Workflow and tools question
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Jul 11, 2020.
  1. Jul 13, 2020 at 7:24 PM
    #61
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've done it with the truck on the ground but it takes some force in a terribly awkward position.
  2. Jul 13, 2020 at 7:34 PM
    #62
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If you jack up the truck by the trailer hitch and let the axle drop they should fit no problem. Also did I read your coilovers are set to different heights? This is generally frowned upon due to the difference in spring preload and difference in characteristic of dampening between the two settings. The better way would have been to add a shim to the drooping side. FYI
    robabeatle[OP] likes this.
  3. Jul 14, 2020 at 3:42 AM
    #63
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Ah, I didnt realize that. I guess that could be changed out. Makes sense though.
    So one of these should do the trick and also take back the 6112 to the #1 setting from the #3 setting it is at now.
    https://shop-coachbuilder.myshopify...oilover-shim-provides-50-of-lift-tundra-99-06
    *edit* So I have to take off the coilover, disassemble, change circlip setting and put back in, yes? Too bad that vendors selling these coilovers dont inform customers of the spacer option when discussing the circlip settings for assembly. I paid more for them to come assembled and I now I have to undo that. Lessons...
  4. Jul 14, 2020 at 3:43 AM
    #64
    robabeatle
    AZ
    Truck was on the ground. I will try the trailer hitch as the point to jack it up.
  5. Jul 14, 2020 at 7:26 AM
    #65
    robabeatle
    AZ
    how dumb is this?
    bmf4069 and Tundyfundy like this.
  6. Jul 14, 2020 at 7:27 AM
    #66
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not preferable but you've still got the tires on so worst case you're probably getting a concussion.
    Tundyfundy likes this.
  7. Jul 14, 2020 at 7:43 AM
    #67
    robabeatle
    AZ
    yes! only had to disassemble my firepit
    Darkness likes this.
  8. Jul 14, 2020 at 9:00 AM
    #68
    robabeatle
    AZ
    finished! (other than having to take off the drivers coilover, diassemble, change preload, insert coachbuilder shim, assemble, lol)
    prolley gonna move that hose clamp it is messing with me ocd
  9. Jul 14, 2020 at 9:31 AM
    #69
    Tundyfundy
    Bay Area, CA
    Yes exactly what you need to do. You can rent a spring compressor for free from your local auto parts store. I cut some small pieces of fabric to put between the spring and the compressor so I didn’t damage the powder coat on the spring. They say don’t use air tools but I did you just have to make sure you compress both sides equally, like two turns one side, two turns the other and so on. Also turn down your gun to the lowest setting. Yes those CB shims are top notch. The lift they give is double the thickness of the shim. Ie., a quarter inch shim gives a half inch of lift and so on.
  10. Jul 14, 2020 at 9:38 AM
    #70
    Festerw
    Festerw New Member
    04 Tundra DC
  11. Jul 14, 2020 at 9:43 AM
    #71
    robabeatle
    AZ
    If only...I dont have an impact wrench nor air tools.
    Some day fellas...
    Thanks for the help. I plan to give a test run in a few hours. I need to be a bit careful as there are brand new rotors and pads on too. This truck should ride much better now.
  12. Jul 14, 2020 at 9:54 AM
    #72
    Tundyfundy
    Bay Area, CA
    So stoked for you! She’s gonna ride like a dream!
  13. Jul 14, 2020 at 10:21 AM
    #73
    robabeatle
    AZ
    Hey all someone just wrote this message to me in another thread. Thoughts?
    A shim under the collar for the spring is identical to "changing the preload". You change the compressed height of the spring when drooped. Unless you're talking about a shim between the shock bucket and coilover, which you wouldn't have to take the coilover apart for then. Regardless, I disagree that a shim is any better. Changing preload does not change the spring characteristics, the spring is compressed the same amount at ride height either way and the spring rate is the same either way. The ONLY thing that is different, is at full droop the preload force is slightly increased and I highly doubt you'll notice a difference considering 99% of applications adjust ride height/balance that way (again, this is the exact same method as putting a shim between the spring and collar which it sounds like what you intend to do).
  14. Jul 14, 2020 at 10:48 AM
    #74
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wait, what's up with the shim? What's wrong that you're trying to correct for?
    And yes, the guy on that Wheelers thread is correct, preload is full of myths.
  15. Jul 14, 2020 at 10:51 AM
    #75
    robabeatle
    AZ
    So at this point the bilstein is at setting #3 on driver and #1 on passenger. Above someone stated that a better method is to use a shim on the drivers side and set both coilovers to #1 .
  16. Jul 14, 2020 at 10:52 AM
    #76
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Why are you setting them differently? Did you check ride height and see a big difference between driver and passenger?
  17. Jul 14, 2020 at 10:55 AM
    #77
    robabeatle
    AZ
    I did not do that originally. Bilstein directions and Wheelers advised this. Im gonna go look now
  18. Jul 14, 2020 at 11:00 AM
    #78
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would start at the same level and see how they look. Or if you already set to #1 and #3, put it in the ground, drive around the block if everything is torque proper and then measure it.
