Work being done this week
Discussion in '1st Gen Tundras (2000-2006)' started by Durbin7, Mar 24, 2021.
  1. Mar 24, 2021 at 9:07 AM
    Durbin7
    Durbin7 [OP] New Member
    Ohio
    Morning y'all, trying to post more and be more involved, 2020 was crazy. So I am having some work done on my tundra this week. I bought it a year ago. 2006 double cab SR5, with 120k miles 2wd. In the last 6 months I had to replace upper and lower ball joints, and the rack and pinion steering system. Today I dropped it off for the timing belt and water pump. I know they have to open up a lot to do that. I am not handy and don't do much with the truck, but have an honest mechanic I know and trust. He thought he would change spark plug, all my filters, and any fluids that needed flushed and refilled. Do you have any other recommendations while it is being worked on this week? Trying to so some preventative maintenance, it is a great truck and want it to run a long time. Thanks
    Durbin
    Darkness and hammeron like this.
  2. Mar 24, 2021 at 9:11 AM
    Professional Hand Model
    Hand Protectors
  3. Mar 24, 2021 at 9:13 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Pcv valve on the driver side, it’s inexpensive and a quick swap while the spark plugs are being done.
    Also maybe clean the Throttle body while it’s off the truck.
  4. Mar 24, 2021 at 9:29 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Plenty a Handy man can do to make her smile, feather dusting for starters as PHM would say !
  5. Mar 24, 2021 at 9:48 AM
    Durbin7
    Ohio
    Professional hand model, your build page is awesome
  6. Mar 24, 2021 at 10:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    You may get some ideas from this thread.
    https://www.tundras.com/threads/2002-sr5-4wd.70271/
  7. Mar 24, 2021 at 10:11 AM
    Hand Protectors
    Thanks. Got the juices flowing after coming to this site. Hopefully that page helps a little. A lot of that stuff is DIY as the mechanics don’t seem to want to mess with it.
    Mostly for you its best to always tell the mechanics you want all OEM (Denso, Aisin, Hitachi) Parts. Do not let them talk you out of them.
    Rex Kramer likes this.
  8. Mar 24, 2021 at 10:18 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    All fluids and filters (except transmission). Belts, hoses, thermostat and spark plugs. Some may recommend a radiator as well to avoid pink milkshake. They aren’t that expensive for a denso unit and are super easy to replace.
    speedtre likes this.
