Won't Fit!!!!
Discussion in 'Wheels & Tires' started by VALORtundra, Aug 18, 2016.
  1. Aug 18, 2016 at 5:20 PM
    VALORtundra
    VALORtundra [OP] New Member
    Stockton, California
    2016 Tundra Limited Crewmax TRD package
    3/1" Rough Country Level Kit 20x9" Fuel Full Blown Wheels 305/55/20 Cooper STT Max Center console organizer
    So I tried mounting 20"x10" Fuel Full Blown wheels mounted on Cooper STT 295/65/20 (35") with a -12 offset and it looked awesome on my 2016 Crewmax with a 3/1" Rough Country Level kit. The problem is that there was rubbing like crazy!
    So we tried a different sized tire with the same rim. We tried 305/55/20 (33") and it looked great also. I still had running on from and rear flap of front tire. We removed the front flap but the tire still rubbed against the plastic that covers the foglighy housing.
    The guys from America's Tire removed that plastic and the tire cleared it. They told me to just cut that plastic but would t do it themselves. I am totally unfamiliar on what to do. Any suggestions? Thank you in advance!!!
    Please see pictures. Thanks again!
  2. Aug 18, 2016 at 5:36 PM
    Island woody
    Island woody New Member
    Scott
    2016 crew max 4x4
    Lift kit, Borla exhaust, 35 inch tires
    I used a heat gun and a 2x4 shoved between it and the tire and bent it in enough for clearance, worked cut and fog lights still sealed up
    NewImprovedRon likes this.
  3. Aug 18, 2016 at 5:37 PM
    Island woody
    Scott
    2016 crew max 4x4
    Worked good not cut
  4. Aug 18, 2016 at 5:59 PM
    Cab mount chop done?
  5. Aug 18, 2016 at 7:23 PM
    PMG
    PMG New Member
    Looks awesome
    PMG
  6. Aug 19, 2016 at 1:13 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    The first guy I have seen with my rims. I was starting to wonder if I was the only guy that liked them.
