Would this level my truck?
Discussion in 'Suspension' started by abpadilla1794, Oct 27, 2019.
  1. Oct 27, 2019 at 11:49 AM
    abpadilla1794
    abpadilla1794 [OP] New Member
    Alexis
    Black 2016 Toyota Tundra 1794 4x4
    So not sure if it’s an upgrade but I ended up getting a pretty good deal on some Bilstein 4600 that has a 2” leveling kit already installed on the shocks but I’m looking to replace my stock shocks on my 1794 to the 4600’s
    I also ended up purchasing CB+2, my goal is to have the truck leveled but maintain the factory rake. :monocle:Would my setup (goal) work? Any input would be greatly appreciated :cheers:
  2. Oct 27, 2019 at 12:29 PM
    Tundyfundy
    Southern California
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    First off in order to keep factory rake you need to lift both the front and the rear the same height. Since you have a 2 inch leveling kit, you need to lift the rear 2". You bought the coachbuilder +2 but unfortunately that shackle only will give you 1.25 inches of lift in the rear. With that setup you will lose 3/4" of rake. the +3 coachbuilder should give you 1.75" of lift so you'll only lose 1/4" of rake.
    Now that I answered your question here are a few things to know.
    The 4600 shocks and coils will ride rough on your truck. Not to mention it sounds like your planning on installing a spacer lift, which can damage your suspension. If you're planning on keeping the truck on the pavement just picking up kids and such then I'd say you will probably be ok with these shocks and lift (except for the harsh ride). Some guys run spacers but they may further degrade the ride of your truck. (I had the TRD package ie 4600 shocks all around and I hated the harsh choppy ride.)
    For around a 1000 dollars you could have an actual suspension lift that will increase ride quality, Performance, and ride height. Also adjustable https://www.4wheelparts.com/p/bilst...ogle_1749763888_65275301221__pla-530275848868
    these are the fronts. The rears you can go a few different ways but these are commonly paired with these... https://www.4wheelparts.com/p/bilstein-5160-series-shocks/prod40017 .
    I went with this setup and highly recommend it as a budget friendly MOD that you will feel everytime you drive your truck. Good Luck!
  3. Oct 27, 2019 at 1:02 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    What he said...
    I have the set up above with coach builder shackles (after a rear block lift that I removed and would gladly give away) You have a nice truck.
    I would add... IMO, as well, spacer lift is not a good ride and affects how she handles and feels on the road. What you do, you will experience every inch you drive this truck moving forward.
  4. Oct 27, 2019 at 1:49 PM
    abpadilla1794
    Alexis
    Thanks fellas for the advice, so I’ll end up having to save up for 6112/5160 but I could at least level the truck with 4600s and the level kit and wait to install the CB+2 until I get the 6112s? I shouldn’t have any issues with that right ?
  5. Oct 27, 2019 at 3:04 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    The 6112 is an adjustable lift/leveling kit with coil over springs. I paid about $350 (glad I did) for a complete install front with unmounted springs, rear shocks , and alignment. I am not familiar with the 4600 level, so can’t answer your question definitively, but unless you install them yourself, you will spend money that you could put toward the 6112’s? I am cheap, and money saved = more mods, so, unless my saving for these things would need to be long term, I would sell what I have while it’s in good shape and only do it once
  6. Oct 27, 2019 at 3:21 PM
    abpadilla1794
    Alexis
    I hear ya man, I am definitely gonna install them myself. I’m just torn cause I spent the $275 for the 4600 with the leveling kit which only had about 1000 miles on them. With the setup I have it sounds more or less of a leveling kit rather than keeping the factory rake?
  7. Oct 27, 2019 at 4:22 PM
    Tundyfundy
    Southern California
    You should not have any issue but why do it twice. You could also go with the bilstein 5100's and that would probably be an ride upgrade as well just not as drastic as the 6112. In my honest opinion, I know you already spent some money but I would never put those 4600 back on my truck ever.
