ODOMETER?!?!??
  4. Jul 24, 2020 at 4:53 AM
    #94
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    It will most likely throw a DTC and your ABS light should come on. The yellow box should work for you as long as you install it between the ABS ECU and the Speedo.
  5. Jul 24, 2020 at 10:12 AM
    #95
    2006Tundra
    Lou
    Long Beach, CA
    I wasn't paying attention to the odometer.
  6. Aug 14, 2020 at 11:18 AM
    #96
    Blueranger501
    Blueranger501 New Member
    Well got mine installed and it fires up but speedo is dead.
    Followed the instructions provided earlier: "
    The white wire from the Yellowbox will take the input form the ABS computer to the Yellowbox, the blue wire feeds it back to the speedo plug."
    See attached, in my case I spliced the green/black wire.
    Thoughts? Did I mix them up? Will email Yellr as well, can swap the leads closer to the box to see if that fixes is so I dont have to pull my dash cluster again.
  7. Aug 14, 2020 at 12:33 PM
    #97
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Blueranger501 they usually come with a bypass plug in case you want to remove the yellrbox, did you try clipping that in?
    Curious if your wiring is good and the yellrbox is bad or severely misadjusted.
  8. Aug 14, 2020 at 5:41 PM
    #98
    04TundraTRD
    Neil
    YB Wiring Harness colours;
    YB RED wire = POWER = Splice connect to Power source = +12vDC source
    YB BLACK wire = GROUND = Splice connect to Ground source = sensor
    ground is best
    YB BLUE wire (Green wire or Grey wire) = Output from Yellow Box to
    speedometer (speedo side of cut sensor wire)
    YB WHITE wire (or Yellow wire) = INPUT from Speed Sensor into Yellow
    Box (cut wire from speed sensor)
    This is directly from yellr. Sounds like you have the wiring right. Which version yellow box do you have? 2 wire or 3 wire?
  9. Aug 14, 2020 at 6:40 PM
    #99
    Blueranger501
    2 wire. Was wondering what that other plug was for. Will plug in and report back. If I have a speedo reading something is up with the unit. Thanks!
  10. Aug 14, 2020 at 6:43 PM
    #100
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I just ordered ver. 5 for the '12 Sequoia. Jennifer was a great help during my decision making. Now for the long wait.
    Darkness[OP] likes this.
  11. Aug 15, 2020 at 9:00 AM
    #101
    04TundraTRD
    Neil
    You’re going to have to exchange your unit for the 3 wire. The 2 wire is designed to convert a sine wave signal where the 3 wire converts a pulse signal. I had to do the same thing. I contacted yellr and they sent me a 3 wire and I sent the 2 wire back as return to sender in the same package.
    Darkness[OP] and SprinterAE86 like this.
  12. Aug 16, 2020 at 9:53 AM
    #102
    Blueranger501
    I wired it wrong at the connector since I had to run power and ground separate from the harness. Works perfectly and is dead on, amazing!!!! Thanks for the instructions and help! Will report back on shifting and if I notice any improvement.
  13. Aug 16, 2020 at 9:58 AM
    #103
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its a weird feeling to have the speedo accurate again.
    KarmaKannon and 04TundraTRD like this.
  14. Aug 16, 2020 at 11:16 AM
    #104
    04TundraTRD
    Neil
    Got that right!
    Darkness[QUOTED][OP] likes this.
  15. Aug 16, 2020 at 11:17 AM
    #105
    04TundraTRD
    Neil
    Just out of curiosity what was the issue?
  16. Aug 16, 2020 at 6:48 PM
    #106
    Blueranger501
    I wired to a dead line. Essentially I cut the splice harness in 2, running the white and blue wires from behind speedo down to driver kick well and the other for power off a fuse jumper under dash and a ground next to kick panel. Wired to the power and ground line harness which had blue and white wires attached to nothing. Hopefully that makes sense.
    Used the heat shrink solder combo connectors they work great just have to keep the wires in place while the heat gun does it’s work.
    And holy cow I haven’t had an accurate speedo for 16 years this is incredible!!!
    thanks for the help!
  17. Aug 16, 2020 at 9:52 PM
    #107
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those connections look nice ^
    04TundraTRD and Blueranger501 like this.
  18. Sep 16, 2020 at 6:14 PM
    #108
    Blueranger501
    For the 04 does anybody know if the ABS unit gets the speed signal from the ABS sensor or somewhere on the trans / t case sensors? Want to know as I’m considering a new spindle which would eliminate the ABS sensors.
  19. Sep 17, 2020 at 3:48 AM
    #109
    04TundraTRD
    Neil
    The ABS ECU receives a its signals from ABS wheel speed sensors.
  20. Sep 17, 2020 at 8:49 AM
    #110
    2006Tundra
    Lou
    Long Beach, CA
    Still waiting to hear about the 05-06 DC Tundras. :popcorn:
  21. Sep 17, 2020 at 4:52 PM
    #111
    04TundraTRD
    Neil
    The yellow box should work for you. Do you have questions about the install or are you waiting for one of the other ‘06 guys to confirm if it works? It uses a different color wire but the installation is the same.
  22. Sep 17, 2020 at 5:16 PM
    #112
    2006Tundra
    Lou
    Long Beach, CA
    I'm not in a hurry so I'm just waiting. I'm really hoping that yellr box can figure out a plug-n-play solution. If not, a step by step instructions or schematic.
    WhoAteMyWaffles and CodyP like this.
  23. Nov 27, 2020 at 7:02 AM
    #113
    Chucktoons
    Chucktoons New Member
    Charlton
    2016 Tundra
    In mid October I ordered a yellow box for my Jeep. Since then I have received no communication from them other than the payment receipt. Emails to them have gone unanswered. I’m going through PayPal to get a refund.
  24. Nov 27, 2020 at 7:08 AM
    #114
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats really unusual. They answered my emails right away.
  25. Nov 27, 2020 at 7:14 AM
    #115
    Professional Hand Model
    Hand Protectors
    Everything is changed now. Service has dropped across the board in most industry.
  26. Nov 27, 2020 at 7:52 AM
    #116
    Chucktoons
    Charlton
    2016 Tundra
    They responded to my emails when asking questions before I ordered. After that it’s been crickets. I understand the COVID thing is impacting everyone but it should have at least shipped in the last 40 days. No communication since and no response to my emails in the last 2 weeks does not seem reasonable. Was going to order one for my tundra but I think I’ll look elsewhere unless something drastic happens after going through PayPal to resolve.
  27. Nov 27, 2020 at 8:01 AM
    #117
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  28. Nov 27, 2020 at 8:42 AM
    #118
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    I see that it includes 00-05 Tundras. Anybody here ever use Speedhealer?
    2006Tundra and Chucktoons like this.
  29. Nov 27, 2020 at 11:42 AM
    #119
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Shows it MAY fit newer models as well the added asterisk which would be nice for us 2006 guys
    KarmaKannon and WhoAteMyWaffles like this.
  30. Nov 27, 2020 at 1:42 PM
    #120
    Chucktoons
    Charlton
    2016 Tundra
    Thank you Glock 40. This looks like the way to go for the Jeep if the Yellowbox does not work out. Looks like it may not work for my 2016 Tundra so I still have to figure that out.
    Thank you!
    Glock 40[QUOTED] likes this.
