Workin' truck
Discussion in '1st Gen Tundras (2000-2006)' started by Cody06tundra, Nov 4, 2019.
  1. Nov 4, 2019 at 11:44 AM
    Cody06tundra
    Cody06tundra [OP] New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    Who here uses their truck for towing or hauling for work and what kind of work do you do?
    I'm going to be using mine for towing motorcycles in an enclosed trailer nationwide.
  2. Nov 4, 2019 at 12:23 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Only slightly off topic: are you starting a business doing this?
  3. Nov 4, 2019 at 1:00 PM
    Cody06tundra
    Cody
    Yes, sometime after the first of the year.
  4. Nov 4, 2019 at 1:14 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Can I assume that your truck came with factory towing pkg.?
    Air bags and a Hellwig rear sway bar... maybe a weight distribution hitch.
  5. Nov 4, 2019 at 3:23 PM
    Cody06tundra
    Cody
    Yes I do have the factory tow package. And to get my truck ready I'm going to be doing the timing belt and water pump this month, the upper and lower ball joints, spark plugs, I've already changed all the fluids, I'm going to be getting a set of the 12-hole injectors from Dirty Deeds probably next month, I will look into the rear sway bar. And they need weight distribution hitch I'm definitely going to get.
  6. Nov 5, 2019 at 3:26 AM
    tvpierce
    Maine
    Nice. I know there's demand for quality service in this field. Good luck!
  7. Nov 5, 2019 at 4:23 AM
    Rex Kramer
    Georgia
    Make sure the brakes are good to go, lubricate everything that can be lubed and look at the wheel bearings
    because_wumbo-truck likes this.
  8. Nov 5, 2019 at 4:31 AM
    Rex Kramer
    Georgia
    Are the radiator and thermostat healthy?
  9. Nov 5, 2019 at 5:51 AM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    In the towing for hire industry the cost to do it right isn't cheap with used gas trks having over 100,000 miles.
    I'd replace the trans before you start. You'll avoid the nightmare from happening when a 1,000 or more miles from home.:)
  10. Nov 5, 2019 at 11:07 AM
    Cody06tundra
    Cody
    The brakes are all brand new. Bearings are good.
    Brand new radiator and thermostat. Previous owner hit a deer and busted radiator so I had no choice on that one. Would have done it anyway. And new Zerex pink antifreeze.
    Thanks everybody for your insight and comments.
  11. Nov 10, 2019 at 7:06 PM
    Ccwave
    Ccwave New Member
    Casey
    Nevada
    2006 Toyota Tundra Limited Double Cab 4WD
    Frontier Grille guard, Tool Box
    I use mine for Pipeline surveying, where I'm forced to do minor rock crawling not going to crazy. I towed my small RV a couple times when our company asked us to move but Its perfect for what I'm using it for.
    Cody06tundra[OP] likes this.
  12. Dec 28, 2019 at 8:30 AM
    cammiller
    cammiller IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    I own a lawn service and use my 2004 Tundra as my main towing vehicle. I tow anywhere from a 7,000 lbs Kubota Tractor to my loaded equipment trailer with 3 ZTR’s, 4 weed eaters, 2 edgers, and about 15 gallons of spare fuel. Factory tow package. I love my truck.
  13. Dec 28, 2019 at 8:57 AM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    I drive to work in mine, does that count? :bananadance:
  14. Dec 29, 2019 at 4:23 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I’ve towed extensively with my truck. It does good work, but depending on what kind of weight you tow and what kind of terrain you’re driving over makes or breaks it.
    honestly I have a hard time recommending a first gen for towing professionally because fuel economy is so poor. $.25 a mile for fuel alone is pretty steep. A 3/4 ton diesel would cut down to $.17 a mile or maybe less depending on the weight of the trailer.
    Now obviously the Tundra is a great, reliable truck, but that reliability comes at a huge price, especially if you’re putting on 30,000 miles a year. That’s $2,500 a year in fuel saved assuming 30k miles.
    you should really do some hard math on costs. That’s my recommendation.