    For what its worth you can also take that spacer off and install it over your current front coilovers as well. The 4600 are the same ride height as stock. You'd probably have a smoother ride this way. There are so many options you just have to decide what you want out of this.
    Luckydog likes this.
  8. Oct 27, 2019 at 4:25 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Went from stock trd offroad( not sure if those are 4600) shocks to 5100. Noticeable improvement. Although would recommend 6112 as well
    Tundyfundy likes this.
  9. Oct 27, 2019 at 4:26 PM
    Tundyfundy
    Southern California
    yes the TRD package is what hes asking about (bilstein 4600) the yellow and blue shocks
    14CRWMX[QUOTED] likes this.
  10. Oct 27, 2019 at 5:31 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    So, I get it now, I have the TRD and what you bought is is what I had on before. They are a decent shock, but 6112 set-up is hands down much better so hard to really compare the two IMO. A plus is with only 1k miles they have some value.
    I would think long term. Coach builder shackles are your best current item. It’s a great company and they might be willing swap you if your set is still brand new and you purchased from them.
    I installed the 6112 set before I did the rear lift with a setting of 1.9. The truck was leveled, looked great and drove well. I added a 1 inch block and soon after the shackles for a 1/2 inch gain. It still has a slight rake.
    I wouldn’t waste those new shackles on a temporary lift. Like the previous post suggested, if you want to ultimately end end up with more of a rake at the top setting on the 6112’s, this will be determined by the rear shackles.
    lOL it’s a lot to consider and there is even more . Personally, unless you are in need of new shocks on your truck, I would delay gratification and cash out of what you bought, and get the final setup. But if you want to level the truck with a stiffer ride right away, then go for it.
    I read every thread I could find on lifts for quite a while before settling on the setup people are recommending. And even then, I foolishly cheaPedroso out with a block lift in the back and they were right about that too... right about headlamps, figs, and exhaust, and on and on
  11. Oct 27, 2019 at 8:35 PM
    abpadilla1794
    Alexis
    Thanks fellas for the advice it definitely helped me out in deciding what to do :thumbsup:
  12. Oct 27, 2019 at 9:17 PM
    Tundyfundy
    Southern California
    keep us updated and post some pics when your done!
  13. Oct 27, 2019 at 9:42 PM
    abpadilla1794
    Alexis
    You got it buddy !!!
  14. Nov 20, 2019 at 2:15 PM
    GATORthaBEAST
    GATORthaBEAST New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    I’m essentially in the same boat as OP. It seems every truck is different and every truck owner is different. Some people say they put in a 2” spacer and it rides the same. Some say it rides rough. Some say 5100s on top setting is rough, but middle setting is good. I bought a 2” aluminum spacer before doing research online and on this forum. Haven’t put it on yet. Waiting for my wheels to come in so I can have it all done at once. I can’t make up my mind. Put in the spacer? 5100s or 6112s? I just want it level. 2019 2WD CrewMax
  15. Nov 20, 2019 at 2:22 PM
    abpadilla1794
    Alexis
    8D0EB2A1-4EBB-4D23-8FEB-3C77CA183A8D.jpg 118629B4-802E-455B-9044-FDD66CC2BD2A.jpg I felt the same way buddy but for the most part everyone is very knowledgeable in here. I ended up going with the 2” spacer with the coach builder + 2 to get a little bit of rake. It all depends what your needs are. My truck for the most part will be a “ pavement princess” Hope this helps a bit!!!
  16. Nov 21, 2019 at 5:56 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    6112’s at middle setting is a leveling kit. This is what I started with and later added coach builder shackles 1”. There is a dramatic difference in ride and handling from OEM. Is it stiffer? Slightly, but handling and feel in the road is more than worth it.
    I wouldn’t do spacers. Maybe some coach builder shims on the drivers side. I have a couple of new ones lying around somewhere. I got them after installing the coil overs and it’s too much of a PIA to retrofit at this point.
    Mine has the 1/2 inch net rear shackles lift. Otherwise it’s straight 6112’s at middle setting.
