Yakima showcase 20 on Diamondback Cover
Discussion in '2.5 Gen Tundras (2014-2021)' started by localmotion, Aug 12, 2021.
  1. Aug 12, 2021 at 11:09 AM
    localmotion
    localmotion [OP] New Member
    Hi all!
    I recently installed my Diamondback HD and have been thinking about ways to mount removable crossbars when I need the space/accessory.
    I have come up with the Yakima Baseline Tower, which should fit like the previous Yakima Q-Clips with the Core bars.
    Yakima Basetowers
    https://yakima.com/products/baseline-towers-4-pack
    Yakima Showcase
    https://yakima.com/products/showcase-20
    Question- assuming there is adequate spacing between the load bars, are there any issues with having the rear of the cargo box stick out approx 16" past the tailgate?
  2. Aug 12, 2021 at 11:14 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Not sure what your budget is, but I’d suggest mounting Yakima rails with landing pads and skyline towers. Would be a cleaner and more secure rack. Just my $.02
  3. Aug 12, 2021 at 11:17 AM
    localmotion
    Thanks Dittothat! I looked at that but liked the idea of keeping a clean look when the Yakima system was not in use.
    Do you think mounting the rails create a significantly safer solution?
    Mater likes this.
  4. Aug 12, 2021 at 12:29 PM
    localmotion
  5. Aug 29, 2021 at 12:06 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Sorry, just seeing this. Depends on what you’re hauling in the cargo box. If it’s light stuff like just skis or suitcases I don’t think it matters either way. If you’re hauling heavy items then you might want to go with the permanent option. That being said not sure how strong the permanent option is because I believe the highest rating for any Yakima rail product is like 120lbs dynamic force which is very little. These towers are just made of a resin material I believe and could easily snap. I see people driving around with roof top tents all the time using the Yakima products and think to myself “there’s no way that thing is staying put in a collision or hard braking scenario.”
  6. Aug 29, 2021 at 1:51 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Get the front runner system right from the Diamondback website. Bars remove with loosening a few screws, and then you only have the rails979B41A3-8DE2-4641-B4F9-0FCE2B69B60B.jpg979B41A3-8DE2-4641-B4F9-0FCE2B69B60B.jpg