    These trucks don't get the "Taco Lean" nearly as bad as Tacoma's or newer Tundras. See what's what when it's on the ground and from there I would adjust on the perch if needed. Your truck will never sit dead level, youll get close but some guys agonize over this and it's a fruitless pursuit.
    FrenchToasty likes this.
  19. Jul 14, 2020 at 11:11 AM
    #79
    robabeatle
    AZ
    It is at #3 and #1, I did a very short ride earlier. I just measured from the ground to the fender on each side and they are within 1/4 inch or better. I was concerned that the preload difference messes with the ride characteristics. I mean that is what I dished out the $$ for, a great ride. I am willing to make small changes to eek out the best ride.
    Also, I am at about 1/4 tank full for gas.
  20. Jul 14, 2020 at 11:18 AM
    #80
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You won't feel a difference. The biggest misunderstanding for "pre load" is that making and adjustment to add height (like going from #1 to #3) will compress the spring and cause it to ride harsh.
    The truth is that you are extending the shaft of the shock, not compressing the spring, and you won't feel a difference once the truck is on the ground.
  21. Jul 14, 2020 at 12:01 PM
    #81
    robabeatle
    AZ
    Thanks. I am keeping it as is.
    First ride: steering slop is gone. definitely firmer ride where the truck tracks straight over bumps now instead of getting thrown to the side along with the steering wheel. body roll still mostly there.
    Darkness[QUOTED] likes this.
  22. Jul 14, 2020 at 12:02 PM
    #82
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Your body roll will go away once the sway bar links are corrected.
  23. Jul 14, 2020 at 12:04 PM
    #83
    robabeatle
    AZ
    I put in an order for the moog links and frame bushings. Turns out I am still under my budget so I went for a cheap rear away bar as well.
    bmf4069, Festerw and Darkness[QUOTED] like this.
  24. Jul 14, 2020 at 12:37 PM
    #84
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You got that stuff so far done quickly, good job. Don't forget to get your alignment done once your height is where you want it. Sway bars don'taffect alignment. :thumbsup:
  25. Jul 14, 2020 at 1:52 PM
    #85
    robabeatle
    AZ
    Reached out to coachbuilder. He says shim is the way to go (I think as I missed the call and he left a voicemail and I need to follow up.)
  26. Jul 14, 2020 at 2:18 PM
    #86
    Tundyfundy
    Bay Area, CA
    So OP the guy above is correct. The guy who messaged you. You are putting a shim between the shock bucket and cool over not under the collar which you don’t have to take the coil over apart for. So you don’t change the preload. YOU have to take apart your cool over, not because of the shim but because you are going to change the setting. I think the guy who messaged you was confused on your intent. It is possible to put a shim right above the spring as opposed to above the coil over, and that method would preload the spring and he is right. That’s not what you are doing.
  27. Jul 14, 2020 at 2:25 PM
    #87
    Tundyfundy
    Bay Area, CA
    A shim under the collar for the spring is identical to "changing the preload". (You are not putting it under the collar)
    You change the compressed height of the spring when drooped. (You are not putting it under the collar) Unless you're talking about a shim between the shock bucket and coilover,(yes we are talking about this) which you wouldn't have to take the coilover apart for then. (Correct except you need to change the setting)
    Regardless, I disagree that a shim is any better. Changing preload does not change the spring characteristics,(incorrect as he states below)
    the spring is compressed the same amount at ride height either way and the spring rate is the same either way.(incorrect, when your shocks are at different settings one spring is compressed more)
    The ONLY thing that is different, is at full droop the preload force is slightly increased (so is preload slightly different or is “the spring compressed either way” -it’s different, as he contradicts himself saying here)
    and I highly doubt you'll notice a difference considering99% of applications adjust ride height/balance that way (again, thisis the exact same method as puttinga shim between the spring and collarwhich it sounds like what you intendto do).(you do not plan to do this)
  28. Jul 14, 2020 at 2:51 PM
    #88
    Tundyfundy
    Bay Area, CA
    I see what darkness is saying but extending one shock further gives you Less down travel on the side with the extended shock as you are eating up some of that down travel with the higher setting. Also your up travel on the shorter side is shorter as that side doesn’t have the shock extended out as far. With the shim you have the same travel on both sides and the shocks are at the same spacial height allowing for even travel in relation to your other suspension components.
  29. Jul 14, 2020 at 2:52 PM
    #89
    Tundyfundy
    Bay Area, CA
    Point is at different settings the characteristics of the coils change. Period, however slight or large that difference is can be debated.
  30. Jul 14, 2020 at 3:09 PM
    #90
    robabeatle
    AZ
    Yeah, I think there probably is a valid argument that I will not notice either way, but I am looking to do this "right."
