Would this be good for my 2001 tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by Riley_Nutt, Jun 27, 2019.
Yes or no
  1. Yes
    0 vote(s)
    0.0%
  2. No
    100.0%
  1. Jun 27, 2019 at 11:41 PM
    Riley_Nutt
    Riley_Nutt [OP] New Member
    Riley
    2001 tundra TRD
    Yes or no
  2. Jun 28, 2019 at 3:07 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I bet the Bilsteins on the front would ride better than the rancho and that tire is going to require quite a bit of trimming to clear.
    because_wumbo-truck likes this.
  3. Jun 28, 2019 at 8:52 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've never heard much about Rancho on our trucks. I'd probably go with OME.
    Also, I don't see how you would fit that big of tire up front unless that's one hell of a lift.
  4. Jun 28, 2019 at 9:46 AM
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    That tire size seems pretty big.
    Is your Gen 1 4x4? If you are going to lift your gen 1 more than 2" in front, you will need to add UCAs and a diff drop to your list. Otherwise your upper ball joints will be over extended and clunk like hell over all bumps and your CV boots will be constantly tearing or slipping off of the seal.
  5. Jun 28, 2019 at 9:59 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Lose the 3" black nerf bars. Get some real sliders. Unless you just plan on mall crawling.
  6. Jun 28, 2019 at 11:39 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Don't get the Rancho front lift. Go Bilstein, OME, or something along those lines with a trusted track record.
    Those tires will likely rub, as others have mentioned. Unless spacers are added I think you will have issues, and possibly you will even have issues with spacers. Not sure.
    If you like those Nerf bars, you do you man.
    Also it was mentioned but it's worth repeating, you will likely need UCA's and a diff drop. Diff drops is cheap, like $30 or so and helps correct driveline angle. UCA's help correct angle as well, but there is significant cost there.
    because_wumbo-truck and MAK like this.
  7. Jun 28, 2019 at 4:14 PM
    Professional Hand Model
    Hand Protectors
  8. Jul 17, 2019 at 12:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    bmf4069 likes this.
  9. Jul 24, 2019 at 4:31 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    Another with unsatisfactory Rancho experience.
  10. Jul 24, 2019 at 9:08 AM
    andrew8404
    andrew8404 New Member
    Andrew
    I just got the Rancho quick lift shocks front and rear for my 2006 Tundra for 500 bucks to my door. Went on a wheeling trip this weekend and was super impressed with them. I’d say there a better ride then the 5100s but haven’t had them long enough to comment on durability vs the 5100s. The problem with the 5100s is you still have to buy a new spring/top hats and they aren’t put together unless you pay extra money. So the 5100s are still over 650 plus dollars. Also the shock is super compressed on those with a 2 inch lift. My advice if your weary of Rancho is get the Bilstein 6112s which is a way better shock then the 5100s and comes with a spring already. Just needs to be installed with new top hats if yours is old. Also, those nerf bars are worthless and if your doing any off-roading they will get torn up quick. Didn’t see the 35s either. That will be a tuff fit.
