Workflow and tools question
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Jul 11, 2020.
  1. Jul 14, 2020 at 3:35 PM
    #91
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    We are talking less than a half inch of shaft travel, its .7 height at the wheel and that's around .43 at the shock. o_O
    Throw a shim on top and the shaft travel is the same but your full extension distance from coil bucket to lower shock mount is different now, effectively increasing droop.
    Pick your poison, but spending time and money on something that minor seems like a waste.
    robabeatle[OP] likes this.
  2. Jul 14, 2020 at 3:43 PM
    #92
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I definitely see what your saying. And I agree it’s minor. But I think as far as the droop he is just correcting for a already existing lean so the distance between shock bucket and lower shock mount is already different due to that droop. He’s just correcting for that so the distance should be the same after the shim.
    Basically if he put Two coil overs set at the same height without a shim he would have a different distance between that shock bucket and mount. So the shim is extending the short side to match the side that’s not drooping, so I don’t agree that the distance will be different regardless if he eats up that droop with a different setting or a shim.
    We both agree it’s minor but we also both agree that a difference exists. That’s all I’m saying.
  3. Jul 14, 2020 at 3:45 PM
    #93
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Don't take it the wrong way but if I sold spacers and called them shims I'd tell you they're the way to go too. I can't pretend that adding a spacer on top of a coilover fixes a perceived problem without adding another.
    Best solve is to put a second gas tank on the passenger side or drive around with a big friend sitting shotgun. :D
  4. Jul 14, 2020 at 3:49 PM
    #94
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Yeah I get that. Thanks again.
  5. Jul 14, 2020 at 4:11 PM
    #95
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not true at all. You're mixing ride height with available suspension travel, they're not the same. These trucks dont have lower driver side with factory suspension, the coils are side specific. This kit is using matching linear springs, that is where the slight lean comes from.
    Put a spacer on top and you'll have an increased effective droop, plus a decreased effective compression (defined as distance between coil bucket and lower shock mount).
    Don't use a spacer and do what Bilstein says, you'll have the same compression and the same fully extended droop. The "eaten up droop" isn't gone, you are just riding with .4" more shaft exposed on the passenger side. That won't make a bit of difference. You have the same absolute travel available.
    Not trying to argue, so don't take it that way, but I've seen the myths of preload and its effects on travel floating around the internet forever. I usually avoid this topic because most people are sold on it. I've made measured adjustments to my own suspension enough times to call it false.
    :hattip:I'll end on that.
  6. Jul 16, 2020 at 11:17 AM
    #96
    robabeatle
    AZ
    okay replacing the bar end links and bushings for the sway bar. drivers side done but passenger side lower link bolt stuck. tried needle nose lock jaw with regular lock jaw at the same time with a 17 mm wrench but the whole dang thing is rotating.
    ideas?
  7. Jul 16, 2020 at 11:20 AM
    #97
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Tear the boot off and lock those vise grips closer to the tire down on the stud from that side.
  8. Jul 16, 2020 at 11:24 AM
    #98
    robabeatle
    AZ
    i already have the boot off and sprayed some brake cleaner in there. tried that three times.
    maybe I just dont have the lock jaws as tight as can be. i used both hands to clamp it down but i do have a very weak left hand
  9. Jul 16, 2020 at 11:28 AM
    #99
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Did the Allen not hold the center part of the bolt?
    Sawzall or grinder that B if your getting news ones
  10. Jul 16, 2020 at 11:32 AM
    #100
    robabeatle
    AZ
    The allen only held at the start. So, if I need to grind/cut this thing off, what is a good tool to get that is versatile and I can use elsewhere? I don't have either now. I think a sawzall would be crazy under the truck!
  11. Jul 16, 2020 at 11:33 AM
    #101
    Festerw
    Festerw New Member
    04 Tundra DC
    Hacksaw will make fairly quick work of it, plus they're cheap.
  12. Jul 16, 2020 at 11:38 AM
    #102
    robabeatle
    AZ
    Nut splitter?
  13. Jul 16, 2020 at 11:38 AM
    #103
    robabeatle
    AZ
    I think I have one of those with a metal blade...checking...
  14. Jul 16, 2020 at 11:39 AM
    #104
    robabeatle
    AZ
    not sure what blade this is
  15. Jul 16, 2020 at 11:59 AM
    #105
    robabeatle
    AZ
    boo yah fellas
    bmf4069, Festerw, Azblue and 2 others like this.
