Yaw Rate sensor on 2006 Toyota Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by 19Voodoomax, Oct 30, 2021.
  1. Oct 30, 2021 at 5:18 PM
    19Voodoomax
    19Voodoomax [OP] New Member
    Mark
    Dundee,Oregon.
    2023 Tundra TRD Pro
    My next door neighbor’s son has a 2006 Tundra Limited. He needs to do a Zero Point Recalibration on it but can’t seem to find the module. He was told to shim it after putting a leveling kit and bigger tires on it but, can’t find it. He’s been told where it’s supposed to be located it the truck but, It’s not there ! He’s even had a mechanic who has worked for Toyota dealership for 22 years look at it and he could not find it either. Does anybody with a 2006 Limited have any idea ?
  2. Oct 30, 2021 at 5:35 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I’ve tried to find mine as well. It’s no where interior wise that I can see
  3. Oct 30, 2021 at 5:46 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  4. Oct 30, 2021 at 5:55 PM
    Black@Blue19
    Ken
    SE Texas
    Turn the ignition switch ON. (2) Keep the vehicle stationary on a level surface for 2 seconds or more. (3) Check that the VSC warning light blinks as shown in the illustration. HINT: • If the VSC warning light does not blink, perform the zero point calibration again.
    this was posted for the Yaw????
    https://m.youtube.com/watch?v=V1vgVfOATN4
  5. Oct 30, 2021 at 10:12 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Look up zero point call. I believe it’s the 4 and 12 pin on the OBD2 port, tap them with a paper clip a certain number of times and do some key on offs. Then it beeps and it’s set. It’s been about 10 months since my last reset.
    Note, the slightest changes to your truck once it’s lifted will require doing this over and over again. I mean they are so sensitive that a 2psi change in the tires will require a reset. If you live in the valley and don’t drive winding roads you’ll probably be fine.
    I have been through this with 2 Tacoma’s and now my Tundra. Absolute pain is the a$$. Oddly the 07’ Sequoia and 16’ 4Runner don’t have this issue. :frusty:
