Would FFV prevent you from purchasing?
Discussion in 'General Tundra Discussion' started by gdog_Tundra, Dec 28, 2018.
  1. Dec 28, 2018 at 1:04 PM
    gdog_Tundra
    gdog_Tundra [OP] New Member
    VA
    2016 Limited CrewMax
    3 inch ToyTec coilovers, Dakar Leaf pack, Dirty Deeds 8 inch stainless exhaust, LED DRL headlights
    So after reading endless threads on FFV, gas types, oil changes, etc..... Should the FFV platform be avoided at all cost or would a FFV truck be acceptable if one was always planning to run 87 or higher octane? Would you still buy the truck if it was exactly what you want i.e. color, options, price?
    Thanks
    G
    Black Wolf likes this.
  2. Dec 28, 2018 at 1:07 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    There is no problem with buying an FFV truck. I would never use ethanol simply because it has a lower energy density than regular gasoline and the idea of using corn as fuel is stupid.
  3. Dec 28, 2018 at 1:08 PM
    gdog_Tundra
    VA
    Agreed....corn based alcohol is for drinking!
    G
  4. Dec 28, 2018 at 1:10 PM
    Grumpy Uncle
    Pat
    CO
    Like @computeruser6 said, just dont use E85. I have an FFV and never used E85 only real dino 87.
    GODZILLA, nvrgvup444, rodm1 and 2 others like this.
  5. Dec 28, 2018 at 1:11 PM
    computeruser6
    Dirk
    Escondido
    I wish that I could get 100% real gasoline where I live...
  6. Dec 28, 2018 at 1:15 PM
    Grumpy Uncle
    Pat
    CO
    I have 2 places by me that I can get it from. The Marathon is only convenient if I am I work.
  7. Dec 28, 2018 at 1:16 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Ditto
  8. Dec 28, 2018 at 1:58 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Same here. I have a FFV and have never had any fuel related problems. I have never run E85 though, I stick to 89 with no ethanol from a local station. Corn is for feedin' critters not trucks.
  9. Dec 28, 2018 at 2:23 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I'd avoid it unless it was heavily discounted. I had a FFV Chevy before I bought the Tundra and had several problems. E85 requires a different compression ratio, specially coated pistons, and extra sensors that gas only systems don't require. E85 also causes emission control issues in some vehicles. One of the sensors went out in the Chevy. Chevy's price for the sensor? $750.00 Is it necessary even if you don't run E85? Yes, you have to have it to make sure the engine isn't running too rich or too lean, and to pass emissions tests. I managed to find a replacement at a much cheaper price, but other E85 related parts and sensors might not be available at a lower price.
    Runnerstrom28 likes this.
  10. Dec 28, 2018 at 2:25 PM
    gdog_Tundra
    VA
    Thanks...this is the exact kind of data I am looking for....
    G
  11. Dec 28, 2018 at 2:27 PM
    Ditto the ditto.
    TXMiamiFan[QUOTED] likes this.
  12. Dec 28, 2018 at 2:34 PM
    Don't sweat it. When I was up in Anchorage most new gas trucks, irregardless of make that I saw on the car lots and just driving around up there in town were FFV. Anchorage gas stations have no BS E85 or even 10% ethanol. All gas up there is refined in Fairbanks and piped down to Anchorage. 100% pure North Slope dino juice...like I said...don't sweat it...
    FYI....I run with Maverick pure dino 87 most of the time but occasionally I take advantage of grocery store fuel points and the gas is possibly up to 10% ethanol. I do have a non FFV motor..
    UTTundra likes this.
  13. Dec 28, 2018 at 3:53 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Nah just don't use E85, I figure the FFV fuel system will be a little more tolerant of E10 and E15 if that ever becomes a thing
  14. Dec 28, 2018 at 4:00 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Mine is non-Flex, but I would not hesitate to buy a Flex. It seems that the kinks have been worked out now.
    No matter what, I would not use E85. But it may come in handy in a Zombie Apocalypse.:D
  15. Dec 28, 2018 at 4:01 PM
    E85 is best to flame out zombies....
  16. Dec 28, 2018 at 4:28 PM
    Donkeypunch
    Donkeypunch New Member
    I wish mine was flex. I have a different opinion on Ethonal. I converted my fuel system to run on E85 and E90. Made 950rwhp on E85 on my other Toyota. Coated pistons, anodized this, that is all just non-sense. The only draw back to E85 is if you don’t drive the vehicle and let it sit for long periods of time (months) as it draws in moisture.
    The other issues such as oil or spark plugs is just using the right oil and plugs. Oil with zinc in it like Brad Penn or Shell Rotella and a spark plug greater heat rang or colder plug. E85has an Octane rating equal to 110.. The engine won’t pull as much timing, make more torque and less tendency to detonate since it’s a fuel than cools the cylinder as it vaporizes.
  17. Dec 28, 2018 at 4:33 PM
    FXFormat
    FXFormat New Member
    Oil just gets dirtier faster with FFV, that's the only negative i can think of. MPG is even shittier with E85, so if all things being equal on 2 trucks, i'd go with the non FFV one. If the FFV one was a grand or more cheaper, then i might consider that.
  18. Dec 28, 2018 at 4:38 PM
    What Yota did you have that got 950rwhp? Just curious...
  19. Dec 28, 2018 at 4:39 PM
    Donkeypunch
    I have found the MPG issue to be a wash as E85 is much cheaper than 87 in Texas. Anywhere from $0.60 to a $0.80 cheaper in some seasons.
  20. Dec 28, 2018 at 4:39 PM
    Donkeypunch
    See my avatar
    Bo-Hunter and Black Wolf[QUOTED] like this.
  21. Dec 28, 2018 at 4:41 PM
    flying dave
    flying dave New Member
    NC
    I'd say check his avatar....
    Doh: too late. lol..
  22. Dec 28, 2018 at 4:41 PM
    I'm not too sure how Toyota"farms" out the FFV Tundra. Whatever it is..doesn't make sense as in no ethanol based gas in AK but a Hell of a lot FFV trucks dumped there by barge in Anchorage...
  23. Dec 28, 2018 at 4:42 PM
    I was thinking that. Bad ass!
    but not a Tundra...yet??
  24. Dec 28, 2018 at 4:45 PM
    flying dave
    NC
    I just looked at his avatar a little closer for the first time.
    I think I would change bad to sweet..... :thumbsup:
  25. Dec 28, 2018 at 5:01 PM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I agree I owned a modified Fox Mustang and it made 950 rwhp on E85. then I moved to north Idaho and no E85 within 3 hrs of me...
    It was a Dart 363 with a single 76 on it, 120lb injectors and 23 psi I liked E85 a lot when I could get it.
    Donkeypunch and Black Wolf like this.
  26. Dec 28, 2018 at 5:05 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    My 2013 tundra is ffv and I haven't had any problems.The ffv trucks have injectors with bigger fuel holes and the entire fuel system is coated to prevent rust from using the e85. The fuel pump is also stronger.So actually the ffv trucks are better from that stand point
  27. Dec 28, 2018 at 5:05 PM
    But......OP is concerned about getting a stock FFV Tundra vs non FFV....
  28. Dec 28, 2018 at 5:08 PM
    My non FFV 07, as in 11 years old, is still running strong and no cam tower bs, and zero fuel delivery issues from my 11 year old non-FFV fuel pump...again...better in what regards???
  29. Dec 28, 2018 at 5:08 PM
    tenntundra
    Walter
    Tennessee
    I wouldn't have any concerns.just don't use e85!
    rodm1, Black Wolf and gdog_Tundra[OP] like this.
  30. Dec 28, 2018 at 5:30 PM
    FXFormat
    FXFormat New Member
    Man you're gonna make me bust out my 1000 crank HP Toyota as well
