Would this make you mad?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota707, Dec 31, 2020.
  1. Jan 1, 2021 at 1:35 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Following as I want to know what the outcome was. I would follow the advice of all others. The conversation would have not gone well with me when they had the balls to say you owed them $280 for the new hinges.
    Good luck OP keep us posted.
  2. Jan 1, 2021 at 4:59 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    It's amazing to me that a tailgate has 1 moving part, and they STILL got it wrong. Unacceptable. Completely and utterly unacceptable.
    GODZILLA, Gunship Guy and ColoradoTJ like this.
  3. Jan 8, 2021 at 8:53 PM
    Yota707
    Yota707 [OP] New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Just wanted to give you guys an update. Picked up the truck on Wednesday and they installed new hinges and painted them white at there collision center at no charge. Then they actually fixed the real problem replacing the tailgate strut. Total was $380. I feel they made it right at the end and I’m glad to have my truck back. Thanks again to everyone who gave me feed back for this issue.
  4. Jan 9, 2021 at 6:55 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    That is good to hear. Too bad you had to diagnose the problem yourself. :thumbsup:
  5. Mar 3, 2021 at 10:45 PM
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    I had this happen to me in the opposite order. They replaced the strut first, covered under bumper to bumper warranty. Slow close worked for about a month before the bushing on the driver side hinge split in half and then that started causing the tailgate to slam again. Dealer immediately told me the bushing itself wasn’t sold separately. Bought the whole hinge. I’m going to try removing bushing off hinge and throwing it on my painted tailgate bracket
  6. Mar 3, 2021 at 11:17 PM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    Yeah now I feel like the new strut they put in is still the soft open but it’s not the same how it used to be so now I’m thinking the hinges will need new bushings as well but I’m not a fan of the bare metal look
  7. Mar 3, 2021 at 11:21 PM
    New_DoorDing
    I’m going to try using bushing only from new hinge and putting it on original painted hinge tomorrow. I’ll let you know the result
  8. Mar 4, 2021 at 4:06 AM
    blanchard7684
    blanchard7684 New Member
    Especially since it would be painfully obvious that the tailgate was not working as designed.
    Kerch71[QUOTED] likes this.
  9. Mar 4, 2021 at 7:09 AM
    New_DoorDing
    It’s not that simple. Either the strut OR the tail agate bushing can cause the slow open function not to work. I had to replace both. Looks normal until you look from the right angle, then you can see the bushing is cracked
  10. Mar 4, 2021 at 8:26 AM
    New_DoorDing
    Bad news, bushing does not come off the driver side tailgate hinge. Walked into the first body shop I drove by and they’re charging me 40 dollars and will be mixing fresh paint to match my color code.
  11. Mar 6, 2021 at 5:51 PM
    Kerch71
    Mechanicsville VA
    Good to know. If it starts happening to my tailgate, I'll replace the bushings and the strut.
  12. Mar 6, 2021 at 6:55 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Glad it worked out, to me 380 dollars I would hold the tail gate as it went down. but that's just me
    Jernik and Cpl_Punishment like this.
  13. Mar 7, 2021 at 5:31 PM
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    Engineers must work alotta OT just to make vehicles this complicated?
    Tundratoofun likes this.
  14. Mar 8, 2021 at 7:31 AM
    New_DoorDing
    If you purchase hinge from Toyota ($60) then get the hinge painted ($40), you can then install yourself. Watch YouTube vid on Tundra tailgate removal, then read up on self install from forums on here, you could solve the problem for about 100 bucks
  15. May 5, 2021 at 7:24 PM
    woofhauler
    woofhauler New Member
    Pacifica, CA
    My Tundra is at the dealer now because the upper part the damper attaches to broke off. Dealer called me back and said there's no damper and the tailgate is supposed to slam down. Don't have a lot of confidence when I have to be the one telling the dealer to remove the driver side tail light to see that there is in fact a damper.
    Will be an interesting fix, as far as I can tell it's a plate that's welded on that needs to be replaced.
    LarryDangerfield likes this.
  16. May 5, 2021 at 7:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    My bearing broke years ago, I have the part, but I stripped the torx head on it, and have just dealt with it popping out in inopportune times.. like almost getting robbed and it decides to not go in and I have to pull it completely out and reset both sides....
    New_DoorDing likes this.
  17. Jun 4, 2021 at 1:07 PM
    New_DoorDing
    I actually had such a difficult time removing that torx bolt that I snapped my tool. I knew I had to bring it to the local mechanic once this happened. They had a heavy duty torx screw driver that he could hammer as he loosened. Sucks that happened to you. mwy have to just drill it out at this point and order another bolt
    blackdemon_tt[QUOTED] likes this.
  18. Jun 4, 2021 at 1:36 PM
    blackdemon_tt
    Yeah... i know... ill have to give in and do that
  19. Jun 5, 2021 at 2:43 PM
    #49
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    At least it was your tool and not your nipples that got snapped ! lol
